Last night a buddy and I installed Koni yellows in the front of my car and the SPC ball joints. Ball joints went in rather well, and so did the shocks. I followed the instructions listed on this site here. One thing is for sure the pipe cutter I bought at Lowe's is the best way to cut the shocks. It sure beats going after it with a hack saw. Per Koni instructions I cut the stock shocks off at 45mm instead of 50mm listed in the DIY. Like the DIY i had to drill out the spring perches to 1/2".
Shock adjustment is a snap. The adjustment knob is on top of the shock and accessible from the engine bay. I had it set at full firm for the ride home (about 40 miles). This morning I stepped it down one setting (half a turn) and it is still firm but a little easier on the highway. Next month the rear shocks go in... wish me luck. I hear they are a bitch. I have these paired with the RPM springs. When I put everything back together it seems that my ride height is higher than before. Should I wait for the springs to settle in before I get an alignment?
06 Speed6 GT- whitewater pearl w/ white and black leather and nav mods: ACT street clucth, ATP downpipe, AWR pass motor and tranny mount, CP-E cai, CP-E rear motor mount, CP-E catback, CP-E hpfp, CP-E FMIC, denso ITV-24 plugs, EBC redstuff brake pads, EGR delete, F2 BSD, HKS Twin Power Ignition, Koni Yellows, OCC, prosport boost gauge in vent pod, Rotara slotted rotors, PTP windage tray, RPM test springs, SPC ball joints, Synapse BOV, TT diff mount, TWM short shifter, whiteline rear sway |
#2 (permalink) | ||||
QUOTE (masskaos @ Sep 18 2009, 09:34 AM)
QUOTE (masskaos @ Sep 18 2009, 09:34 AM) Quote:
The adjusters usually have hysteresis, which means the direction from which you approach a setting is important too. Most people recommend always returning to full soft, then making the adjustment from there. QUOTE (masskaos @ Sep 18 2009, 09:34 AM) Quote:
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
Thanks for the info on the shock adjustments... I'll back it off to full soft then reset them. I'll be spending a lot of time using different settings. Hopefully I can find a good long drive setting and a good road carving setting.
The springs I have right now are the RPM test springs. They were the first ones that came out with the small drop. I think they call those the sport springs now.
^ Agreed, I just swapped out my Koni Yellow/K-Specs with BC Coils. I remember the rears being awful the first time around, but this time around they weren't that bad actually. Took no longer than 20 minutes to get the bracket unbolted, out, and replaced.
![]() Sponsored By: Soundwaves of Tampa | StreetUnit | Team SSP | Tranceologist Powder Coating <-- MySpace Page |
#6 (permalink) | |
QUOTE (RhoadBlock @ Sep 18 2009, 08:47 AM)
Thanks.
2007 MS6, Mazdaspeed CAI, Speedie TIP, RPM Sport Springs, Bilsteins, SPC Adj. Ball Joints, Whiteline Rear Sway Bar, AWR Endlinks, Corksport Frt Tower Brace, GT Spec Trailing Braces, CPE prototype MM, TT Frt Diff Mount, CPE Rear Diff Mount, Cobb AP, Dashhawk, Battery Relocate to trunk bracing. Wheels: Summer: OEM. Winter: Konig Feathers 17x7.5 +45 (17.1 lbs) w/ Yoko Ice Guard IG20 tires, Racing: BBS STI 17 x 8 +53 hub bored to 67.1 (18 lbs) w/ Yokohama Advan A048 235/45ZR17 R tires. |
#7 (permalink) |
I read somewhere that the konis are better shocks so if paired with the BCs they be perfect, and I replied but they are not height ajustable and never got a reply on that.
RENT FENDER ROLLER</span> CPE Standback - CPE catted DP to dual muffler CS mounts - CPE FMIC w/ OEM air dam & HKS BOV - mrlilguy CDFP - D N <span style="color:#4b0082">P - CPE CAI - speedie6 TIP - SU MM - TWM SS - TT Front MM - TT & CPE Rear Diffmounts - BC Coilovers - Brembo Front/StopTech & EBC Redstuff rear - F2 Baffle <strike>BS</strike> - <strike>VTCS & EGR</strike> - - 8.5x18et45 GM 57F's w/ 245/40 M3s / 18x8.5et45 Advan RZ GM w/ 245/40 Re01Rs - Passport 8500 X50 + LI Quad Laser Jammer - X50 mute button, Sub volume, LI swith & Dashawk custom mounted in steering column - EURO Tails - Rola Roof Rack - Prosport Boost gauge-Vent mount - TSX projector Retrofit - 55w projectors in fog retrofit - Carputer - CRX antenna w/ sat antenna mounted in front - Audison Dynaudio & Alumapro - Amsoil/Schafer Supreme |
#8 (permalink) | |
QUOTE (aviator79 @ Oct 29 2009, 05:40 PM)
I'm sure everyone knows that the OEM front shocks are themselves "coilovers", just not with height-adjustable bodies. The BC rears aren't coilovers at all, merely adjustable spring perches for their springs. Personally, I think everyone running a Speed6 would be better off running the Koni yellow Sports and their choice of spring to give them the height compromise they need/desire. I've found no one that actually competes with their car that changes the ride height for street/track use. When you change the height, it changes the toe and camber, so to be precise on the alignment needed for competition, you would need to align it each time as well. I think the "coilover" moniker leads people to buy them as the word is associated with replacing strut suspension econoboxes with performance parts. Otherwise it's just bling to say I have "coilovers" on a Speed6. Nothing wrong with that, but they really aren't for high-performance use....
`07 Speed6 Sport Titanium Gray w/Cobb TIP/SRI; ETS TMIC; CorkSport CBE & STB & RTB; OEM BPV; ATP DP w/HF cat; OEM turbo; Cobb AP; Perrin EBCS; KMD HPFP; F2 BSDw/baffle; SM Oil CC; Autometer vac/boost & DashHawk; Koni shocks; WL RSB; SPC Adj balljoints; 18x8 SSR wheels; 225/45 Z1 SS Dunlops; SU RearMM & RearStiff-Diff; TT FrontMM; 0-60 in 4.3 and 1/4 mile 12.96 @ 105.6 with ONLY 266awhp/310awtq is ok for now... Yeah, I really like Mazda... ZOOM! freakin' ZOOOOOM!
#10 (permalink) | |
QUOTE (Appman @ Feb 17 2010, 07:27 AM)
