I have a 2007 mazda6s hb with about 25,000 miles on it. I'm not sure if its just me, but I feel like the car feels a bit mushy when I drive. The suspension doesnt seem as stiff and feels a bit bouncy. I also noticed that when I apply some pressure to the doorsill with my foot, I can push the car down pretty easily. Im not sure if my springs or shocks are giving out. What does everyone think??
2007 MAZDA6s 5-door (tungsten gray)
#3 (permalink) | |
QUOTE (H15A5H1 @ Oct 20 2009, 02:11 AM)
Checking the shocks is really easy. Rapidly push down one corner of the car and release. If the suspension quickly moves back up and stops, the shocks are probably fine. If the car bounces a couple of times, the shock is shot. Repeat at all the other 3 corners to check all the shocks.
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
#4 (permalink) | ||
QUOTE (ydnauhz @ Oct 19 2009, 11:20 PM)
QUOTE (jd42 @ Oct 20 2009, 07:36 AM) Quote:
Get some Konis. Stiff as hell.
2003 Mazda 6s- Konis all around, Progress Rear Sway, Hid in Lows, EBC Ultimax Sport Rotos w/ EBC Redstuffs, PIAA 1000XT's, 225/45/17 Toyo Proxes 4's and Ecsta's, Cntinental Extreme Contitacts, MSDS headers w/Magnaflow spun metallic cat w/stock exhaust |
Definitely some gone shocks. My mates 82 corolla is gone to heck. I one jumped on his car and it was like a trampoline. The only way he solved it was to put his overweight step-mum in it, that stiffened her right up!
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune |
#7 (permalink) |
Do worn shocks also cause a mushy feeling in the steering? The steering responsiveness in my 2004 is not nearly as crisp as it was 105,000 miles ago.
2004 Mazda6s MTX |
#8 (permalink) | |
![]() Join Date: Apr 2005
QUOTE (fly757 @ Oct 22 2009, 12:46 PM)
#9 (permalink) |
I replace the power steering fluid once every year. It used to help a lot when my car was young, but now it has over 100k on it. Maybe the steering rack is getting tired, and a little sloppy. However, I'm pretty sure it's my suspension is wearing out. Especially since I have made aggressive turns frequently throughout the life of my car.
What else besides shocks might cause this "sloppiness?"
2004 Mazda6s MTX |
