Front end creaking/squeaking - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Suspension / Brakes
New User? Register
Old 01-01-2013, 10:26 PM   #1 (permalink)
Sean486's Avatar
Quoted: 14 Post(s)
Default Front end creaking/squeaking
I have been noticing some squeaking and creaking in the front end lately. It is not a brake squeak, more like a suspension creaking.
The car drives fine, and doesn't shake or shutter on the highway, and the brakes work good. I definitely hear it at low speeds like when going over speed bumps or even when pulling up to the drive through at McDonalds. I haven't been too worried about it, but it is on my list of things to check into. Any ideas or where to look first?
The car has 181K on it.
'05 Mazda 6 iSport 198K Charcoal
'06 Mazda 5 69K Blue (sold, needed more room)
'92 Subaru SVX Lsi 158K Liquid Silver
'07 Honda Odyssey EXL 60K
Sean486 is offline   Reply With Quote
Old 01-01-2013, 10:43 PM   #2 (permalink)
elemento_74's Avatar
Quoted: 36 Post(s)
Might be your bushings.
Sent from my SAMSUNG-SGH-I727 using AutoGuide App
K&N CAI,Magnaflow exhaust,HID driving & fog lights,DoubleDin stereo with NAV,VIS carbon fiber hood,Autoexe grill & lip,Motegui 18' rims with Hankook tires,speed6 brakes,Steel braided lines,TB coolant bipass,TB grounded,PKE alarm system,Mazdaspeed short shifter
elemento_74 is online now   Reply With Quote
Old 01-02-2013, 08:41 AM   #3 (permalink)
Sean486's Avatar
Quoted: 14 Post(s)
Control arms or sway bar?
Old 01-02-2013, 09:29 AM   #4 (permalink)
Quoted: 36 Post(s)
I would check or maybe replace all of them
Old 01-02-2013, 02:27 PM   #5 (permalink)
Quoted: 13 Post(s)
I noticed the same thing with my car, but never looked in to it. I have Eibach springs and Koni FSD shocks, so I figured it could have something to do with bushings. The car still handles great, just creaks sometimes. RockAuto has bushings and they are pretty inexpensive. Could start with replacing the bushings for the control arms and it only would set you back $20 or $30. They might need to be replaced at the amount of mileage anyways.
2003 6S MTX, 2006 Fusion engine swap, Fidanza alum flywheel, Exedy clutch, Cordova Motorsports 70mm OTB w/ coolant bypass, Custom Spectre CAI, CPe MAF Customizer, Cp-E Wishbone Mount, Magnaflow cat-back, EGR mod, TWM short shifter, Koni FSD, Eibach Pro-Kit, 18" Kazera KZ-J (+55mm), Blacked out emblems, Atenza Badge, Audiolink MP3 USB adapter, Scangauge II w/ Blendmount, Apexcone DDE Lighting Raptor Edition, 8000k 55w, red interior LED's.
gondlesnorf is offline   Reply With Quote
Old 01-02-2013, 03:25 PM   #6 (permalink)
Sean486's Avatar
Quoted: 14 Post(s)
Let's say I don't replace them, will it damage anything, or will it just be a noisy car?
Old 01-02-2013, 06:57 PM   #7 (permalink)
Quoted: 4 Post(s)
Lose control arm bushings make a sloppy ride aswell
stealthvr4 is offline   Reply With Quote
Old 01-03-2013, 01:03 PM   #8 (permalink)
Quoted: 13 Post(s)
Well, if you look at the anti torsion link on the V6 models, those would fail because the bushing was weak, which caused the engine to sway back and forth. I would say that eventually, a bushing or two may break apart causing the component to flop around loosely. Mine have been squeaky for over a year and everything is still fine. Alignment is good, car handles great... You probably have time, but I'd suggest getting them replaced for peace of mind. I'm going to replace mine sometime after I get an engine in my car.
The Following User Says Thank You to gondlesnorf For This Useful Post:
Sean486 (01-03-2013)
Old 01-17-2013, 12:01 AM   #9 (permalink)
I had the same problem took it to a suspension shop and they found water in the ball joints. try replacing grease with a hypodermic grease gun in ball joints. I was told if it got much worse the control arms would need to be replaced. hasnt squeaked since I replaced grease. Hope that helps
airforcesicksix is offline   Reply With Quote
Old 01-17-2013, 12:29 AM   #10 (permalink)
ydrone's Avatar
Quoted: 10 Post(s)
Endlinks. Notorious for creaks.
2006 6s 5-dr gray, AEM SRI- Magnaflow exhaust- Kazera KZ-D 18x7.5- Bilstein shocks/HR springs- AWR endlinks- Stoptech rotors, Hawk brake pads- Neo chrome vanadium lug nuts- AGM battery- Blue: calipers; interior LED lights; footwell lighting; LED ribbon trunk lights; instrument cluster gauge- Stubby antenna- Titanium Burl wood panels- NGX Platinum plugs- Tein hood damper- Greddy air diversion plate
ydrone is offline   Reply With Quote
