Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Mazdaspeed6 > Speed6 Engine/Drivetrain
Old 10-08-2009, 10:11 PM   #1 (permalink)
late8's Avatar
Knock readings were climbing up according to my AP during the last week of daily driving (amp. temps in mid 70s.) Yesterday, after crusing on the freeway between 75-80 mph for an hour, I exited and coasted to the stop sign and pulled a typical "California stop" and slowly rolled through and gave the throttle a tap and my knock reading shot to 5.8; knock reading is usually partial throttle between .3 to .7
Fearing the "I exited the freeway and popped my motor" syndrome, I drove home and pulled the plugs. The Densos have been in the motor for at least 25k.
After doing some research, I'm still confused on how to read these plugs. I've added some pics my Denso and highlighted some possible problem areas with arrows on the #3 plug.
My concerns on the #3 plug is that the jetting hasn't completely covered the ring as the other plugs show and the strap is discolored and slightly burned more than the other plugs.
Am I reading my plugs correctly? There are tons of photos on spark plug webites on bad or problem engines but I'm confused on what direction the discoloration is supposed be headed on the strap. Is the plugs too cold by the color?
As a side note, I didn't have a second set of new Denso plugs so I re-installed the NGK iridiums that I used for just a short time. Just to see how the car would react on my current fuel trims, I didn't bother resetting the ECU after swapping back to the NGK's.
My knock readings are back down to .3 to .7 and the throttle response is so much quicker and the butt dyno says the car pulls harder.
I'm thinking that I needed a set of fresh plugs?
Thanks in advance for the help!
'06 Black Cherry Mica MS6 GT w/sunroof
Engine/drivetrain: Cobb AP (Stg.1 91 v1.02) AEM SRI w/ air straightner,
Speedie6's T.I.P, Forge BPV, Denso ITV22 spark plugs, SU Silicon Boost Tubes, silicon recirc. and vac. tubes
Saikou Michi OCC w/ 2 PCVs, CP-E Motor Mount, SU Stiff Diff bracket
Exterior: Badgeless AE style grill, 18x7.5 Kazera KZ-T Silver Rims, 215/45/18 Hankook V12 Evo
Bilstein shocks, AutoEXE Lowdown springs, SPC ball joints, Magnaflow catback, Redline Tuning hood shocks,
Interior: Lotek gauge pod w/ ProSport boost, water, volts gauges,
TWM stage 2 short shifter w/bushings, Redline short shift boot
late8 is offline   Reply With Quote
Old 10-08-2009, 10:22 PM   #2 (permalink)
Turbo6Girl's Avatar
Location: Where the anal itching parasites are, also known as Draper, Utah. Or is it Ohio? I can never remember.
Send a message via AIM to Turbo6Girl
They look like they are burning evenly and don't look bad IMO. This is how mine looked on my NGKs with 25K~ miles when I switched to the Densos. I think you probably just needed new plugs but it doesn't look like there is a major issue with how they have burned.
Click here for a burn chart.
The official non-6 owner forum lurker, harasser and racket queen.
1993 Probe GT, Hawk HPS pads, Continental ExtremeContact DW's. More goodies waiting to be installed.
2006 Black Mica MS6 Sport, 65K miles and one hell of a love/hate relationship. She will be missed.
Centric Brakes from R1 Concepts CLICK HERE
Turbo6Girl is offline   Reply With Quote
Old 10-08-2009, 11:32 PM   #3 (permalink)
late8's Avatar
Thanks Turbo6Girl for the chart link.
Old 10-08-2009, 11:51 PM   #4 (permalink)
late8's Avatar
After viewing the burn chart, would spark plugs pulled from a DI motor have the same normal burn or wear pattern as the plugs found on a standard chart?
Old 10-08-2009, 11:53 PM   #5 (permalink)
They seem to be too hot.
EDIT: I should state that the previous statement is a general combustion temp statement and may not be related to plug temp rating.
Formerly known as Corpus_Speed6 - 06Speed6 on MSF... The handle change is gay.
Quakeguy is offline   Reply With Quote
Old 10-08-2009, 11:57 PM   #6 (permalink)
late8's Avatar
Maybe go 2 step colder?
Old 10-09-2009, 04:12 PM   #7 (permalink)
late8's Avatar
QUOTE (Corpus_Speed6 @ Oct 8 2009, 08:53 PM)
EDIT: I should state that the previous statement is a general combustion temp statement and may not be related to plug temp rating.[/b]
Hey thanks for the heads up! I double checked the AP map I loaded a while back and sure enough I flashed the 93 octane instead of the 91 version. Shit.
Old 10-10-2009, 08:20 AM   #8 (permalink)
QUOTE (late8 @ Oct 9 2009, 04:12 PM)
Hey thanks for the heads up! I double checked the AP map I loaded a while back and sure enough I flashed the 93 octane instead of the 91 version. Shit.[/b]
Lol.
Switching back to the denso's then, are you?
2007 Black Mica MazdaSpeed6
p057 is offline   Reply With Quote
Old 10-12-2009, 12:23 PM   #9 (permalink)
MS6Mike's Avatar
Yeah that white color means youre running hot
2006 Velocity Red Mica MS6 GT
<blockquote>
Cobb AP*Stage II
CPE Intake / Speedie6 TIP / CPE Motor Mount / CPE 3" Downpipe +cat / PG CDFP Upgrade
RPM Smoked Rear LEDs / RPM Smoked LED Side Markers / MSD Dashhawk / CX7 Antenna
MB Boost wheels + oem Rubber (hot) / oem Wheels + Pirelli Sottozeros (cold)
</blockquote>
MS6Mike is offline   Reply With Quote
Old 10-12-2009, 12:40 PM   #10 (permalink)
late8's Avatar
QUOTE (P057 @ Oct 10 2009, 05:20 AM)
Lol.
Switching back to the denso's then, are you?[/b]
Yup,....ordered from SU. $47.50 shipped!
