Hi,
I would like to know if you have a Defi Blue Racer 52mm Boost Gauge in stock because I would like to order one early next week. Thanx
CP-E intake; CP-E inlet; CP-E FMIC; CP-E exhaust; CP-E catted DP; CP-E HPFP; GT2871R turbo; Steedspeed manifold; Tial 38mm wastegate; Turbosmart BOV; HKS ignition amplifier; HKS plugs; Saikou Michi OCC; SU radiator hose; TurbineTech front mount; CP-E rear mount; Kics oil drain bolt; Mazdaspeed oil cap; Greddy radiator cap; TWM short shifter; TurbineTech rear differential mount; F2 BS delete / OSB kit; Cobb shifter weight; CP-E Standback; CP-E ECU flash; Perrin EBSC; AutoEXE springs; Bilstein shocks; SPC ball joints; Whiteline rear sway bar; Enkei RPF-1; Yokoham S-Drive tires; Rays Engineering lugs; EBC Greenstuff pads; Stoptech rotors; AutoEXE antenna; DG CF splitters; JSPEC mirrors; SU black out emblem; Defi boost + EGT gauge; CP-E pod; AutoEXE CF shift knob; MSD DashHawk. |
![]() Join Date: Aug 2005
Remember they are debuting this very gauge in a perfect dash matching red at Sema in a few weeks...
(Not trying to take away sales Cullen )
2006 Mazdaspeed6 - Grand Touring w/ Moonroof - Black/Black- Click here to see it... 2005 Mazda6s - Fully loaded w/ every option but ATX - Steel Gray/Black (SOLD) - Click here to see it... 2006 Mazda6i - Sport package w/ Bose/Moonroof ATX - Dark Cherry/Black - Click here to see it... |
i just wish these things worked with the contol unit, i'd be all over them they did.
#4 (permalink) | |
<div align="center">cullen@streetunit.com | AIM: StreetUnitCullen | (321) 296-0777 | MAZDASPEED Owner & Addict ![]() MS6 Aftermarket Warehouse | Guide to Modifying Your MS6 |
