Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Suspension / Brakes
Old 09-24-2009, 03:48 PM   #1 (permalink)
Mazdaspeed sway bar kit (front and rear sway bars) is served for only I4 2.3 L.
My car is I4 2.0, will it fit my car, any idea?
Thanks..
2006 Facelifted Mazda 6 AT I4 2.0 MZR 147 Hp Sedan
notyet is offline   Reply With Quote
Old 09-24-2009, 03:50 PM   #2 (permalink)
MrTea's Avatar
chassis is the same, size of the actual block is the same, so i don't see any clearance issues at all in that regard.
