Lessons Learned:
Simple does not mean easy. Easy does not mean correct. Correct does not mean perfect.
![]() 2007 Liquid Platinum Mazdaspeed 6 Currently Installed: Sharkfin | Forge BPV | TWM Stage 2 SS | Dashhawk | COBB Accessport Stage 1+ | Speedie's inlet pipe | Cobb SRI | Magnaflow Exhaust | H&R Springs | Bilstein HD Shocks | SPC Adjustable Balljoints | Cobb Shifter Weight | RX-8 Wheels w/ 225/40-18 Goodyear GS-D3 Tires Selling: Fujita CAI, DSM 1G BOV Future Possibilities: who knows... |
![]() Join Date: Feb 2008
I guess I'm lucky 'cause we have a local shop that is known statewide for their alignments. They actually drive the car first then put it on the machine to see where it's at and discuss anything they noticed during driving. They then set the specs to what it should be or what you want and you can watch if you prefer. I saw them move around while he was adjusting, but when it was all said and done he shook the car a bit and it settled back in where it was set to. They took it out for another drive and thru it back on the machine for one more check and then discuss what they think it needs or if it's done. $92 ish after taxes and he was impressed with the settings I asked for. Didn't care for the SPC balljoints though and said to watch them for slipping. Haven't had any yet though.
#4 (permalink) | ||
QUOTE (knyghtryda @ Dec 31 2008, 03:51 AM)
QUOTE (knyghtryda @ Dec 31 2008, 03:51 AM) Quote:
I like you summary. Alignments are definitely a very difficult thing to get right, and patience is very important.<div class=\'quotetop\'>QUOTE (jmhinkle @ Dec 31 2008, 08:39 AM) <div class=\'quotemain\'>Didn't care for the SPC balljoints though and said to watch them for slipping. Haven't had any yet though.[/b][/quote] <span style="color:#FF0000">I have noticed the ball joints need re-torquing a couple of times after completing an alignment. After driving 50 miles or so, I was very surprised how much they had loosened. I recommend checking them each day for at least three days to ensure they don't start to slip later and screw up a careful alignment. Details: For those curious about my alignment method, here are the details. Since caster isn't adjustable, I stick to camber and toe. Caster can be measured using the same setup, but it is rather involved. First order is to get the car level. I use a 4-way line level I made from clear tuning and some tees, filled with colored water. One end is taped to each wheel hub and squares of wood and cardboard are added under each tire until the water level is the same at each wheel. I use a couple of sheets of smooth plywood with grease between them to ensure the suspension can settle properly without the tire "binding" to the ground. This process can take up to an hour by itself. I measure camber at all 4 wheels using a plumb bob and a precision ruler. I measure the difference in distance between the rim and vertical string at top and bottom. Combined with the rim diameter and some trigonometry, the camber angle can be calculated. (The sine of the camber angle equals the ratio of the spacing difference to the rim diameter.) Toe is simple to measure once I set up some strings parallel to the car at wheel hub level. The trick is that the two strings must be parallel to each other and parallel to the center line of the car. This can be determined by matching the string spacing to the rear hubs on each side and the spacing the the front hubs on each side. Combined with measurements from string-to-string at the front and rear, there are six measurements (3 pairs) that need to be matched. Once these are correct, toe can be checked by measuring the spacing from the string to the front and rear rim edges.
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
#5 (permalink) | |
QUOTE (jd42 @ Dec 31 2008, 10:32 AM)
`07 Speed6 Sport Titanium Gray w/Cobb TIP/SRI; ETS TMIC; CorkSport CBE & STB & RTB; OEM BPV; ATP DP w/HF cat; OEM turbo; Cobb AP; Perrin EBCS; KMD HPFP; F2 BSDw/baffle; SM Oil CC; Autometer vac/boost & DashHawk; Koni shocks; WL RSB; SPC Adj balljoints; 18x8 SSR wheels; 225/45 Z1 SS Dunlops; SU RearMM & RearStiff-Diff; TT FrontMM; 0-60 in 4.3 and 1/4 mile 12.96 @ 105.6 with ONLY 266awhp/310awtq is ok for now... Yeah, I really like Mazda... ZOOM! freakin' ZOOOOOM!
#6 (permalink) | ||
QUOTE (FORZDA 1 @ Dec 31 2008, 12:34 PM)
The downside of this method over the fancy machines is the time involved, but I'm a big fan of DIY techniques and not having to rely on others. At some point I should create a nice writeup of this method with some diagrams so others might be encouraged to try it. QUOTE (FORZDA 1 @ Dec 31 2008, 12:34 PM) Quote:
#7 (permalink) |
wow bro haha. when i brought my car to the place that fixed it after my accident. they used the same machine. i had EXACTLY -1.3/-1.5 F/R and the exact toe in i asked for. they never fail to impress me. total cost was 90 bucks
2006 Mazdaspeed 6 GT Black Mica #4126 GT3076R BITCHES ~ TXS BOV ~ Custom 3" MAF SRI w/ giant AEM filter ~ AP PROtune'd ~ MBC ~ Custom Side-to-Side FMIC w/Treadstone TR8 Core ~ CPE DP ~ DNP Mani w/Tial 38mm MV-S EWG VTA'd~ CPE BT TIP ~ TWM Stage 1 Short Shifter ~ CPE RMM ~ TTFMM ~ CPE RDM ~ BC CO's slammed ~ SPC BJ's ~ EBC Red's ~ Stoptech's ~ Technafit SS Lines ~ Autometer Boost & STRI EGT in Custom Built Vent Pod ~ 20% Tint ~ LED Tails ~ Denso ITV-24's ~ Xtra Shorty Antenna ~ Dashhawk ~ CPE Dual CBE ~ Custom Strut tower bar ~ Whiteline RSB ~ PnP'd IM ~ CDFP Internals ~ labonte meth kit ~ VC tapped OCC ~ 320WHP/385WTQ ~ 12.9 @ 107 1.8 60' ~ fastest stock turbo trap speed in the USA |
#9 (permalink) | |
QUOTE (jd42 @ Dec 31 2008, 04:58 PM)
