Ok, here is the dealio.
I have RX8 Wheels with 225/45/18's for my summer setup. I have MS6 Stock Wheels with 225/40/18's for my winter setup. I plan on getting the Eibach Pro Kit Springs (So far I like these best) and I know I will need an alignment afterwards. My question is: Will the new alignment only be good for the summer setup, or do I have to get an alignment everytime I switch from summer to winter? Springs will stay on all year round. Might be a stupid question, sorry if so, never done springs before. Thanks!
2009 G8 GT Magnetic Gray Metallic 350whp/362wtq Mods: Borla CBE | Roto Fab Intake | HSRK | 35% Window Tint | Tinted Side Markers | 35W 6000K HIDs | Kooks 1 7/8 Mid Length Headers | Livernois Tune | Tinted Tails | UPR Billet Catch Can | GXP Diffuser | Ported Intake Manifold | SLP UDP | Black Kidney Grills Summer: 19" Forgestar F14 Matte Black/Invo F: 19x8.5 245/40/19 R: 19x10 275/35/19 Winter: 18" VMR VB3 Hyper Black Wheels/Blizzak LM25 Track: 17" WS6 Wheels/MT ET Street Radials |
#2 (permalink) | |
QUOTE (Rawyzf @ Mar 23 2009, 01:50 PM)
Now, if you switch to radically different wheel offsets or tire sizes, there may be a performance advantage to adjusting the alignment specifications accordingly. The offsets of the wheels you are using are only 5mm different, and the tire sizes are almost the same, so this wouldn't apply in your situation. Also, if your roads are a rough as the ones around here, checking the alignment seasonally might be a good idea. But, that's only because the bumps and potholes can knock the alignment out, not because of a change in the tires and wheels.
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
#3 (permalink) | |
QUOTE (jd42 @ Mar 23 2009, 01:18 PM)
Great, thanks for the reply. Exactly the info I was looking for. Any idea on what a shop would charge to install springs? I know alignments run around $100-$120.
#4 (permalink) | |
QUOTE (Rawyzf @ Mar 23 2009, 02:22 PM)
I think Sears does alignments for $60 or $70. For the $100+ range, I would hope you are getting a specialized custom alignment. If you are ambitious (and patient), you can also do the alignment yourself: http://forum.mazda6club.com/index.php?showtopic=108096
#5 (permalink) | |
QUOTE (Rawyzf @ Mar 23 2009, 11:22 AM)
2006 Mazdaspeed 6, Liquid Platinum Metallic, COBB SFI and AP Stage 1+, GHL Dual Catback Exhaust, RPM Street Springs, Streetunit rear Motor Mount, Audiolink MP3 input, sharkfin antenna, 18" Enkei EVO 5 wheels with Goodyear F1 Allseason tires 225-40-R18. On factory turbo #2... |
#6 (permalink) | |
QUOTE (priceprince @ Mar 23 2009, 03:19 PM)
#7 (permalink) | |
QUOTE (Rawyzf @ Mar 23 2009, 04:22 PM)
![]() ohh and BTW unless you put SPC adjustable Ball joints in.... what ever the number is is what you get. edit***heres the link to the alignment writeup http://forum.mazda6club.com/index.php?showtopic=72653
----------------------------------------------------- 2007 MS6 Black Mica Sport, 4 oz shifter weight, CX-7 antennea, ProSport 52mm boost gauge, Vent pod, megan v6 springs, ATP TIP, CP-E Xcel CAI, Forge BPV, Custom Fab TP, shift knob personally machined by ME , CF shift boot / ebrake boot
#8 (permalink) | |
QUOTE (matchingsilver @ Mar 23 2009, 07:21 PM)
#9 (permalink) |
i have the eibach pro kit. definitely love it. i am workin on getting an alignment done because my friend works at Firestone but he has yet to come through for me. I got my spring from Drivewire.com. check their they have some cheaper stuff
--AEM CAI--Corksport DownPipe--Forge Motorsports BPV--Denso ITV22--Eibach Pro Springs--Cobb TIP--AWR MM--Corksport Race Pipe--Glowshift Boost Gauge--TWM SS--Redline Quick Lift--Tinted Side Markers--VG Sharkfin--10000k D2S--2700k Fogs-- 13.3 @ 99.7 |
#10 (permalink) | |
QUOTE (a7x813 @ Mar 23 2009, 11:23 PM)
Cool, thanks. SU is a few bucks cheaper, so I'll probably order from them. LBV sent me his specs, he is also on this kit, but he has the SPC Adjustable Ball Joints, so it may be a little different. I am gonna try to use those specs though when I get them installed.
