ok so the start of my problem was, i would floor it and i would go to around 12psi taper to 10psi and fall off. so i was told by a shop it was my boost sensor. i just replaced it today and saw around 13psi when the intake was on, no i put on the TIP and am running around 12psi holding. but it doesn't taper off it just holds unti around 5500 rpms. Could there be a boost leak or something that i missed? i will pressure test it tomorrow but does anyone have any ideas?
--AEM CAI--Corksport DownPipe--Forge Motorsports BPV--Denso ITV22--Eibach Pro Springs--Cobb TIP--AWR MM--Corksport Race Pipe--Glowshift Boost Gauge--TWM SS--Redline Quick Lift--Tinted Side Markers--VG Sharkfin--10000k D2S--2700k Fogs-- 13.3 @ 99.7 |
Groaned at 2 Times in 1 Post
Vac at idle normal? Could also be an exhaust leak before the turbo letting out pressure (mani, turbo, either gasket).
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s | CPE CAI, SU MM, SU Boost and Recirc Tubes, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1 w/Bushings, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, CX-7 Antenna, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3, GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler. Spare GT2871r for sale. |
My guess is a boost leak, same thing happened to me with the boost only going up to 12ish and going down to 8. Connector wasn't fastened on the line to the boost gauge...
2006 MAZDASPEED 6 is no more... :..( PARTING OUT!!! FOR SALE!!! SM Stage II OCC ($150) DashHawk ($225) |
