Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Suspension / Brakes
Old 11-11-2009, 05:12 PM   #1 (permalink)
I'm just wondering when should I replace my rotors? What thickness should they be under to consider changing? cuz i'm about to change my pads soon, so i'm wondering if i should replace the rotors too
fredricktsang is offline   Reply With Quote
Old 11-18-2009, 05:45 PM   #2 (permalink)
I would just get the rotors out and have a shop resurface it, they will tell you if they are still thick enough to be resurfaced.
I got 94K miles on mine and they're still the original ones
2004 MAZDA 6S 5 DOOR HATCHBACK,STEEL GRAY, ATX
KNN CAI, MAGNAFLOW EXHAUST
TRUECOOL LPD TRANNY COOLER
EVOKE 17X7 GUN METAL RIMS, 225/45/17 ZR NEXEN N3000 TIRES
seigfredm is offline   Reply With Quote
Old 11-19-2009, 10:17 AM   #3 (permalink)
wannabe6owner's Avatar
because of the differences in pad material, its always a good idea to have your rotors resurfaced (or turned). you can also sand with a fine grit sand paper until there is a light cloudy haze to get some of the embedded pad material off the surface. be sure to clean the rotor after sanding. a local shop turned mine for $15 a rotor so its not a big deal.
one thing to keep in mind is different pads may adversely react with the OEM rotor surface. both EBC and Hawk pads did a number on my rear OEM rotors with a lot of grooving and uneven pad wear. i've since been recommended to use ceramic pads for better rotor life.
Attention: Please be sure to read my reply or original comment before "flaming" or unecessarily writing uninformed d-bag responses. A difference in opinion or presentation of facts contrary to your beliefs does not imply an attack on your views or pride. This is the Internet, not elementary school recess. Thank-you.
wannabe6owner is offline   Reply With Quote
Old 12-03-2009, 02:07 AM   #4 (permalink)
shops charge you an arm and a leg to resurface the rotor. if it doesn't have obvious noticeable scratches on them, i wouldn't think it's necessary. post pics of your rotor and we'll judge
the mazda is offline   Reply With Quote
Old 12-03-2009, 08:24 PM   #5 (permalink)
Spazdog's Avatar
Most shops use the cheapest Accuturn lathe and have a shop monkey gouge the crap out of your rotors and cut them in one pass.
I wish they would just let me do it. I'd still be willing to pay them.
Spazdog is offline   Reply With Quote
Old 12-30-2009, 02:58 PM   #6 (permalink)
QUOTE (the mazda @ Dec 3 2009, 01:07 AM)
shops charge you an arm and a leg to resurface the rotor. if it doesn't have obvious noticeable scratches on them, i wouldn't think it's necessary. post pics of your rotor and we'll judge[/b]
In my opinion, this is bad advice. Any time you're changing pads, you should turn or replace your rotors too. It costs less than $20 to get both done at O'Reilly or a different parts place and is well worth it.
'03 Mazda 6s Lapis Blue w/ full Razzi body kit
Past Owner of an '03 Protege5 (for 32 days :-( RIP) and a '97 Explorer (miss that thing too)
jayhawk6s is offline   Reply With Quote
