Old 03-13-2007, 08:14 PM   #1 (permalink)
slospeed6's Avatar
Anybody have any experience with the SPC Camber Adjustable Ball Joints from found here:
http://www.therpmstore.com/product_info.ph...25fc5f130cce5e9
I LOVE HOVER ADS - YEAH!!!!
slospeed6 is offline   Reply With Quote
Old 03-13-2007, 08:26 PM   #2 (permalink)
barberjohn's Avatar
Send a message via AIM to barberjohn
I saw those the other day as well. I would think that adjusting the camber more negatively on this car would greatly increase our handling characteristics, but I'm just not $180 sure.
'06 Black Mica Speed6 GT</span>
ATP turbo-less
13.0 @ 105 MPH
If you live in or around the Carolinas then check out <span style="color:#FF0000">Carolina Mazdas
. Meets are scheduled monthly.
barberjohn is offline   Reply With Quote
Old 03-13-2007, 11:28 PM   #3 (permalink)
falcontx's Avatar
Send a message via AIM to falcontx Send a message via Yahoo to falcontx
Lots of discussion about these here:
http://forum.mazda6club.com/index.php?showtopic=66965
In short, adding 1-1.5 degrees of negative camber does wonders for the car!
Are you one of our valued, satisfied, and/or devoted customers? -- Get your banner here!</span>[/b]
falcontx is offline   Reply With Quote
Old 03-14-2007, 08:47 AM   #4 (permalink)
Stretch's Avatar
That's awesome. EVERYONE should buy these.
Stretch is offline   Reply With Quote
Old 03-14-2007, 10:22 AM   #5 (permalink)
In short, adding 1-1.5 degrees of negative camber does wonders for the car![/b]
I'm still waiting for a complete coilover solution to arrive with adjustable camber plates on the top end of the shocks. I'd wonder how durable adjustable ball joints would be in the log run; i.e. would they be prone to sag or become loose at the camber pivot over time.
klash2000 is offline   Reply With Quote
Old 03-14-2007, 10:41 AM   #6 (permalink)
Stretch's Avatar
I'm still waiting for a complete coilover solution to arrive with adjustable camber plates on the top end of the shocks.[/b]
What would these "camber" plates do?
Old 03-14-2007, 11:22 AM   #7 (permalink)
flyingm's Avatar
I'm still waiting for a complete coilover solution to arrive with adjustable camber plates on the top end of the shocks. I'd wonder how durable adjustable ball joints would be in the log run; i.e. would they be prone to sag or become loose at the camber pivot over time.[/b]
You might be waiting a while... going from double-wishbone to macphearson is going to take quite a bit of engineering.
'06 Speed6 CPE CAI, CPE Cat-Back, HKS SSQV, 17x8 Kosei K1TS with 245/45/17 Michelin PS2, Rotora slotted front & rear, EBC Redstuff pads front & rear
flyingm is offline   Reply With Quote
Old 03-14-2007, 12:48 PM   #8 (permalink)
slospeed6's Avatar
You might be waiting a while... going from double-wishbone to macphearson is going to take quite a bit of engineering.[/b]
Yeah that ain't gonna happen in our lifetime.
I think I'll go for these once I figure out what kind of shocks to go with - at this point it's either Koni Yellows or wait for something from Bilstein.
I would prefer to have the work done at the same time since it involves basically the cracking the upper ball joint open for either install.
Old 03-14-2007, 02:21 PM   #9 (permalink)
Yeah, Kforce sent me a mail when I asked about a camber adjustable CO solution, from the mail:
1. I have no idea, that is a question for eibach
2. id is 62mm, length is 180mm
3. shocks will “handle” any spring rate, but the valving will dampen properly up to a 2kg change.
4. since ride height is adjusted with the lower mount and not the spring perch is has no relation to ride quality.
5. front is camber adjustable.
6. installation depends on the person installing, easy for some, hard for others.
Thanks,
Ksport Suspension Company
info@ksportusa.com
I was assuming that they would have a top mounted camber plate like in a macphearson set up, maybe it's else where in the solution, not sure where else it could be though....
To the person who asked what does a camber plate do, simple answer is that it allows you to move the entire suspension geometry (i.e. the shock and spring) +/- as far as camber. from my POV it seems this would be MUCH more durable than trusting a ball joint to handle all the load of a camber change.
Old 03-14-2007, 02:54 PM   #10 (permalink)
Thanks,
info@ksportusa.com
To the person who asked what does a camber plate do, simple answer is that it allows you to move the entire suspension geometry (i.e. the shock and spring) +/- as far as camber. from my POV it seems this would be MUCH more durable than trusting a ball joint to handle all the load of a camber change.[/b]
You are missing the whole point. We don't have struts up front so you can't adjust camber by using camber plates mounted on the strut towers like you are saying. Double-wishbone. You're going to have to be content with a balljoint - trust us it'll be fine.
"NASCAR is the Bose of auto racing. Makes a lot of money but ain't worth crap"
2006 Black Mica Mazdaspeed 6 Sport
2003 Vibrant Blue Sentra SE-R Spec-V - R.I.P 1/11/07
Auto-X fun
Gandalf is offline   Reply With Quote
