I noticed for a while now even when we first got the car about a year ago... when stopping say around 60km/h, I find the steering wheel to judder a bit. It is not ABS as it is not pulsating feel from the pedal. I think the brakes are warped. Any idea? I wanna get it looked by the dealership on my next oil change. Car is 1-year old bought new.
Was the car ever checked in regards to the brake lines? You might need to have the brake lines bled to get any air out of the system. OR better yet, flush the brake fluid and refill brand spankin new and at that time, the lines can and should be bled to ensure proper braking.
Link to the Yellow Submarine [2003 Speed Yellow]... Come join the flickr group! http://flickr.com/groups/atenza/
though this can be attributed to warped rotors, it's not necessarily the case, though the solution would be the same. typically on a warped rotor you would feel the issue through the brake pedal, with or without steering vibration, but it is always through the pedal usually. the reason for this is as the high/low spots in a warped rotor pass the piston, it would push the piston back in a small amount, pushing fluid back and in turn being felt by your foot....happening over and over as quickly as the wheels rotates, it's should feel like a vibration in the pedal.
though not common in the 6, an issue commonly referred to as brake judder could be the issue. especially if any non-normal driving styles have happened lately...canyon driving, stop and go followed by a long hwy drive (or the reverse), hard braking in rainy weather....but of things. essentially your brake pads heat up in a way that leaves an uneven layer of pad material on the disc, which cause the pads to now grap a bit differently in that one spot. so pedal pressure would stay the same, but as the disc rotates there is a slip/grap sensation that is transfered to the steering wheel, as the spots are never in the same spot on both discs (99% of the time it's just the front) so when the left disc passes that spot it pulls left, and opposite for the right....very quickly obviously. with a judder issue it's very common to only be felt at certain speeds, which are usually close to the speed in which the original pad layer issue happened. ...that out of the way, same fix, turn the discs or replace.
#6 (permalink) | |
QUOTE (TRMM @ Sep 28 2009, 10:35 AM)
OK I can only blame my wife. The 6 is her daily driver. But in her defence, all her other cars never had this problem. Anyhoo, called Mazda and they are gonna fix it under warranty. |
#7 (permalink) |
+1 to Tea's comment
Warped rotor and/or uneven pad deposition.
04' 6s MTX sedan - Tein - TC Sportline - Seibon - AEM - Magnaflow - Cusco - Streetglow - Momo - iRotors - Hawk Performance - Maxcar - Ignited - Exile - American Bass - Legacy - TenzoR - Falken - Redline - TWM - Compustar - Racing Beat - AWR - Autometer - Lotek - AutoExe - Megan - Feather Carbon - Autolumination - Wedge Engineering - Scroth - Sparco - Sabelt - NRG - DG Motorsports - Carbon Creations - Cordova Motorsports - Sniper Tuning - Axxess - GT Spec - Tanabe - CP-E - Scangauge - Steeda - Hella - Aero Catch - ELF Racing - Stoptech - Car_LED - ARP - Project Kics
#8 (permalink) |
Could be a sticking brake caliper piston which can cause the rotor to overheat causing warpage or leaving a layer of deposit. Thats what happened to me. On both front calipers nonetheless.
2003 Mazda 6s- Konis all around, Progress Rear Sway, Hid in Lows, EBC Ultimax Sport Rotos w/ EBC Redstuffs, PIAA 1000XT's, 225/45/17 Toyo Proxes 4's and Ecsta's, Cntinental Extreme Contitacts, MSDS headers w/Magnaflow spun metallic cat w/stock exhaust |
