Old 07-08-2009, 05:49 PM   #1 (permalink)
I'm getting a strange wobble sound. I'm having a hard time identifying where its coming from, but it is definitely speed related, and doesn't change during acceleration/braking. It is most evident between 40-70 km/h and pretty much gone at over 100 km/h. At first I thought it might be wheel balance or tire issue, but there is *NO* vibration in either the brake, chassis or steering wheel.
Any ideas? Could this be a bearing issue? I can't hear any "humming", etc.
ncnmra is offline   Reply With Quote
Old 07-10-2009, 10:37 AM   #2 (permalink)
FORZDA 1's Avatar
QUOTE (ncnmra @ Jul 8 2009, 04:49 PM)
Any ideas? Could this be a bearing issue? I can't hear any "humming", etc.[/b]
Not much info here to go on, but as a guess, I would suspect the rear diff noise.
`07 Speed6 Sport Titanium Gray w/Cobb TIP/SRI; ETS TMIC; CorkSport CBE & STB & RTB; OEM BPV; ATP DP w/HF cat; OEM turbo; Cobb AP; Perrin EBCS; KMD HPFP; F2 BSDw/baffle; SM Oil CC; Autometer vac/boost & DashHawk; Koni shocks; WL RSB; SPC Adj balljoints; 18x8 SSR wheels; 225/45 Z1 SS Dunlops; SU RearMM & RearStiff-Diff; TT FrontMM; 0-60 in 4.3 and 1/4 mile 12.96 @ 105.6 with ONLY 266awhp/310awtq is ok for now...
Yeah, I really like Mazda... ZOOM! freakin' ZOOOOOM!
FORZDA 1 is offline   Reply With Quote
Old 07-10-2009, 11:45 AM   #3 (permalink)
QUOTE (FORZDA 1 @ Jul 10 2009, 06:37 AM)
Not much info here to go on, but as a guess, I would suspect the rear diff noise.[/b]
Can you point me to more information on this? Is this considered part of the powertrain (and therefore the powertrain warranty)?
It sounds like tires to me, and one weekend I'm going to try to put my winters on and see if it persists.
Old 07-10-2009, 01:35 PM   #4 (permalink)
FORZDA 1's Avatar
QUOTE (ncnmra @ Jul 10 2009, 10:45 AM)
It sounds like tires to me, and one weekend I'm going to try to put my winters on and see if it persists.[/b]
Yeah, could definitely be the tires. I can't remember where the thread is, but a quick test for the "common" diff noise is to pull the E-brake handle one or two clicks to see if the noise goes away. If it does, then the problem is likely the diff. When you pull hte E-brake, it shuts off the rear diff coupling....
Old 07-10-2009, 02:26 PM   #5 (permalink)
QUOTE (FORZDA 1 @ Jul 10 2009, 09:35 AM)
Yeah, could definitely be the tires. I can't remember where the thread is, but a quick test for the "common" diff noise is to pull the E-brake handle one or two clicks to see if the noise goes away. If it does, then the problem is likely the diff. When you pull hte E-brake, it shuts off the rear diff coupling....[/b]
Thanks! Its funny, because I was JUST going to ask if that would be a valid test. As soon as I get in the car again, I'm going to try this.
Old 07-21-2009, 08:35 PM   #6 (permalink)
mick_estes's Avatar
^^ Yup, e-brake is a valid method to disengage rear diff. "one click of ebrake and whine stopped" was all Mazda Tech needed to hear before they authorized my dealer to replace my rear diff under warranty. New diff fixed the whine at 45-50mph but since then I developed another whine at 75-80mph.
On the tire front, you might consider swapping out the wheels (if you've gone aftermarket). At about 15k miles on my current tires, I noticed an significant increase in noise which was similar to what you described. I rotated - no change. I got aligned - no change. Swapped back to near bald stock RE050A and noise went away. Shop says it's due to the aggressive tread and the wear. Not sure if that's the reason but there's no denying the noise followed the wheels.
<span style="color:#000080">2006 MazdaSpeed6 GT
* Installed (gray items temporarily removed for wty svc): Fujita CAI, SU Rear Motor Mount, <span style="color:#c0c0c0">ETS 3.25" TMIC, CX-7 Antenna, RPM Sport Springs, MB Boost (18x7.5 +48offset) w/Hankook Ventus Evo V12,Insane DIY CAI Splash Shield, SLS Test Pipe, Ghettospeed DIY Strapped Diff, MSD Dashhawk, SPC Adj Ball Joints, </span><a href="http://forum.mazda6club.com/index.php?showtopic=111609" target="_blank">Chiss DIY MP3 Adapter
</a>* Purchased but not installed: <waiting for more cash...>
* Future: (1) Cobb AP , (2) Whiteline RSB, (3) Turbine Tech Lower Rear Diff Mount, then...Who knows??? Upper Rear Diff Mount + Shocks (Koni Yellow or FSD) _or_ Catted DP _or_ Catback
</span>
mick_estes is offline   Reply With Quote
Old 07-22-2009, 10:18 AM   #7 (permalink)
QUOTE (MEE @ Jul 21 2009, 04:35 PM)
On the tire front, you might consider swapping out the wheels (if you've gone aftermarket). At about 15k miles on my current tires, I noticed an significant increase in noise which was similar to what you described. I rotated - no change. I got aligned - no change. Swapped back to near bald stock RE050A and noise went away. Shop says it's due to the aggressive tread and the wear. Not sure if that's the reason but there's no denying the noise followed the wheels.[/b]
Thanks for the tips. I tried the e-brake test and there was no change. So I decided to take off the wheels and put on my winters just to see if there was a difference. I basically removed one wheel at a time. My first pick (rear passenger) seemed to be the culprit. I decided to do a tire rotation (cross pattern -- I have the non-directional P-Zeros), and it seems to have greatly improved. Oddly enough, it seems like the every so slight pull I had in the steering wheel is gone now too. However, it doesn't appear that the tires are wearing improperly (to my "untrained" eye that is).
The tires themselves have a good deal of road noise that they push through, but the "wobble sound" is now gone. I'm obsessed with it now, so everything I listen for starts sounding like it, but there is a 100% marked difference from before. I think that the tire/wheel I suspected is slightly out of balance (or out of roundness). I'll go for a few miles and see if it changes. I might get the wheels rebalanced just for good measure.
Thanks again for all the advise!
Old 07-22-2009, 01:17 PM   #8 (permalink)
mick_estes's Avatar
^^Glad it worked out for you. I forgot to mention I got re-balanced a couple of times with no change. I wish I could try to cross-rotate but my tires are directional. I think I'll have to tolerate the noise for another few months until it's time to get new tires. Fortunately, they grip like crazy so the road noise is easy to forgive
</span>
Old 07-22-2009, 05:48 PM   #9 (permalink)
QUOTE (MEE @ Jul 22 2009, 11:17 AM)
^^Glad it worked out for you. I forgot to mention I got re-balanced a couple of times with no change. I wish I could try to cross-rotate but my tires are directional. I think I'll have to tolerate the noise for another few months until it's time to get new tires. Fortunately, they grip like crazy so the road noise is easy to forgive [/b]
MEE - I am in the exact same boat as you. I am running on Goodyear Eagle F1 A/S. They grip like glue, but the entire car started to vibrate at about 13,000 miles on the tires. The best way I can describe the vibration is as if I had full motor mounts (I used to have all four at some point and I just kept the rear one). The vibration/noise seems to get worse at it gets hotter outside, and living is Houston it is realy realy hot these days.
I have some Sumitomo HTR ZIII on order, hope that will make it all go away.
What tires are you riding on?
2006 Black Cherry Mica Mazdaspeed6 GT w/ navi & B&W Interior
Current Mods:
Engine: COBB AP (Stage 1 93 v101), MS CAI, Injen Prefilter (X1033), spark plug "coil stretch", Topfuel OCC baffled with steel wool, BSD and Baffle kit, CPE TIP, Diehard P1 Battery
Interior: STRI 60mm Mechanical Boost Gauge (center vent), DashDyno SPD, TWM Stage 1 short shifter and bushings
Drivetrain: SU MM, TT differential brace and upgraded bushigs, clutch pedal adjustment, RL MT90 in MTX, RL 75W90 in TC and RD
Suspension: Whiteline RSB, SPC Adj Ball Joints, RPM Sport Springs, Bilstein Shocks
Exterior: CX7 stubby antenna, Mazda Moonroof wind deflector, Sumitomo HTR Z III 225/45/18.
Dealer visits: Clutch TSB, HPFP TSB
Future Mods: Upgraded TMIC
HoustonSPD6 is offline   Reply With Quote
Old 07-22-2009, 05:58 PM   #10 (permalink)
^^^ If you're asking me, I have Pirelli P-Zero Nero M+S. I think MEE has the same tires as you (or similar) -- check out his sig.
