Old 07-31-2009, 06:12 PM   #1 (permalink)
I have the H&R springs and love them, but they make like a rubbing noise at slow speeds after i installed them ive just ignored it. anyone know why?
also when i go over some big bumps or the car has been sitting for long the rear side makes a loud "thunk" sound.
any help would be great thanks!
2006 Pearl White Mazdaspeed6
CObb SRI/Forge Bypass Valve/TWM Stage 1/Prosport Boost Gauge/AEM Wideband/Prosport Volt Gauge/H&R Springs/18" Gunmetal Tenzo DC5 V2/Nitto Neo-Gens/Magnaflow Catback/VG Sharkfin/Eyelids/Denso Plugs
On Order: ATP DP/Cobb AP :-)
zixxspeed is offline   Reply With Quote
Old 09-28-2009, 11:50 AM   #2 (permalink)
MPSdriver's Avatar
QUOTE (ZixxspeeD @ Aug 1 2009, 12:12 AM)
any help would be great thanks![/b]
Apparently the rear damper only fits very tightly were it mates with the lower control arm. The H&R suspension was originally designed to work with the normal 6 (incl. wagon and 4wd versions) which has a different control arm and much more clearance around the pivot. I recently read about this problem on a German Forum (MPS6 - H&R Gewindefahrwerk). The OP of the thread in the link contacted H&R and apparently they acknowledge the problem (the pics speak for themselves) and are about to rectify the situation.
I found it pretty odd I didn't read about problems with these CO's on the 6club forum earlier but then again the tolerances for the OEM suspension parts are probably give and take some millimeters which means some will have the clearance issues with the H&R's and others might not. I was in the process of purchasing this CO-set and I do hope H&R puts the record straight on these!
edit: I just realized you only had the springs and not the shocks which makes the above info worhtless but oh well... still odd no-one complained about it before...
2006 Mazda6 MPS (80k+ miles)
Visual Garage Shark Fin Antenna Volk Racing 18x7,5 Progressiv Spoke (summer) Kei Racing 18x7,5 RSS (winter) TWM SS (stage2) MSD Dashhawk CPE Motor mount & Rear diff mount Remus Racing Cat back Redline Tuning Hood Quicklift Elite Stri Boost Gauge block8head Vent pod Autoexe TMIC HKS/CPE BPV 808speed6 preamp+eq H&R lowered suspension
MPSdriver is offline   Reply With Quote
