I ordered Hawk HPS pads and Centric Premium blank rotors from TireRack. The package arrived yesterday, just in time for my planned brake job this weekend. I took the rotors out of the box, unwrapped the plastic and began cleaning off the coating and inspecting them. I was shocked to find a deep gash on the outer edge of one of the rotors! Clearly this was done during manufacturing and before milling the surface as the black "E-Coating" was applied inside the gash. Here's a pic showing the defect:
![]() ![]() Would this gash cause me any problems with pad wear or noise? I'm really dissapointed in the quality of the Centrics based on this. I have to change brakes this weekend since my stock pads are all but gone at 52k. The rotors feel like they are good shape, so I'm thinking about just having them turned and leaving it at that. I'd really like to use the Centrics, but I'm not sure about that gash. Looks like the pad sweep will cover the gash and I'm not sure what problems that may cause. Any input?
<span style="font-family:Tahoma">2006 6i Grand Sport | Glacier Silver Metallic Smoked LED Rear Reflectors | Smoked LED Sidemarkers | LED Lighting | CX-7 Antenna | Airbox Mod | 17" Enkei RP03s Future Plans: Window Tint | Painted Calipers/Hubs | Racing Beat Axle-Back Exhaust</span> |
tire rack has a great return policy, just contact them and they'll replace it quickstyle. i would imagine a brake job could wait a week of daily driving unless you really have no pad left i guess.
i really don't see the gash being an issue with pad life really, and as you said it looks like it was done at machining, so as long as it's balanced i really doubt there will be an issue. BUT, why chance it? if you can, just get one that you don't have to assume will work.
They are overnighting me one for Saturday FedEx delivery. They had no issue with replacing it and matching the two-day shipping I originally paid for, but I talked them into overnighting it and sending a call tag for the defective one. I hope this is just a fluke as I've read good reviews of the Centric rotors. I am a bit concerned because, according to the box, these are made in China. I thought they were made elsewhere?? Oh well, they seem like great quality aside from the gash and I think the non-directional, double-disc ground finish will help bed the pads in properly. The brake job shall continue as planned thanks to TireRack's customer service!
Centric is one of the largest brake mfr's in the world, and they get material and produce parts in many different parts of the world. They've been around for a long time, which tends to say something. i'm sure you just got one that made it through the system somehow.
Yeah, I'm sure they are good quality overall.
Now my next problem is getting the old rotors off. Those retention screws are a major pain! I got an impact driver and beat the ever-loving crap out of it, but the screws won't budge. I don't have access to an oxyacetylene torch, so I tried a small propane torch and heated on the rotor for about 3 minutes. Still nothing! I'm thinking the impact driver I got from Autozone is crap. Not sure what to do now.
#6 (permalink) | |
QUOTE (TNM6i @ Oct 31 2009, 02:17 PM)
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
#7 (permalink) |
Ended up just drilling them out after breaking the bit of the impact driver off in the screw head. Driver side done, now to the passenger side.
#8 (permalink) |
I don't think it would have any negative effect. No difference whatsoever
But you paid for a perfect rotor, not a blemished one. So you deserve a perfect rotor. |
