My car pulls very hard left (like at 80 mph you'd hit the guardrail in less than 1 second, literally).
I just learned of the TSB on here this week, (thank you all!), and I'm going to call the dealer tomorrow to have it checked out. Problem is, I'm getting some mods (SF + TIP + AP) in the next two weeks, and want to get this suspension business squared away first, as to not tip off the dealer if I have a major problem and need to "de-mod & unmarry" before the visit. Plus, the closest dealer is a douche, and didn't want to replace my clutch, but did only bc of all the great info you guys armed me with (special thanks to turbo6girl). I accelerate & corner hard (like most of you I'm sure), but not an autocross guys, etc... I'd be more worried about something going awry at the end of the 1/4 than anything else. That, and I noticed my tires are already down to 5/32 with only 4K miles. PLUS, I saw on the printout below, that the top says "Mazda : Mazda6 : 2003-07 : Wagon " ?? Going to a different dealer anyways. ![]() I thank you guys in advance for the input! It's been challenging trying to keep up with all great (new) info on here, you guys & girls ROCK! (btw, I have an 06 speed6 26K mi, I just liked the grill on the wwp6 in my avatar). Also, any advice on how to approach the dealer?
Cobb SF, CPE TIP, 3" GHL Dual Cat-Back Exhaust w/ Resonator, 3" SU Test Pipe, Denzo ITV-22 Plugs, Cobb AP~ Stage 2 + TIHSF 93oct map, TWM Stage II STS w/ Aluminum Bushings, SU Rear Engine Bone Mount, CPE Rear Diff Mount, SPC Ball Joints, Redline Fluids, Apexi Turbo Timer, Hyperdark Wheels, & 35% tint . I just flashed on the Stage 2 base map and now I gotta log some data ![]()
http://forum.mazda6club.com/index.php?showtopic=72653
Hey again! I'm trying to figure out the best alignment specs as well... My post #: 251
2006 MS6 black sport block8head's custom vent pod | Defi Red Racer imp. boost | Apexi TT | OEM RX8 Wheels | Strapped diff | SM OCC Kit |
#3 (permalink) | |
PS. Read through a similar thread, and still have a question for before I go to the dealer...
If the TSB applies, and the dealer fixes it, do I still ask them to set the following specs after the replacement parts are installed? Front camber: -1.2 deg +/- .2 deg Toe @ tire: .06" +/- .03" Toe @ tire: .14 deg +/- .04 deg Rear camber: -1.6 deg +/-.2 deg Toe @ rim(?): .06" +/- .03" Toe @ tire: .14 deg +/- .04 deg Thanks. I'd love to get in there today or tomorrow. QUOTE (cfdp @ Jul 31 2009, 05:48 AM) Quote:
"front and rear total toe-in at .09 deg +/- .04 deg ( .04" +/- .02" @ tire ). Rear camber of -1.6 deg MS6, and -1.1 M6 deg (spec targets), +/-.2 deg. [ Be clear about the toe spec units: degrees is typically used]" I wonder if the dealer will do this, or if I need to go to an alignment shop?
#4 (permalink) | ||
QUOTE (dougefresh_ @ Jul 31 2009, 12:18 AM)
I don't think the ridiculous rear cross-camber would be responsible for the hard left pull. Since the rear has camber adjustment, this can be easily remedied. I'm concerned about the caster and camber imbalance on the front. This suggests the possibility of suspension damage. Any chance the car was in a wreck previously? QUOTE (dougefresh_ @ Jul 31 2009, 09:07 AM) Quote:
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
#5 (permalink) | |
Thanks for the reply!
QUOTE (jd42 @ Jul 31 2009, 05:28 AM) Quote:
That's what the dealer said, and "I wouldn't worry about it at all." It was a returned lease with 22K miles on it when I bought it up last year from a Speed Dealer (out of state though). Car-Fax report I got when I bought it was clean, but now I'm worried. The only thing that's happened since I've had her is someone backed into my rear bumper in a parking lot (no note left, what a shock), leaving a 1/2" dent vertically along bumper, but insurance covered a new one (and thankfully I dropped my deduct to $300 when I bought it.. new bumper painted= $1250). Other than that, nothing.
