While changing to oil I found that my Drive Belt is shot ... Split all the way down the middle. See attached pic. Any chance I can relieve the tension from the idler pulley without having to pull the splash shield and wheel off? I think I can get an open end wrench on it from the side/front, but how much leverage will I need in order to get the belt off?
Looks like you got a pebble in there ... seen it happen before.
I found I needed a lot of leverage ... search for me with the word "tensioner" ... should find more info from me and others.
2007 MS6 Eibach Pro-Kit, RX8 Wheels, Toyo Versado (245-40-18), Ractive heatshield filter on stock MAF, Magnaflow custom 3" CBE, Stock BPV, Prosport boost gauge, ETS TMIC 3.25", Sprint Booster BDJ601A, Aeroforce OBD gauge, SPC Adj Ball Joints, Cobb AP Stage 1 |
use an angled, close ended 14mm, and reach down from the top right by the alternator. With your left hand, you should be able to get the closed end on the bolt, (with the angle going towards the driver side), and pull up enough to remove the belt. Ive done this several times, no need to even jack the car up, or remove anything from underneath.
[b][i]2007 MazdaspeedTial 44m EWG, GT2871r, Labonte Meth Injection Stage 2, Cp-e FMIC, Cp-e HPFP, Cp-e Big Turbo Inlet, Cp-e Catted DP, Cp-e Standback v2.5, PnP harness, Cp-e FC Flashes, Cp-e Rear MM, Magnaflow CB, DNP Turbo Manifold, Turbosmart Eboost2 Boost Controller, Synapse BOV, F2 BSD, Greddy OCC, Mazdaspeed SRI, Turbine Tech Front Motor Mount, Street Unit Rear Motor Mount, Mazdaspeed Lowering Springs, AutoExe Strut Bar, TWM Stage 2 Shifter w/bushings, VEI Digital AFR/EGT Gauges, Innovate Wideband Sensor, Dashhawk, V1....Last Dyno 06/25/2009 356 AWHP/365 TQ |
#4 (permalink) | |
QUOTE (firestonemazda @ Apr 17 2009, 07:25 AM)
#5 (permalink) | |
QUOTE (firestonemazda @ Apr 17 2009, 11:25 AM)
This is what the tensioner looks like ... stole the pic from another thread. The bolt in the middle is what the manual says I need to grab onto ... def not 14mm.
Am i missing something? |
#7 (permalink) |
Its a 14mm. I'm not sure if there's more than one tensioner (I doubt it), but the one that I've used is a 14mm, and it is visible from the TOP, just to the right of the alternator pulley.
And you have to pull it up installing the belt as well. The tensioner gives slack when you pull up.
#8 (permalink) |
i think I am looking at the wrong pulley ... I just went out to take a quick look ... I was looking at an idler pulley towards the top of the motor. When I looked down further, near the alternator there is another pulley .. that one looks to have a 14mm bolt on it. I assume that's the one?
I thought it was Pulley 1 in the diagram ... the alternator I think is #2 right? the tensioner is next to that one. That sure would explain it ... doh!
#9 (permalink) | |
QUOTE (firestonemazda @ Apr 17 2009, 01:15 PM)
#10 (permalink) | ||
QUOTE (2006mazdaspeed6 @ Apr 17 2009, 11:25 AM)
QUOTE (LBV @ Apr 17 2009, 01:21 PM) Quote:
