Knocking sound coming from rear end - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 08-15-2012, 06:37 PM Thread Starter
My 2007 Mazda 6 has a knocking sound that comes from the rear end somewhere. It does it mostly when I apply the brakes but has gotten to where it does it sometimes even when the brakes aren't applied. I have been told maybe its the u-joint and also read online where it might be the brake drums are warped. I figured I'd check on a forum concerning my exact car to see if anyone could help with suggestions. Thanks.
Sent from my iPhone using AG Free
C_mc73 is offline
post #2 of 9 (permalink) Old 08-16-2012, 08:40 AM
mrpd150's Avatar
Quoted: 33 Post(s)
Unless you've got four wheel drive, it isn't a u-joint. Check your rotors for cracks, this is what I had last week, see my post on inspecting rotors from last week Inspect your rotors, kiddies!!!
Noises that happen when you brake are most likely brake related.
mrpd150 is offline
post #3 of 9 (permalink) Old 10-19-2012, 01:10 PM
I also have a clicking sound from the rear end when my car goes over speed bump. Took it to the dealer for inspection. During test drive they heard it but after lifting the car on hoist found nothing. After that they guessed that may be the rear pads are lose in calipers and make this noise because of a jolt and offered to grease them. I agreed and they charged me $100 for this but clicking noise did not disappear. I demanded the refund and got it. It was 2 years ago. Since then the clicks became louder. Does anybody know what this could be ?
2007-Mazda6-GT-V6-Owner is offline
post #4 of 9 (permalink) Old 10-19-2012, 01:22 PM
Glad to hear they refunded the rape-charge! On a more serious note, how old are your shocks?
2003 6S ATX - Onyx Black - Black Leather - Sport+Comfort+Premium Packages - Moonroof
AWR 88 Duro Mount Set - FluidAMPR - RacingBeat F&R Sways - TB Coolant Bypass - EGR Mod - Airbox Mod w/K&N Filter - Inline PCV
Royal Purple MAXATF in AT and PS System
Goodyear Eagle GT 215/50R17 all around
bevobrown is offline
post #5 of 9 (permalink) Old 10-19-2012, 01:23 PM
karlt10's Avatar
Quoted: 25 Post(s)
End links could be toast.
No reason brake pads should click going over a bump. The pads also have springs that keep them separated; dealer should know and notice that immediately.
If it was me, I'd lay on the ground under the car and have someone push on the rear to get it moving and just listen. If you have a set of ramps to back into, even better.
Eibach springs / MazdaSpeed bars / Bilstein / Steeda Adj FR links / Racing Beat RR links / GTSpec Rear Susp & Trailing Braces / Steeda shock tower brace
EBC Ultimax rotors & pads / StopTech lines / Motul fluid
MSDS headers / Magnaflow cat / Racing Beat mufflers / Cork Sport urethane hangers / WeaponX coils / AER CAI / Fluidampr pulley
EGR mod / FilterMag / Street Unit engine mount /
B&M trans cooler / Amsoil fluid
Mazda iPod adapter
/ CX7 antenna
Continental Extreme DWS / Bridgestone Blizzak
karlt10 is offline
The Following 2 Users Say Thank You to karlt10 For This Useful Post:
2007-Mazda6-GT-V6-Owner (10-19-2012), xkreedx (10-25-2012)
post #6 of 9 (permalink) Old 10-19-2012, 01:31 PM
ok, thank you, will try to check the links
post #7 of 9 (permalink) Old 10-19-2012, 01:33 PM
The shocks are as old as the car (2007). It has 73000 km (~ 50000 miles) on it.
post #8 of 9 (permalink) Old 10-25-2012, 08:32 AM
On my MSP, I had a clicking noise coming from the rear of the car. Over time, the noise got louder and louder and went from being a "click" to an ungodly "clunk". Eventually, as I was pulling into a driveway, the rear suspension made the loudest sound the car's ever made; it sounded like a gunshot. After that, the rear was whisper quiet. Turns out the endlink had been going bad for some time and had finally given up the ghost in spectacular fashion.
Long story short, yeah, check your endlinks.
We Are Ninja is offline
The Following User Says Thank You to We Are Ninja For This Useful Post:
post #9 of 9 (permalink) Old 06-25-2014, 09:07 AM
Same horrid "clunking" or banging noise, like a cannon ball was rolling around in the trunk, especially slow speed turning into/out of parking lot etc. It was the left rear stabilizer endlink that was loose/worn. Had it replaced and all is well.
2004 Mazda 6, 80,000 miles
BillON2 is offline
