parking brakes barely works! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 03-22-2011, 02:24 AM Thread Starter
newbie here, can somebody help me, i got a 2003 mazda 6i, my parking brakes barely works, i can even go 60mph and literally yank my parking brakes all the way up and nothing will happen, i can feel that its working because the car is decelerating, but very very slow, so i guess there are no cable that snapped, beacause it still works, just barely. somebody told me that i can adjust it by turning the nut that can be found under the center armrest, i found it, but the problem is the nut is already turned all the way into the bolt, so it cannot be adjusted any further. the brake pads has been replaced last month, i dont know if theres a connection with that, and the brake system is all oem, nothing modified. what do you think? thanks in advance,
ghostrider85 is offline
post #2 of 10 (permalink) Old 03-22-2011, 10:05 AM
banana boat.
flipper66's Avatar
Quoted: 329 Post(s)
how is your brake fluid?
ripping the ebrake at 60 is dangerous and stupid.
flipper66 is offline
post #3 of 10 (permalink) Old 03-22-2011, 03:34 PM Thread Starter
the brake fluid resevoir is full,this is the story, i just bought this car a month ago, bought it cheap, because the car is really messed up, i have to replace lots of things, including new brake pads. this afternoon, it just came into my mind to try the parking brakes instead of using foot brake while driving it to the garage, and i almost hit the wall! i said, wtf?! i am going very very slow but the hand brake did not manage stop the car quickly, so i went out of the garage again, tried the parking brakes couple of times more, but its just the same, its taking way too long to stop the car, i have other cars, their parking brakes isnt this bad, is theres some other way to adjust the parking brakes? from the caliper perhaps? i already tried to put it on neutral, on a steep road, yes neutral, so i can see if the parking brakes can hold it, but it cant, i dont know what to do anymore, please help me,
post #4 of 10 (permalink) Old 03-22-2011, 08:41 PM
lamborg's Avatar
As far as I know there should be some sort of a bolt or something to tighten the hand brake. Don't ask me how to do it, though as I'm looking for an info as well.
lamborg is offline
post #5 of 10 (permalink) Old 03-22-2011, 09:43 PM
TurboGTU's Avatar
Quoted: 57 Post(s)
Groans: 21
Cables might be going bad, the mechanism that engages it at the brake may be seized. Few things to check into.
06 Mazda 6s Grand Sport - stock
08 GMC Acadia SLT-1 FWD - stock
89 Mazda RX7 GTU - sold, :-(
TurboGTU is offline
post #6 of 10 (permalink) Old 03-22-2011, 10:53 PM
banana boat.
flipper66's Avatar
Quoted: 329 Post(s)
remove your cup holder and their is a nut to tighten down on the Ebrake.
stretched cable is a very real possibility.
If you replaced the pads last month, were they maybe not seated properly? who did the service? If you have to deal with winter conditions, you may even have a rust problem.
hard to be sure of anything without a little more info.
post #7 of 10 (permalink) Old 03-23-2011, 12:45 AM Thread Starter
i tought that the cables has been stretched so i was about to buy those cables, i called one of my friends, who had a mazda 6 before, to help me out about this project, he came, then he checked the car, we started disasembling the center console, i was wrong about i said that the adjusting nut is already all the way into the bolt, because when i looked at it the last time i did not remove the whole center console, i only remove the cupholder, thats why i didnt saw it clearly, we can adjust it a little bit more, if we want to, and that what we did, now theres another problem, we tried to raise one of the back wheels off the ground so we can try to spin it, but now the wheel is locked! we didnt adjusted the nut that much! so we decided to put but the adjusting nut to its previos place, now the wheel spins freely, but now the parking brake barely works again! he explained to me that its just the way it is, even if we replace the cable it will be just like that, the reason he told me is this, the problem is the parking brake handle itself, the travel from engaging and disengaging the brakes is just too short that when you pull the handle, it only pulls the cable slightly, by the way, this is what my center console looks like inside, yuck, good side is theres coins inside,
post #8 of 10 (permalink) Old 03-23-2011, 07:22 AM
You need to take rear caliper out,open brake fluid cap, turn it in clockwise to get some space. Then adjust nut under center console. Then step on brake to reset rear caliper
Romaninus is offline
post #9 of 10 (permalink) Old 09-07-2015, 10:36 AM
I too have a mazda6 2004 with problems on the handbrake.
Biggest problem is, that its not affecting the right side.
I need to adjust the tension on the cable, but how do you remove the box between seats? I mean that part what is sitting on top of the cable adjustmen nut.
heller is offline
post #10 of 10 (permalink) Old 09-14-2015, 01:51 PM
10Ring's Avatar
https://www.google.com/webhp?sourcei...center+console
10Ring is offline
