What are factory alignment specs for the first-gen "Grand Touring Sport," which has 18" wheels?
And what is the range of negative camber I should be able to add with the stock parts? (I want to reduce the plowing and scrubbing of the front tires in tight turns....) |
#2 (permalink) | ||
QUOTE (dbooksta @ Nov 11 2009, 09:04 AM)
http://forum.mazda6club.com/index.php?showtopic=72653 There is some good reading there, and much of the information applies to the regular Mazda 6 as well. There is also a link in the first post to an alignment sheet scan showing the factory specs. I also have a copy of the alignment section from the factory service manual available here: http://www.4shared.com/file/105145465/b99d...heel_align.html QUOTE (dbooksta @ Nov 11 2009, 09:04 AM) Quote:
The front suspension has no factory camber adjustment. You can add that capability with SPC adjustable ball joints. Lowering the suspension will also reduce the camber slightly (i.e. more negative). There is also an Australian company called Fulcrum Suspension that is supposed to offer a set of eccentric upper control arm bushings that will add camber and caster adjustment: http://www.fulcrumsuspensions.com.au/ I haven't heard of anyone trying their product yet.
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
#4 (permalink) | |
QUOTE (dbooksta @ Nov 11 2009, 10:24 AM)
The heart of the discussion in the thread I linked above is that the factory alignment specs allow too much variation in the values, and that tighter specs should really be used for a good alignment. The wide specs make completing an alignment easy for the techs. If you want to ensure good performance and tire life, more restrictive specs are the way to go.
