Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Mazdaspeed6 > Speed6 Engine/Drivetrain
Old 09-11-2009, 01:38 PM   #1 (permalink)
bkbmazda's Avatar
http://www.pbase.com/rsrock/oil_catch_can
I found this last week, and I wanted to do something about the lack of PCV valve on my MS6, I recently installed boost tubes, ets tmic, and removed my entire intake and cobb TIP and man, there was alot of oil residue in there. Weird thing is my car does not smoke...but yesterday I went to homedepot, spent $30 and installed this, everything with the car seems fine, drove the car for about 50 min. this morning and checked it out, saw no oil in the bottle or the lines as of yet. But this seems like a nice simple fix, still free flowing from the valve cover to the MS CAI, but alot more rubber line and the catch can. Here is a pic.
Excuse the lack of mounting bracket, LOL I was lazy and used steel reinforced tie wraps for now.
2007 MS6 GT & 2007 6 GT WAGON
"mazda won me over with their 6 so much I bought 2 of em"
bkbmazda is offline   Reply With Quote
Old 09-11-2009, 02:08 PM   #2 (permalink)
jmhinkle's Avatar
Been done a million times on a zillion cars and eventually fails. Just doesn't hold up for use in a car. The housing will crack soon enough.
Yup, my car is stock.
jmhinkle is offline   Reply With Quote
Old 09-11-2009, 02:09 PM   #3 (permalink)
our cars don't lack a pcv valve, its just not off the valve cover. its off the crankcase behind the intake manifold.
07 Mazdaspeed6 GT
MzdSpd.com
bova80 is offline   Reply With Quote
Old 09-11-2009, 02:09 PM   #4 (permalink)
late8's Avatar
Is your "can" an air compressor filter?
Edit: added pic
'06 Black Cherry Mica MS6 GT w/sunroof
Engine/drivetrain: Cobb AP (Stg.1 91 v1.02) AEM SRI w/ air straightner,
Speedie6's T.I.P, Forge BPV, Denso ITV22 spark plugs, SU Silicon Boost Tubes, silicon recirc. and vac. tubes
Saikou Michi OCC w/ 2 PCVs, CP-E Motor Mount, SU Stiff Diff bracket
Exterior: Badgeless AE style grill, 18x7.5 Kazera KZ-T Silver Rims, 215/45/18 Hankook V12 Evo
Bilstein shocks, AutoEXE Lowdown springs, SPC ball joints, Magnaflow catback, Redline Tuning hood shocks,
Interior: Lotek gauge pod w/ ProSport boost, water, volts gauges,
TWM stage 2 short shifter w/bushings, Redline short shift boot
late8 is offline   Reply With Quote
Old 09-11-2009, 02:38 PM   #5 (permalink)
bkbmazda's Avatar
QUOTE (jmhinkle @ Sep 11 2009, 11:08 AM)
Been done a million times on a zillion cars and eventually fails. Just doesn't hold up for use in a car. The housing will crack soon enough.[/b]
I figured this much... i didnt think it would last forever, just more of an experiment to see how much oil is making its way into the TIP.
It says right on the bottle(max temp 130 degree's) and I am sure that the engine bay will get over that in the summer time.
QUOTE (bova80 @ Sep 11 2009, 11:09 AM)
our cars don't lack a pcv valve, its just not off the valve cover. its off the crankcase behind the intake manifold.[/b]
sorry I mis-spoke, I realize that area is where most put the real catch cans as well, and that it too is a problem area, just wanted to do this experiment because all the oil I saw was before the intake manifold.
QUOTE (late8 @ Sep 11 2009, 11:09 AM)
Edit: added pic[/b]
yes.
Old 09-11-2009, 03:01 PM   #6 (permalink)
jmhinkle's Avatar
Your best choice is VTA on the valve cover thru a real catch can.
I tried that PTP thing and my car still smoked, but it made me think about the whole situation more. I've had a 2nd OCC for a long time, but always hooked to the intake pipe like stock. I just vented the OCC to air with a filter and plugged the intake tract hole. I haven't smoked since.
Old 09-11-2009, 03:19 PM   #7 (permalink)
bkbmazda's Avatar
QUOTE (jmhinkle @ Sep 11 2009, 12:01 PM)
I tried that PTP thing and my car still smoked, but it made me think about the whole situation more. I've had a 2nd OCC for a long time, but always hooked to the intake pipe like stock. I just vented the OCC to air with a filter and plugged the intake tract hole. I haven't smoked since.[/b]
yeah that ptp thing for $25 doesnt sit well with me, I dont think restricting the flow of crankcase pressure is the best idea. I think I will run this current setup for a couple weeks, then I will grab a real filtered catch can to put in its place, but I think your right, a catch can with VTA would be a step in the right direction.
Old 09-11-2009, 05:11 PM   #8 (permalink)
QUOTE (jmhinkle @ Sep 11 2009, 11:01 AM)
Wait so this has been working? Nice!
http://www.youtube.com/watch?v=wsHLbZyA2Uk watch me but DO NOT watch me
07 speed6
-cp-e cai -tp -amsoil everywhere -whiny diff -forge bpv -cobb ap -saikou mitchshuitsou OCC -Speedie6 Inlet -cp-e fmic -denso 1 step colder plugs -water/meth in the trunk -WOTBOX -CS DP -BSD+baffle -diff braced -whiteline RSB -CS TP -CS CBE -rpm sport -spc BJ -GT3071 -TTFMM -DCR Exh Mani waiting to be installed
djuosnteisn is offline   Reply With Quote
Old 09-11-2009, 05:41 PM   #9 (permalink)
jmhinkle's Avatar
Yeah, I guess I forgot to tell you guys, but it started smoking with the PTP thing right before I left and I was seeing weird knock like a few other guys. I pulled it out and bought a filter and went VTA the day before I rolled out. Been working great so far.
Old 09-11-2009, 05:58 PM   #10 (permalink)
Road Rage's Avatar
back in the 90's we did alot of that, now days catch cans are so cheep
jegs sells a kit for $40
"When you can leave black marks from the exit of every turn to the braking points of the next turn, then you have enough horsepower."
"Oversteer is when you hit the wall with the back of the car. Understeer is when you hit the wall with the front of the car. Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
06 Black Cherry Mica Speed6
Road Rage is offline   Reply With Quote
