4th Gear Temporary Power Reduction - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 57 (permalink) Old 03-06-2012, 04:38 PM Thread Starter
DPFISUMS6's Avatar
Quoted: 10 Post(s)
Noticed it today, between 3000-4500 RPM in 4th only so far, as RPMs increased, boost held position, and then spiked. Noticable reduction in car acceleration. WOT made this more evident.
One time heard a noise from the engin bay, almost a rattling. Another time boost guage backlight flickered which had never happened, I didn't notice any other power loss.
I checked the guage hose and wiring, everything seemed ok.
I have read about fuel cuts, and hiccups, possibility need a new hpfp here? Something else maybe?
Damn I wish I had a log to show.
VRM 2006 MS6 GT #517
AP V3 - Self Tune in Progress - ACT/pedal reinforced - H&R Springs - JBR 80a RMM - DREAD - TWM Stg 2 - Turbosmart BV - Denso20s - Hawks - SPC BJs - CS SS Clutch Line - Defroster POD/PS Boost Guage - RED Footwells - CAR LED & Brake Mod - LED Turns & all 194s -Smoked Side Markers - Nokya Yellow H11s w/MOD Rockford 200w Amp/12" Sub - AUXMOD
Plasti Dipped Lots of Stuff - Redline and Royal Purple
DPFISUMS6 is offline
post #2 of 57 (permalink) Old 03-07-2012, 08:33 AM
jm211's Avatar
Quoted: 211 Post(s)
Groans: 12
Groaned at 4 Times in 3 Posts
You don't seem to have many power mods. I've been reading where as you approach, say 280+ hp you have a pretty good shot at getting some fuel cut.
But, on the other hand, your boost gauge (as you say held position) would seem to indicate there are no boost leaks.
Double check for cracks along any intake, bpv etc hose. check charge tubes too on inter-cooler
Black Mica 2006 Speed6 GT | 60,000 Miles
Cobb AP | Stage 1 | JBR Stage II Intake - Blue | CP-e Exhaust | JBR RMM | SURE Shortcut | SURE Return | SURE Anchors | SURE AGS 625g Shift Knob | All Amsoil Fluids | Forge V1
I'm Registered. Are You?
"I would happily admit to anybody that the Mazdaspeed6 should come with a warning label..."
-TiGraySpeed6
jm211 is offline
post #3 of 57 (permalink) Old 03-07-2012, 08:38 AM
Lowspeed
TiGraySpeed6's Avatar
Quoted: 618 Post(s)
Groaned at 7 Times in 7 Posts
iTrader: 2 reviews
how does the car sound/act on first cold start of the day? Fast & easy, or slow to turn over, and takes a few revs to catch & start? I'm wondering if you're beginning to have battery issues, and this car is a bitch about good electricity and plenty of it...
That "almost rattling" could be a description of really bad engine knock- how's this tank of fuel?
How about the plugs?
All the clamps nice & tight- no leaks?
Was a Mazdaspeed6 GT #3476 TiGray slicktop
2009 BMW 135i - double the turbos, double the fun!
E82.N54 / A/T / Drop-in / CP / Berk Street / MHD / xHP
340 hp / 371tq
TiGraySpeed6 is offline
post #4 of 57 (permalink) Old 03-07-2012, 09:15 AM Thread Starter
DPFISUMS6's Avatar
Quoted: 10 Post(s)
I was about empty so I refueled and drove around for a while, found it happeneing in all gears.
Really cold days over the winter it would start ok and then die pretty much immediately after. Second start always stayed running.
I need to take a look i nthe light, checkings out more thoroughly.
post #5 of 57 (permalink) Old 03-07-2012, 09:48 AM
Lowspeed
Quoted: 618 Post(s)
iTrader: 2 reviews
really really cold start- it dies when you let the clutch out?
If that's it, just bypassing the clutch pedal switch will allow you to start the car with the clutch out instead, and prevents the symptom.
I've been doing this for years now, not for cold tho-
Thrust Bearing Failure/Clearance Is The ANSWER
edit to copy/paste this post from the Forzda thread I linked- compliments of McFly
And whats the benefit of jumpering the clutch so u can start without pressing it in?
When the clutch is fully depressed in, it pushes on the thrust bearing, so pushing the
clutch in on an engine start forces zero to full pressure on the bearing. This, in time will
cause excessive wear on the bearing. Without the clutch pedal depressed, you eliminate
that unneeded jolt to the crank bearing every time you start the car.
The auto manufacturers put the clutch pedal safety switch in for people that
never learn to do the 'stick jiggle' and instead start the car in gear, which can do damage
to the starter.... the front of your car..... what ever you jolt into....it's an idiot feature,
like the dinger when your key is in the ignition....
340 hp / 371tq
bazzarino (03-07-2012)
post #6 of 57 (permalink) Old 03-07-2012, 03:19 PM Thread Starter
DPFISUMS6's Avatar
Quoted: 10 Post(s)
Like well below ZERO temps that happens. No a problem I would think a Floridian would encounter. I'm so used to pushing the clutch in now i may just leave it.
I looked on lunch, didnt find anything loose or worse.
I think I'll order a COBB AP this week, would imagine something shows up there. Going to get one eventually anyways.
post #7 of 57 (permalink) Old 04-04-2012, 03:12 PM Thread Starter
DPFISUMS6's Avatar
Quoted: 10 Post(s)
Resolution has been found. I pressurized through the CAI with the boost leak finding contraption I found here and there is a leak.
Leak coming from a where the inlet meets the turbo, i think. It is near the fire wall on the right side down pretty low, is a bitch to reach let alone get a socket wrench down there.
The Following User Says Thank You to DPFISUMS6 For This Useful Post:
TiGraySpeed6 (04-04-2012)
post #8 of 57 (permalink) Old 04-04-2012, 03:50 PM
bmorrisj's Avatar
The stock turbo inlet hose is known to be loose fitting on the turbo before being adjusted.
2007 w/ Cheez
// COBB AP // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs //
Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber
// Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob //
bmorrisj is offline
The Following User Says Thank You to bmorrisj For This Useful Post:
DPFISUMS6 (04-04-2012)
post #9 of 57 (permalink) Old 04-10-2012, 03:35 PM Thread Starter
DPFISUMS6's Avatar
Quoted: 10 Post(s)
More update, when monkeying around with the TIP and tightening it did not help, I took it to the Dealer. Dont have the full story yet, but a solenoid is stuck open they say. Not waste gate, he said somthing about Emisions and intake but he wasn't sure.
post #10 of 57 (permalink) Old 04-11-2012, 02:13 PM Thread Starter
DPFISUMS6's Avatar
Quoted: 10 Post(s)
The Dealer replaced the purge valve... boost leak seems to be non-existent BUT RPMs still surge up and the back of gradually as the car seems try to catch up with its self when accelerating quickly. I didn't go WOT but over 3k rpm up hill it held boost at 16 steady while the RPMs are all over the place.
Also, I felt like Jerry Sienfield as the dealer chastised me for not changing my oil at 3k miles. All i have read on this site and otherwise is that is not necessary.
Last edited by DPFISUMS6; 04-11-2012 at 02:15 PM. Reason: to finish my last sentence
