After careful tie rod end replacement, alignment necessary? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 03-24-2010, 12:26 PM Thread Starter
dawei213's Avatar
Well, my outer passenger tie rod end is started to go and had to change it out. I loosen the jam nut ever so slightly so i can remove the tie rod end. I've also counted the number of twists it took to remove the tie rod end. Placing the old tie rod end next to the new one and they are identical length. When I place everything back on, it took the same number of twists. Then I tighten the jam nut by the same amount. The question is, do I really need to have an alignment done? I have a custom alignment and would hate to have to do it again, since it runs around $200, if it's not needed. The car tracks straight and does not pull in any funny directions.
dawei213 is offline
post #2 of 6 (permalink) Old 03-25-2010, 12:00 AM
karlt10's Avatar
Quoted: 25 Post(s)
I've done it exactly that way and been fine. Both in feel and as witnessed in tire wear.
If it feels fine, I wouldn't worry about it. Hell, the new parts are already putting you in better shape than the old ones were.
Eibach springs / MazdaSpeed bars / Bilstein / Steeda Adj FR links / Racing Beat RR links / GTSpec Rear Susp & Trailing Braces / Steeda shock tower brace
EBC Ultimax rotors & pads / StopTech lines / Motul fluid
MSDS headers / Magnaflow cat / Racing Beat mufflers / Cork Sport urethane hangers / WeaponX coils / AER CAI / Fluidampr pulley
EGR mod / FilterMag / Street Unit engine mount /
B&M trans cooler / Amsoil fluid
Mazda iPod adapter
/ CX7 antenna
Continental Extreme DWS / Bridgestone Blizzak
karlt10 is offline
The Following User Says Thank You to karlt10 For This Useful Post:
dawei213 (03-25-2010)
post #3 of 6 (permalink) Old 03-25-2010, 12:04 AM Thread Starter
dawei213's Avatar
Yeah, I figure that much. I'd just like to get confirmation from the more experience folks such as yourself. Thanks Karl.
dawei213 is offline
post #4 of 6 (permalink) Old 03-25-2010, 12:32 AM
QuickSilver6's Avatar
Send a message via Yahoo to QuickSilver6
I changed both tie rod ends, counted the number of twists and everything. But i had a 6 month warranty on my alignment so i took it in and everything was still in specs. So an alignment is not necessary.
QuickSilver6 is offline
post #5 of 6 (permalink) Old 08-02-2012, 11:15 AM
Is it true that in order to replace the inner tie rods that the entire rack has to come out first?
2006 Mazda6 S Grand Sport
5-speed manual ǀ heated leather ǀ Bose sound w/ subwoofer pre-amp ǀ Bluetooth aux in ǀ Viper remote start ǀ sharkfin antenna ǀ HIDs ǀ 3500K Xenonmatch fogs ǀ LED city and license plate lights ǀ LED interior accent lighting ǀ MX-5 shift knob ǀ gutted airbox ǀ TB ground ǀ AWR 70 duro engine and transmission mounts ǀ Exedy clutch and Fidanza lightweight flywheel ǀ Michelin Primacy MXM4 225/45R18
2005 Lexus RX330 AWD
2007 Honda Shadow Spirit VT1100C
tbm5690 is offline
post #6 of 6 (permalink) Old 08-02-2012, 06:25 PM
^ Not true.
Sent from my PC36100 using AutoGuide.Com Free App
gen1MZRman is offline
