Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Suspension / Brakes
Old 11-18-2009, 04:06 PM   #1 (permalink)
QuickSilver6's Avatar
Send a message via Yahoo to QuickSilver6
I read on here somewhere that someone had upgraded there stock brakes to the speed 6 brakes, my question is what all do i need, other than the caliper and rotor. Will i need the bolts and brake hoses from the speed or will the stock bolts and hoses work. Also what about the dust shield, should i just leave them off or should i get the shields for the speed?
I can get the front rotors and calipers with bracket, just not sure about the rest, any imput would be helpfull.[/size]
QuickSilver6 is offline   Reply With Quote
Old 11-20-2009, 09:37 PM   #2 (permalink)
shutterbug2020's Avatar
Send a message via AIM to shutterbug2020
QUOTE (QuickSilver6 @ Nov 18 2009, 03:06 PM)
I can get the front rotors and calipers with bracket, just not sure about the rest, any imput would be helpfull.[/size][/b]
IIRC all of the stock parts will work. Up front you will need to bend (slightly) the brake line to make room for the larger caliper/rotor. In the rear the dust shield has to be removed to fit the rear caliper. The master cylinder is the same so all is good. Cheers!
Bright Island Blue 06 6s
shutterbug2020 is offline   Reply With Quote
Old 11-20-2009, 10:14 PM   #3 (permalink)
Egierda's Avatar
You need:
1. Speed6 calipers
2. Speed6 caliper brackets
3. Speed6 rotors
4. Speed6 brake pads
5. Speed6 soft lines/SS brake lines for the speed6
The hard lines between the 6 and the speed6 "should" be the same because my Stoptech BBK has the exact same part number for the regular 6 and the speed. Thus, the SS brake lines that come with it will fit both cars...meaning that the hard lines should be identical.
04' 6s MTX sedan - Tein - TC Sportline - Seibon - AEM - Magnaflow - Cusco - Streetglow - Momo - iRotors - Hawk Performance - Maxcar - Ignited - Exile - American Bass - Legacy - TenzoR - Falken - Redline - TWM - Compustar - Racing Beat - AWR - Autometer - Lotek - AutoExe - Megan - Feather Carbon - Autolumination - Wedge Engineering - Scroth - Sparco - Sabelt - NRG - DG Motorsports - Carbon Creations - Cordova Motorsports - Sniper Tuning - Axxess - GT Spec - Tanabe - CP-E - Scangauge - Steeda - Hella - Aero Catch - ELF Racing - Stoptech - Car_LED - ARP - Project Kics
Egierda is offline   Reply With Quote
