VOLT HID *Japanese* slim kit!!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 03-05-2009, 12:43 AM Thread Starter
XenonExpert's Avatar
Hi,
Tired of cheaply made kit that have bulbs flickering, bulbs turning off by themselves or simply a part failing every 3 months? Don't have the money to buy an Xtreme kit with Philips bulbs? No problem.
Just in time for the Holidays we are introducing the Volt HID kit. Japanese parts, low draw and bulletproof reliability. Say goodbye to problematic HID kits!!!
Volt HID Kits offer the latest in High Intensity Discharge (HID) Xenon technology. Volt HID utilizes ultra slim-line ballasts with next generation patented Digital+ technology for optimal light output and ballast efficiency. This exclusive HID conversion kit is the leader in digital ballast technology and will provide you with a level of performance and quality that is unmatched by similar digital HID products found on the market today. Volt HID Digital+ ballasts are the smallest and lightest ballasts manufactured today. This new ultra-slim design will enable the product to be used in a wider variety of applications.
- Patented Digital+ technology for optimal light output & ballast efficiency
- Ultra-slim design and light weight ballasts
- Quality Japanese parts
- CE, UL, and E4 certified OEM Grade Xenon HID Components
- Rubber injected waterproof/shockproof ballasts
- Laser aligned HID Xenon Bulbs to ensure optically correct beam patterns
- Full 1 year replacement warranty
BALLAST SPECIFICATIONS:
-These ballasts are equipped with next generation Digital+ Technology allowing the ballast to exert greater control over electrical flow to the bulb. As a result, the voltage output to the bulb is more consistent and stable, resulting in constant lumen output, brightness stability,with no flickering or one side not lighting up unlike some thin ballast designs on the market.
- Automatic reverse polarity protection.
- Dual EMI Filter protection Circuit shielding.
- Ultra-slim design and light weight: Our ballast measures 3" x 2 5/8" x 9/16" (7.6cm x 6.6cm x 1.4cm), and weighs only 7 oz (200 g).
- Volt Digital+ ballasts are uniquely designed for aftermarket applications as they are rubber injected to protect against harsh weather conditions
To ensure optimal light output, the Volt HID Kit uses laser calibrated bulbs so that the focal point of the HID bulb matches the focal point of the corresponding halogen bulb. This will result in both proper fitment and optically correct beam patterns. These bulbs are rated at approximately 2500 hours of use same rating as high end Philips and Osram bulbs. Industry leading AMP style connectors are used to ensure proper water tight connections. Volt HID is manufactured in an industry leading high tech facility. Due to stringent manufacturing standards, this product line carries ISO certification, CE and UL safety listed, and is E4 certified. This product carries a one year legitimate warranty.
LIMITED TIME OFFER: $120 USD
Get it here: http://www.xenonexpert.com/volt_hid_sale.html
Enjoy!
Oliver
XenonExpert is offline
post #2 of 11 (permalink) Old 03-23-2009, 01:42 AM
H15A5H1's Avatar
im very interested in taking advantage of this sale, but i have a couple questions if you dont mind answering:
how are these in comparison to apexcone's hids? do apexcone/ddm fall under the same category as generic brands?
i had a 35watt 5,000k hid set from apexcone and one of the lights have a flickering problem during startup. also, the 5,000k looks yellower than stock hids.
* also, how are these japanese parts only when they are manufactured in Taiwan??
2007 MAZDA6s 5-door (tungsten gray)
H15A5H1 is offline
post #3 of 11 (permalink) Old 03-23-2009, 01:59 AM
H15A5H1's Avatar
at a 25$ shipping price, how long will the shipping time be?
H15A5H1 is offline
post #4 of 11 (permalink) Old 03-23-2009, 02:17 AM Thread Starter
QUOTE (H15A5H1 @ Mar 23 2009, 12:42 AM)
* also, how are these japanese parts only when they are manufactured in Taiwan??[/b]
Apexcone/DDM is better than generic brands but not as good as the Volt.
Parts are Japanese and assembled in Taiwan to reduce cost. If you want the parts and assembly all from Japan we have the Xtreme.
post #5 of 11 (permalink) Old 03-27-2009, 11:40 PM
H15A5H1's Avatar
im guessing the "special deal" is balanced out by the high 25$ shipping cost as the only option?
H15A5H1 is offline
post #6 of 11 (permalink) Old 04-01-2009, 01:30 AM Thread Starter
QUOTE (H15A5H1 @ Mar 27 2009, 11:40 PM)
im guessing the "special deal" is balanced out by the high 25$ shipping cost as the only option?[/b]
Not at all. It's a flat fee for all North America via UPS and that includes brokerage fees and any duties. So $25 is actually super cheap.
Oliver
QUOTE (H15A5H1 @ Mar 23 2009, 01:59 AM)
at a 25$ shipping price, how long will the shipping time be?[/b]
They ship from Canada so to you in California about 7-10 days.
Oliver
post #7 of 11 (permalink) Old 04-19-2009, 09:02 PM
Hello,
Im interested in upgrading my 04 6i's stock halogens to HID. Is this kit all that is required or are there additional parts/wires/etc that must be purchased for installation?
Also, Im from Toronto. Is this item shipped from Montreal? or Cali? Whats the expected transit time?
Thanks.
sherstino is offline
post #8 of 11 (permalink) Old 04-22-2009, 03:15 AM Thread Starter
QUOTE (sherstino @ Apr 19 2009, 09:02 PM)
Hello,
Thanks.[/b]
Hi
Sure you can. All you need is included in the kit.
Transit time is about 24-48 hours to Toronto.
Oliver
post #9 of 11 (permalink) Old 10-02-2009, 01:18 AM Thread Starter
More tracking sent!
Oliver
post #10 of 11 (permalink) Old 08-19-2010, 08:56 PM
Albertngoo's Avatar
Groans: 13
bump to get the spam off the front page.
2004 Lapis Blue Mazda6i
Check
and
, and
, and
, and
, and
, and
Check all of them
Albertngoo is offline
