So I moved into a nice neighborhood and for the benefit of my neighbors not getting mad at 5:00am I decided to remove my Corksport exhaust and put my stock exhaust back on. Even though a have a CP-E downpipe w/ cat, There is pretty much no exhaust sound anymore, so goal #1 accomplished.
Unfortunately, I noticed a substantial decrease in power doing this (~25hp). The nice flow that the Corksport 3" pipe had all the way back is now restriced BADLY by the 2 1/4"? stock exhaust. What I want to do is put a large 3" muffler between the mounting points of the exhaust and just before it bends around the rear differential to gain most of the lost flow back, then reduce it down to the stock exhaust. I believe the sound should still be very minimal. Has anyone done this? FYI there is a cat in the stock cat location so nothing can be mounted there.
The new: 2006 Mazdaspeed6 Sport Velocity Red 1/4 - 13.739 @ 98.10 (Stock) w/ 1.787 60' Mods: 18" Tenzo Type M w/ 225/40/18 Kumho Ecsta SPT, Tein S springs, Mazdaspeed CAI, CP-E Standback, ETS TMIC, CP-E "Catless" DP w/ 53009 Magnaflow cat welded in, Corksport Exhaust, STRI DSD-SLM II 60mm Boost Gauge, Dashhawk, Synapse BOV; 0 - 60 4.64 (dashhawk) The old: 2003 6S MTX Speed Yellow /18" RSL ADR Mase/ 18" Nakayama Higari/ HIDs (6000K)/ Painted 'stash/ INJEN-CPE /BR Lip /Sprint Springs 1/4 14.503 @ 96.56 Post your time slips! Drag racing tips! |
| Sponsored Links | |||
Advertisement | |||
Groans: 6
Groaned at 4 Times in 4 Posts
Quoted: 128 Post(s)
iTrader: 13 reviews
If you are looking to reduce sound get a resonator or two welded into the corksport. The closer they are to the engine the more they will help, this has been dicussed many times.
Get the vibrant 3" in/out http://www.google.com/url?sa=t&rct=j...1n-LtuZ8euTX4A Also, the stock catback is not going to reduce power by 25, but maybe 5-10
CLEAN YOUR VALVES |
I'm not buying the 5 - 10 hp loss on the stock exhaust. There is just too much difference. It may be a torque loss over hp. Is there dyno proof of that claim?
I've looked around the forum on this topic, but haven't found exactly what I want. The closest I've seen someone do is a 3" back into the stock mufflers, which is originally what I wanted to do. Unfortunately, the exhaust shop I went to could not do this. I just want better flow with no noise.
Groaned at 8 Times in 7 Posts
Quoted: 174 Post(s)
According to the guru's at MSF, the stock exhaust is actually not very restrictive at all. According to them, if you are looking for power, upgrading the exhaust is the last place to look for it. A lot of them are actually running stock exhaust. Main reason for exhaust is sound.
2006 BCM MS6 GT #00584
CP-E 3" Straight Pipe Exhaust. CP-E TMIC. CS SRI/TIP. SU RMM. SU TP. Forge V1 BPV. Cobb AP. RichTuned. Denso ITV22. PTP HPFP Internals. STi S204 Lip. Megan Racing Springs. GenPu MS3 Wheels. VEI Boost Gauge. Blox Shift Knob. VG Shark Fin. 35W 8000K DDM HID lows/3000k fogs. Super White LED Tag Lights, Parking Lights, Interior Lights. SOLD: 2009 Mazda 6i GT. Comet Gray Mica. 6-speed MT. ![]() |
| The Following User Says Thank You to 6Y MAZDA For This Useful Post: | oh_yeams6 (11-20-2012) |
Quoted: 174 Post(s)
My biggest concern for you is you are running a DP with no HPFP internals and no AP. ZZB is imminent.
![]() Join Date: Jan 2007
Groaned at 6 Times in 6 Posts
Quoted: 64 Post(s)
I don't think CS's, or any 3"+ system can ever be made quiet.
I am having trouble visualizing your description, but do you mean adding a single muffler to the midpipe section of the car? Under the cabin? You cant fit one there, can you? I guess you don't like the idea of a single exit exhaust? You ever consider a cut-out? Maybe a cutout fabbed into the OE system, or something like the Magnaflow CB with a cutout? |
#7 (permalink) |
Quoted: 70 Post(s)
imminent, i dont know about that. More like 5 seconds ago.
i have single out and is noisy. leaves a black eye on exhaust valance too.
Black Mica 2006 Speed6 GT | 57,000 Miles Cobb AP | Stratified OTS Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | CP-e RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | NGK Step 1 Colder | Autotech Internals I'm Registered. Are You? Ms6db.com "I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..." -TiGraySpeed6 |
#8 (permalink) | |
I have not measured officially yet, but I do believe there is (barely) room to mount one there. As for the single exhaust, I don't like the "black eye" as mentioned above.
#9 (permalink) | |
What is AP and ZZB? I did have the CP-E DP crack on me and had to get it re-welded, but so far, so good.
#10 (permalink) |
Quoted: 182 Post(s)
AP=AcessPort
ZZB=ZoomZoomBoom usually as in throwing a rod.
2004 Mazda 6 Sport V6 MTX-Steel Grey MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18 Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils |
Advertisement | |
