Groaned at 5 Times in 5 Posts
Quoted: 209 Post(s)
Alright kids.
I've read so many posts about the dreaded rotor screws that even I started thinking they were made out of some uber-indestructo-type material. BAH & puh-lease. Here's the deal on rotor screws. They are soft metal and not worth your concern. Not even a little bit. As in under five minutes per corner to rotor on the ground. I approached mine knowing they were going to be stucker than shit. They didn't let me down either, laughing at my impact driver even (you can see indexing marks in the photos below, testament to that epic failure). I had classic screw removal bits, or drill bits that I could escalate to.... Well, no sense in screwing (chuckle...) around- directly to the 1/2 in drill bit, not new, but not abused either, and the ever classic battery drill. As it turns out, this method is so quick I didn't apply more than a few token taps with the impact driver on the other three corners. From first picking up the drill bit to the fourth rotor being removed was about fifteen minutes. Including the time spent taking the pictures seen below. Oh, and for the record, no, I didn't replace the screws. 1/2" drill bit > pot metal screws (lost one of them, darn it...) ![]() Bit on screw- ya know, in case there was some confusion on this part... ![]() Started- light touch on the drill till some of the head is removed. now that you have some meat to drill on you should lean into it a bit ![]() In just a moment you'll find the top of the screw head on your bit good sign, means your 75-80% done with that screw. ![]() ![]() ![]() In the above pic you can see the ring in a new rotor, showing us there is just a bit of screw left to remove. Back to the drill we go... "But..." you ask, "how do I know when to stop? How deep should I drill??" Trust me, you'll know. The rotor is a significantly different material. When the drill gets there it will sound different, feel different and the shavings will change from silver to dark gray. You will notice the difference. On the first one, about the time you start thinking "Hmmmm... That's different" you should stop drilling. Your removing the screw, not shaving weight from the hub. After a quick love tap from your favorite heavy, blunt object you end up with a freed rotor, easy peasy ![]() Nifty thing about math, and rotor screws, is that when you remove thescrew head & the rotor, there is no more tension on the threads so they just spin right out into your hand... Kinda neat considering... ![]() ![]() There ya have it- Brake Rotor Screws - done. No more mystery or confusion for all the folks who were dreading the prospect of replacing their rotors. In short- Try the screw driver even try the impact driver if you have one but don't hesitate to break out the drill. - so easy to do I'd spend the money on a new drill bit before I bought an impact driver. Drilling these eight screws takes only a few minutes
Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04
| The Following 10 Users Say Thank You to TiGraySpeed6 For This Useful Post: | Banditland (03-10-2012), blacksin (10-25-2011), Dooby (10-05-2010), friedricebob (02-21-2011), MATT DAMOND (08-18-2010), MazdaNeed4Speed6 (04-29-2012), Mitch41 (04-07-2013), MWSpeed6 (08-11-2010), SJP0tato (02-21-2011), xfeejayx (09-22-2010) |
| Sponsored Links | |||
Advertisement | |||
Quoted: 67 Post(s)
Thanks for the detailed pics and instructions. This will be very useful when I have to replace my rotors...
2007 mazdaspeed6 GT | titanium gray ![]() COBB AP, intake, TIP | Corksport FMIC | GrimmSpeed 3-port EBCS | KMD HPFP | CP-E inj seals | ATP 3" cat'ed DP | Magnaflow 2.5" CBE | SM OCC w/ check valve | EGR + VTCS delete | TB coolant bypass | JBR IM and TB gaskets | ITV22s | GP-WERKS BSD + oil pan baffle | TT rear diff mount + bushings, front engine mount | BC coilovers | SPC camber adj ball joints | JBR SSP, weighted shift knob. |
Groans: 5
![]() ![]() OH!!! ![]() ![]() ![]() ![]() A quick glance made it look like you had drilled a huge hole in your fender. LOL! |
| The Following 3 Users Say Thank You to Spazdog For This Useful Post: |
Is it even necessary to have these screws? I just ran into this problem, but my screws won't come out after drill off the head probably because of all the salt on MN roads. Once the wheel is holding the rotor on, I don't see why they're needed.
'07 Liquid Platinum Mazdaspeed 6 GT |
Quoted: 209 Post(s)
My understanding is that the screws were used to hold the rotors during manufacturing while the car was on the assembly line.
While they are a nice touch and do hold the rotor secure whenever the wheel is removed, they are not at all needed. Many, myself included, have elected to not replace them.
#7 (permalink) |
Groaned at 2 Times in 1 Post
Useful post, THX.. After the first time I had to drill these suckers out about 20+ years ago, I got in the practice of putting anti seize on these screws whenever I got a new car. Never had a bit of trouble since then.
No, these screws are not necessary, but they do keep the rotors from moving while you do pad or caliper changes. Last edited by TopazM3; 08-13-2010 at 11:17 PM. |
#8 (permalink) |
i just did this with the impact driver no trouble... need to use as big a hammer as you have and beat it like you hate it, but they came right out... less than 20 min new front rotors and brake pads.
#9 (permalink) |
I went through this exact thing while getting my brakes replaced. We tried taking them off the proper way, using screwdrivers and impact drivers. After a while, we said fuck it and got out the drill.
2007 Mazdaspeed6 GT Liquid Platinum |
#10 (permalink) |
+1 same here
2004 6s MTX/sport clutch/air box mod/de badged/ TB Coolant by-pass / TB Ground/6000K HID/ EGR Re-route/ 126,500( Nov, 2011)AWR 88D Rear mount my 6 http://forum.mazda6club.com/newbie-s...ml#post3307638 185.66/ 170@126k mi (Nov 5, 2011) |
Advertisement | |
