Brake caliper rebuild kits - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 12 (permalink) Old 11-21-2016, 03:14 PM Thread Starter
waughoo's Avatar
Quoted: 258 Post(s)
I'm upgrading to speed6 brakes on my regular 6 and want to refresh all the parts before i put them on. So has anyone got a solid source for caliper rebuild kits? I've found quite a few for the regular 6 but not the speed6. Also, even the dealer availability is sparse. And the price on their rear kit is crazy town expensive!! Any ideas?
Alex
waughoo is offline
post #2 of 12 (permalink) Old 11-21-2016, 05:52 PM
b1lk1's Avatar
Quoted: 214 Post(s)
Groans: 17
You have to change every single piece of the braking system to do a Speed 6 swap right. Speed 6 calipers are different from regular 6 calipers. The only thing the two cars braking systems share are mounting points.
Are you saying you have the Speed 6 stuff already or do you need to buy it? In general, Speed 6 stuff is expensive and much harder to find than normal 6 stuff.
2004 Mazda 6s 3.0 5dr. never ending money vacuum project:
b1lk1 is offline
post #3 of 12 (permalink) Old 11-21-2016, 06:32 PM
Quoted: 180 Post(s)
Hey Alex,
I have been thinking about doing this upgrade as well.
I checked rockauto and everything seems reasonable even if it is piecemeal in its approach.
Seems like you need to only replace rubber parts, hardware, and caliper pins
Piston and damper can probably be used as is don't you think?
I calculate about $8 - $15 each wheel.
Is there something I am missing?
Modifications:
DrFeelGood is offline
post #4 of 12 (permalink) Old 11-22-2016, 06:01 PM Thread Starter
waughoo's Avatar
Quoted: 258 Post(s)
I have a full set of front and rear calipers from a wrecked speed6 (and the larger donut spare tire to clear the larger rotors from the speed) and I want to refresh all the rubber service parts before I put them on the car. Thus, they would be like remanufactured calipers when I got done. I haven't extracted the pistons yet to see how the bores and piston look, but those usually survive well.
The problem I'm having is finding the correct kits. I have found some that have the seals and dust boot, but nothing for the guide pins. It is rather frustrating!
waughoo is offline
post #5 of 12 (permalink) Old 11-22-2016, 06:03 PM Thread Starter
waughoo's Avatar
Quoted: 258 Post(s)
You are correct. The rotors, calipers and caliper brackets. The other thing not mentioned is the donut spare. The regular 6 has a 16" spare and that won't clear the speed6 rotors. I got mine from a wrecked speed.
waughoo is offline
post #6 of 12 (permalink) Old 11-22-2016, 06:03 PM
b1lk1's Avatar
Quoted: 214 Post(s)
Groans: 17
Try Rock Auto. They have things that you can't get anywhere else it seems.
b1lk1 is offline
post #7 of 12 (permalink) Old 11-22-2016, 06:06 PM Thread Starter
waughoo's Avatar
Quoted: 258 Post(s)
Originally Posted by DrFeelGood View Post
Hey Alex,
I'm not sure I understand you here... the rubber parts are just to rebuild the calipers. The speed6 calipers and rotors are larger and thus the pistons and so forth are all different. A regular 6 calipers rebuild kit would not rebuild a speed 6 caliper.
waughoo is offline
post #8 of 12 (permalink) Old 11-26-2016, 04:26 PM Thread Starter
waughoo's Avatar
Quoted: 258 Post(s)
So it "LOOKS" like Rock Auto has the correct parts for the speed6 calipers. I had read in past forum posts that many suppliers said the parts were for a speed, but turned out to be for the regular 6. The cost for the rebuild kits is quite small so I'm going to risk it from rock auto and see what shows up. According to what they show on the website, the piston size is correct for the speed6 rebuild kit. Also the pictures of the slide pin bushings and hardware kit is correct in comparison to my speed6 calipers. Hopefully it will be!
Now, I just need to get the ghetto paint job cleaned off the caliper and find someone to zinc coat them for rust prevention and appearance. I'm a bit of a factory wonk when it comes to the presentation. I like my mods to look like they were shipped with the car. Plus, single piston calipers just don't look too sexy in my opinion. I just want them to be clean and fresh, but don't feel the need to call attention to them. I'm looking up sources now to see what I can find out. There's a guy here in my area that does caliper rebuilds and has a plating he uses (though different than zinc) that looks pretty sharp. I might go that route if he will just do the plating for me. I want the satisfaction of rebuilding them myself.
Alex
, and
waughoo is offline
post #9 of 12 (permalink) Old 12-29-2017, 08:58 PM
Quoted: 180 Post(s)
That Zinc CAD plating is quite nice.
Something like this?
Did you get those on yet?
Modifications:
post #10 of 12 (permalink) Old 12-29-2017, 11:41 PM Thread Starter
waughoo's Avatar
Quoted: 258 Post(s)
Yes... exactly that! I'm aiming for stock appearance so I'm not interested in paint. I still haven't got anywhere with them yet. I see them in my shop all the time and sigh a little sigh for my project. One of these days I'll plow into it and get it done. I plan to do the rear backing plate and right now, the mod for that is slowing me down.
Alex
, and
waughoo is offline
