Odd shift into 2nd - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Mazdaspeed6 > Speed6 Engine/Drivetrain
New User? Register
Old 12-25-2012, 04:56 PM   #1 (permalink)
Emew's Avatar
Quoted: 56 Post(s)
iTrader: 2 reviews
Default Odd shift into 2nd
Just curious if anyone else had experienced something like this. My speed came with a short shifter when I got it. Whenever I shift into 2nd from 1st, I feel a literal rumble in the shifter. It does go into 2nd and go but it's definitely a bit resistant. This applies to both 3k rpms and 4.5k, both times clutch fully depressed, no gas. All input appreciated!
Sent from my dial up phone
Flow Tuned
'07 Speed6 Titanium Grey: SURE SRI+TIP in Designer White, CX-7 OEM Antenna, ProSport Boost Gauge, Block8Head's Custom MS6 Pod, Cobb AP, Denso ITV22 1SC Plugs, TWM Short Shifter, Stage 2 Clutch, SURE Shortcut+Countershift Weight, JBR EGR Delete, Euro LED tail lights, AutoTech Fuel Pump Internals, JBR RMM, M2 DP.
(Pending Installation)
JBR Shifter Bushings, Spring Flow Tune Stage 2.
Emew is offline   Reply With Quote
Old 12-25-2012, 05:00 PM   #2 (permalink)
ctmazda's Avatar
Quoted: 193 Post(s)
Do you have a short shifter plate (SSP)?
Sent from my iPhone using AutoGuide.com App
2004 Mazda 6 Sport V6 MTX-Steel Grey
MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18
Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils
ctmazda is online now   Reply With Quote
Old 12-25-2012, 07:54 PM   #3 (permalink)
Emew's Avatar
Quoted: 56 Post(s)
iTrader: 2 reviews
To be honest because I didn't install it and it came with it, I have no idea. Best way to find out?
Flow Tuned
Old 12-25-2012, 11:07 PM   #4 (permalink)
MATR6's Avatar
Quoted: 17 Post(s)
Did you open it up & see if the short shifter plate is loose?
The bolts on my TWM SS comes loose after a few months.
'07 Speed6 GT LPM #8903
AutoExe Low Down Springs | Billstein HD | CARLED Tailights | Mazdaspeed OC | Redline Goods SB | TWM Stage 1 SS & Bushings | XCarlink | Enkei RS5 18X7 42mm offset | 225/40 Hankook Ventus V12 EVO K110
MATR6 is online now   Reply With Quote
Old 12-26-2012, 06:59 AM   #5 (permalink)
jm211's Avatar
Quoted: 79 Post(s)
Its over the Transmission FYI.
It will be noticeable aftermarket. Do you clunk or hear anything when you shift into quickly?
If thats all good, May I suggest taking a look at your mounts? (transmission and rear)
A SSP will lead to harder shifting in all gears. This is offset by a heavy shifter knob and/or 20 minutes of weight lifting, everyday, for 4 weeks.
Black Mica 2006 Speed6 GT | 57,000 Miles
Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals
I'm Registered. Are You? Ms6db.com
"I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..."
-TiGraySpeed6
jm211 is online now   Reply With Quote
Old 12-26-2012, 08:48 AM   #6 (permalink)
Emew's Avatar
Quoted: 56 Post(s)
iTrader: 2 reviews
No clunking and it's not the kind of resistance of lack of muscle lol. It's literally like I hit something, feel it rattle for a second then it goes in. almost like an incorrect shift rumble except not as rapid nor do you hear that grinding sound at all. Might mention it to the mechanic to check out if it's ssp
Flow Tuned
Old 12-26-2012, 10:10 AM   #7 (permalink)
ctmazda's Avatar
Quoted: 193 Post(s)
I hear some SSP's will cause your shifter linkage cable to rub on something it's not suppose to in certain gears, which sounds like it could be causing the resistance feeling you are describing. Might want to check that out.
Old 12-26-2012, 12:27 PM   #8 (permalink)
Emew's Avatar
Quoted: 56 Post(s)
iTrader: 2 reviews
Friend of mine and I are going to take the shifter apart and see about the linkage cable, also he said oddly enough that he thinks it might be brake fluid. Said there's a correlation between low break fluid and resistance to shifting. He gave me a more technical reasoning but I can't recall right now. I'll update after that whole project goes down. Checking that out, putting in boost gauge, and going to some ITV22s all in 1 day. Oh what fun will be had!
Flow Tuned
Old 12-26-2012, 01:56 PM   #9 (permalink)
oh_yeams6's Avatar
Groans: 6
Groaned at 4 Times in 4 Posts
Quoted: 141 Post(s)
iTrader: 14 reviews
Your slave uses brake fluid.
Definitely take a look at the shifter and use some loc-tight
oh_yeams6 is offline   Reply With Quote
Old 12-26-2012, 03:27 PM   #10 (permalink)
6erforlife's Avatar
Quoted: 46 Post(s)
Try taking apart your center console and adjusting the linkage. I've done it a few times to try and get it right. 2nd seems to be an issue for some people, including myself until I played around with it
HOW TO: Fine tune Shifter
Your SSP would be underneath the intake. You probably can't miss it if it's aftermarket
Liquid Platinum 07 Speed 6 #10177
JBR 80duro RMM, Sure Juggernaut, Sure Dreadnaught
Cobb AP, HTP3.5" Intake, Streetunit TMIC, M2 DP, TurboSmart BOV, Grimmspeed EBCS, AT Internals, GP Werks BSD & Baffle, Denso ITV22, TWM Stage 2, Dashhawk, JBR OCC, JBR TB TIG, SURE IM TIG, VTCS Delete, Clean Valves!
LED tail lights, 20% tint, EVO X rims and VG Sharkfin
Soon to be installed: Ford Transit Oil Filter Conversion
6erforlife is offline   Reply With Quote
