Quoted: 56 Post(s)
iTrader: 2 reviews
As per the title says, I got my SRI+TIP installed and notice when I'm in neutral and rev to say 4-5k I hear a pop. We're talking like if you were to shoot off a cap gun style pop..
Any input? My first assumption was a missfire.
![]() Flow Tuned '07 Speed6 Titanium Grey: SURE SRI+TIP in Designer White, CX-7 OEM Antenna, ProSport Boost Gauge, Block8Head's Custom MS6 Pod, Cobb AP, Denso ITV22 1SC Plugs, TWM Short Shifter, Stage 2 Clutch, SURE Shortcut+Countershift Weight, JBR EGR Delete, Euro LED tail lights, AutoTech Fuel Pump Internals, JBR RMM, M2 DP. (Pending Installation) JBR Shifter Bushings, Spring Flow Tune Stage 2.
| Sponsored Links | |||
Advertisement | |||
Quoted: 79 Post(s)
Pop from exhaust? pinging sound?
Does it do it during normal driving? I guess we need to find out if its detonation or pre-ignition. Did you unplug the battery after you installed the tip? (i would assume you have too)
Black Mica 2006 Speed6 GT | 57,000 Miles Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals I'm Registered. Are You? Ms6db.com "I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..." -TiGraySpeed6 |
| The Following User Says Thank You to jm211 For This Useful Post: | Emew (11-21-2012) |
Quoted: 56 Post(s)
iTrader: 2 reviews
Unplugged battery, ecu is reset. It's perfectly fine driving, thinking rev limiter or the fact the ecu doesn't have a mix ratio in mind yet and it might be running rich on revs.
Sent from my dial up phone
Groans: 5
Groaned at 8 Times in 7 Posts
Quoted: 214 Post(s)
it's just afterfire
2006 BCM MS6 GT #00584
CP-E 3" Straight Pipe Exhaust. CP-E TMIC. CS SRI/TIP. SU RMM. SU TP. Forge V1 BPV. Cobb AP. RichTuned. Denso ITV22. PTP HPFP Internals. STi S204 Lip. Megan Racing Springs. GenPu MS3 Wheels. VEI Boost Gauge with Block8head pod. Blox Shift Knob. VG Shark Fin. 35W 8000K DDM HID lows/3000k fogs. Super White LED Tag Lights, Parking Lights, Interior Lights. SOLD: 2009 Mazda 6i GT. Comet Gray Mica. 6-speed MT. ![]() |
| The Following 2 Users Say Thank You to 6Y MAZDA For This Useful Post: | IHeartGroceries (11-21-2012), Rainmens (11-20-2012) |
Quoted: 4 Post(s)
that's your car suggesting you get a Honda if you want to act like a ricer
![]() "When you can leave black marks from the exit of every turn to the braking points of the next turn, then you have enough horsepower." "Oversteer is when you hit the wall with the back of the car. Understeer is when you hit the wall with the front of the car. Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it." 06 Black Cherry Mica Speed6 |
| The Following 2 Users Say Thank You to Road Rage For This Useful Post: | GroceryGetter (11-23-2012), Rainmens (11-20-2012) |
![]() Join Date: Jan 2007
Groaned at 6 Times in 6 Posts
Quoted: 65 Post(s)
Unburned hydrocarbon reaching auto-ignition temp from hot exhaust gases in your exhaust manifold, or even after, and combusting. Like small explosions...
Your ECU is probably like, "HOLY FUCKING SHIT, WHAT IS ALL OF THIS AIR, BITCHES?! BETTER ADD MO FUELZ!" |
| The Following 4 Users Say Thank You to IHeartGroceries For This Useful Post: |
#7 (permalink) |
Groaned at 5 Times in 5 Posts
Quoted: 229 Post(s)
Lol, but, yeah, that ^^^^^
I'm betting your MAF Cal / fuel trims are freaking out. That happens when you make a drastic change like increasing available air substantially, then immediately rev it in neutral to check out the new awesomes before the ECU has a chance to learn & make adjustments.
Mazdaspeed6 GT #3476 TiGray slicktop bolted & tuned by my own hand 405/394 AWD - cf1.01 BNRs3 315/372 AWD - cf1.01 k04 |
#8 (permalink) |
Quoted: 56 Post(s)
iTrader: 2 reviews
Alright that's what I figured. Thanks guys, fyi roadracer, the percentage of people who rev their engine in neutral within the first hour of putting on an intake is probably in the 90s, that doesn't make everyone a ricer but awesome useful input you have there.
#9 (permalink) |
Groaned at 8 Times in 8 Posts
Quoted: 18 Post(s)
Just wondering......why are you revving the motor in neutral to that high of an RPM?
2006 MazdaSpeed 6 Grand Touring | Velocity Red Mica DashHawk, CS TIP/SRI/TMIC, SU MM, JB EGR block plate/plug/TB TIG, CPE RDM, Perrin EBCS, Turbosmart BPV,TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, silicone boost tubes, Bilstein HD, LED bulbs, TRS projectors, HID fogs, Hawks pads, Amsoil diff/pto/trans, navi, XCarLink USB
#10 (permalink) |
Quoted: 79 Post(s)
Advertisement | |
