First gear staying slightly engaged? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Mazdaspeed6 > Speed6 Engine/Drivetrain
New User? Register
Old 01-22-2013, 05:55 PM   #1 (permalink)
Default First gear staying slightly engaged?
I recently bought a 2006 speed6 and loving it! But one thing that i noticed when starting my car in the morning (or after it's been parked for a period of time) is after starting and putting it in neutral to idle, it feels like first gear remains engaged and rolls forward slightly. I've had other manual transmission cars and never had a problem, even on extremely cold days. I took it back to my dealer and had them look at it but they couldn't replicate the problem... Does anyone have any insight into what could be the problem?
Case6 is offline   Reply With Quote
Old 01-22-2013, 10:25 PM   #2 (permalink)
jm211's Avatar
Quoted: 79 Post(s)
Welcome!
Ok, to get a bit of clarification which of the following is correct:
Clutch pedal depressed, and shifter in 1st gear. Car moves a little
Clutch pedal NOT depress, and shifter in neutral. Car moves a little
Black Mica 2006 Speed6 GT | 57,000 Miles
Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals
I'm Registered. Are You? Ms6db.com
"I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..."
-TiGraySpeed6
jm211 is online now   Reply With Quote
Old 01-23-2013, 01:16 AM   #3 (permalink)
Thanks! Ok, I depress the clutch when I start my car with it in first, put it in neutral, release the clutch, and it moves slightly. Also noting that when I release my clutch in neutral, my rpm's drop like it would if I were starting in first gear. Hope this helps! Tomorrow I'm going to record a video on my phone to help clarification
Old 01-23-2013, 07:50 AM   #4 (permalink)
TiGraySpeed6's Avatar
Groaned at 5 Times in 5 Posts
Quoted: 229 Post(s)
Only do this on cold starts?
Cold where you are right now?
Mazdaspeed6 GT #3476 TiGray slicktop
bolted & tuned by my own hand
405/394 AWD - cf1.01 BNRs3
315/372 AWD - cf1.01 k04
TiGraySpeed6 is online now   Reply With Quote
Old 01-23-2013, 11:15 AM   #5 (permalink)
Final Impact's Avatar
Quoted: 194 Post(s)
The trans has an abundance of parasitic drag from all the shafts with gears spinning on them. Its normal for cold thick oil. You could dump it and replace with Synthetic. That's part of the reason 100% of your Crank Shaft HP doesn't make it to the ground!
FWIW: that is just another bit of insight about the importance of SLOWLY warming up ALL of the drive train together when its cold out. i.e. not hammering on the gas 2 blocks down the road because you let the engine warm for 7 minutes while the trans and diff are stone cold still.
>79,000
evolution99 (01-23-2013)
Old 01-23-2013, 03:50 PM   #6 (permalink)
My car does the same thing on cold mornings(below ~30F in the garage). As others stated, normal. I even have the Ford tranny fluid in mine and it still does it. I use my e-brake almost every time I park the car, so I don’t normally notice the “lurch” forward, but I have experienced it. The RPM does drop a little when I let out the clutch in neutral when the car is cold(with e-brake on), but same reason as the car lurching.
I also agree with Final Impact. Just because the engine is warm, doesn’t mean everything else is warm…especially drivetrain parts if the car was just idling. The crappy part for me is that the freeway is a 2 block drive from my work parking lot(and I’m too impatient to take the side roads). It was a cool -5F when I left work on Monday. I could really feel the thick oils in the diffs and tranny once I started moving, felt like the brakes were dragging. I should have taken the side road up the next block, but I didn’t(impatient).
Odrapnew is offline   Reply With Quote
Old 01-23-2013, 04:04 PM   #7 (permalink)
Yes only on cold starts or if i park my car for more than an hour or so. I live in Wisconsin and it was 0F to 6F degrees yesterday and about 16F degrees today.
So it's normal then for my tranny to do this when it's cold? Not saying it doesn't make sense, just seemed a little odd. If I went to full synthetic would it still lurch or just not as bad? Thanks for the info though!
Weird, so it's not just me this is happening too. I feel a little better about it now ha. I usually just park with my car in first gear without the E-brake applied if it's below 30F so it doesn't freeze in place ( I've had this happen before... go Wisconsin) so I notice the lurch more I guess
Old 01-23-2013, 05:24 PM   #8 (permalink)
jm211's Avatar
Quoted: 79 Post(s)
I agree.
My cars starts. I hear my VVT. my RPM starts at 2.2 k RPM.
If I pump the clutch my RPM's will drop 200rpm (per the gauge) every time I pump the clutch.
I would expect it to move a little as there are rotating masses all over the place.
Luckily I'm in florida and only have to deal with 50* weather at its coldest. BUT I'll be moving back to wisconsin so bring it on!
-TiGraySpeed6
Old 01-23-2013, 07:15 PM   #9 (permalink)
Quoted: 194 Post(s)
Not that this applies - to you guys but ATX do it even worse. Some will move the car a good distance with tight clutch packs and cold fluids. My six speed ATX does it against the park pall. I'll drop into N and see what it does. Yes, Temp effects the fluids! On the yamaha forum for the bike, the Newbies cry when they drop it into gear as the bike JUMPS! lol << IS this normal?? haha! Yep, but even with synthetic, its still has drag.
Think of this: Stopped with the trans in N, you have about 6 to 7 gears spinning at different speeds in the main and cluster gears, plus the revers gears all while the output shaft is stationary.
Picture compliments of: @CanyonRider
Here we are with the shift forks and shift rods removed:
>79,000
The Following 3 Users Say Thank You to Final Impact For This Useful Post:
Case6 (01-23-2013), jm211 (01-23-2013), TiGraySpeed6 (01-23-2013)
Old 01-23-2013, 11:13 PM   #10 (permalink)
Awesome thanks to everyone that responded! Helped shed some light on what was going on
