MS6 Fluid Notes & DIY Pictures - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Mazdaspeed6 > Speed6 Engine/Drivetrain
New User? Register
Old 09-13-2008, 04:45 PM   #1 (permalink)
TiGraySpeed6's Avatar
Groaned at 5 Times in 5 Posts
Quoted: 210 Post(s)
Notes on fluids & associated part information for the MS6
Please do post corrections or suggestions-
I'll integrate to this post as appropriate
This was mostly copied & pasted from dozens of posts,
or taken from the '06 MS6 owners manual
-notes gathered mostly just to make my life easier.
based on US dollars, quarts or gallons
> Fuel Tank
'06 MS6 Manual - 15.9 us gal
> Power steering fluid
'06 MS6 Manual - ATF M-III, M-V, or equivalent (e.g. Dexron® II)
dry fill- 1 quart
HOW TO: Power Steering Flush
**NOTE: This is not a good area to skimp on quality. In harsh environments like autocross the power assist has been known to fail. Well worth the extra few dollars for a good synthetic ATF.**
> Brake/Clutch fluid
'06 MS6 Manual - SAE J1703, or FMVSS116 DOT-3
system flush- 1 liter
> Coolant
'06 MS6 Manual - 8.5 us qts (2.25 us gallons)
Type- Mazda FL22
Mazda OEM - part# 0000-77-508E-20
Ford Specialty Green Coolant - Motorcraft part # VC-10-A or VC-10-A2 - $27.59 gallon 50/50 mix
Zerex Asian Vehicle Coolant - NAPA Part # ZRX 675130 - $13.99 gallon of 50/50 mix
get 2 gallons and top off with distilled water
It seems that only Mazda has coolant called "FL22"
- - Well, OK then, just WTF is FL22, and is this going to be a PITA?
Some clarity, compliments of the BobIsTheOilGuy forums, and a poster named ponderosaTX
"...Mazda automotive coolants are green but they have almost NOTHING in common with conventional North American green coolant. Prior to the 2005 model year, Mazdas were equipped with a first generation P-OAT (phosphated organic acid technology) coolant developed and manufactured by CCI, the leading Japanese coolant company. P-OAT coolants rely on a combination of phosphates and organic acids to prevent corrosion; they contain no silicates or borates. In the 2005 model year, Mazda started using a second generation P-OAT coolant which has a lower concentration of phosphates and an improved organic acid additive package. The other major Japanese auto manufacturers, namely Toyota, Honda, and Nissan all use essentially the same coolant technology.
The only aftermarket P-OAT coolants are Japanese OEM coolants from Mazda, Toyota, Honda, and Nissan, Zerex Asian Vehicle coolant, and Motorcraft Specialty Green Engine Coolant (which reportedly is identical to the second generation Mazda FL22 OEM P-OAT coolant). For the record, Ford started using Japanese P-OAT coolant technology in many of its 2009 models (those sharing engine technology with Mazda) instead of G-05. Ford evidently found the performance of Japanese P-OAT coolants was superior to G-05 in Mazda engineered engines.
Using conventional North American green coolant in a Mazda is a bad idea. Even German (BASF) coolant technology as embodied in G-05, which contains silicates and no phosphates, is a much better choice than conventional North American green for vehicles with aluminum blocks and aluminum radiators. But a genuine P-OAT coolant, particularly a second generation P-OAT coolant like Mazda FL22 or Motorcraft Specialty Green, is the best choice."
It now looks like Ford Specialty Green Coolant may be the cost-effective alternative to Mazda FL22. Zerex Asian Vehicle Coolant is another option.
Originally Posted by IHeartGroceries on 4/13/2012 View Post
Just got off the phone with the Ford house.
Their Mazda equivalent fluid is now identified as VC10A2.
It was priced 27.59/gal...
> Engine:
5.5 - 6 qts
7 quarts with Balance Shaft removed
'06 MS6 Manual
- 5W-30
There's a strong argument being made that 5W-40 is better
as the slightly thicker viscosity will not seep past the seals
in the turbo and may help prevent the smoking turbo syndrome.
Oil Filter - cartridge style
Oil Filter Part Numbers:
FL-2017B - Motorcraft/Ford OEM cartridge oil filter
L321-14-302-9U - Mazda OEM cartridge oil filter
7203 - Napa Gold cartridge oil filter (made by Wix)
57203 - Wix cartridge oil filter
L15505 Purolator Premium Plus cartridge oil filter
PL15505 Purolator Pure One cartridge oil filter
GL15505 O'Reilly's/Microgard cartridge oil filter
P7313 - Baldwin cartridge oil filter
HP-7013 - K&N cartridge oil filter (made by Champion Labs)
84203 - Carquest cartridge oil filter (made by Wix)
LF594 - Hastings cartridge oil filter
CH9641 - Fram cartridge oil filter
P960 - Champ cartridge oil filter (Champion Labs, makes oil filters for other companies)
S9641 - STP cartridge oil filter (made by Champion Labs)
M1C153 - Mobil1 cartridge oil filter
Oil Filter Wrench - 76mm/14 flutes
Engine Oil Crush Washer - Mazda OEM - part# 9956-41-400
Drain Bolt torque specs - 23-30 ft-lbs
**NOTE - Short interval oil changes- fuel shear from DISI is bad mojo
> Tranny:
'06 MS6 Manual - API Service GL-4 (SAE 75W-90)
3 qts - GL-4
2.5 us qts actual fill
-Amsoil
Synthetic Manual Transmission and Transaxle
Gear Lube 75W-90 API GL-4 (MTG)
-RedLine
MT-90 (75W90 GL-4 Gear Oil)
-Motorcraft
Ford Manual Transaxle fluid # XT-M5-QS (75W-90 GL-4 Gear Oil)
Transmission Crush Washer - Mazda OEM - part# A601-17-117
Drain and Fill Bolt torque specs - 20.2-37.5 ft-lbs
> PTO & Rear Diff:
'06 MS6 Manual - API Service GL-5 (SAE 80W-90)
3qts - GL-5
'06 MS6 Manual - pto - 1.3 us qts actual fill
'06 MS6 Manual - r.diff - 1.1 us qts actual fill
-Amsoil
SEVERE GEAR® Synthetic Extreme Pressure (EP) Lubricant 75W-90 (SVG)
Long Life Synthetic Gear Lube SAE 75W-90 (FGR)
-RedLine
75W-90 (75W90 GL-5 Gear Oil)
PTO Crush Washer - Mazda OEM - part# 9956-21-800
Rear Diff Crush Washer - Mazda OEM - part# 9956-41-800
Drain and Fill Bolt torque specs - Transfer case: 29.0-43.3 ft-lbs
........................................... Rear differential: 29.0-39.7 ft-lbs
What's the deal with this GL-4 vs GL-5 business anyway?
You can go here and form your own opinion:
GL5 gear oil bad in tranny,fact or myth? - clicky-clicky
Even more reading on the subject- clicky-clicky
In theory, and in the print of many GL-5 containers, and many parts counter guys will say GL-5 superseded GL-4 and is suitable for all GL-4 or GL-5 locations.
That said, many, including my Amsoil Rep and the Bobistheoilguy forums will tell you different. My Mazda manual also clearly states 4 for the tranny, 5 in the remainder.
GL-5 contains sulfur compounds known to not be healthy to yellow metals such as brass (read: your synchros). GL-4 has a substantially lower quantity of sulfur than GL-5, which instead uses chemicals to try & lessen the impact on gold metals.
My manual calls for GL-4
My Amsoil Rep is is vehement on this as well!
>DIY Pics:
Trans:
Transfer Case/PTO:
Read Diff:
>Helpful Hints:
the plugs are all either 23 or 24mm
drain & fill bolt torque specs from the FSM:
- Engine: 23-30 ft-lbs
- Transmission: 20.2-37.5 ft-lbs
- Rear differential: 29.0-39.7 ft-lbs
crush washer part numbers:
- Trans oil plug washer - A601-17-117
- T-case oil plug washer - 9956-21-800
- Diff oil plug washer - 9956-41-800
A pump of some kind is highly recommended for all three locations.
-Basic, inexpensive hand pumps can be had from almost any parts store
Squeaky clutch or shifter?
Originally Posted by lapisbluinhou View Post
What is the recommended lube for this guy and is it applied directly on the part?
Originally Posted by FORZDA 1 View Post
The best grease I have found for underhood type stuff in the green "waterproof" grease from Advance auto. Can't think of the name right now, but you will know it when you see it. The shifter mechanism must be cleaned out real good with paper towels before adding lube. You lube it by "squishing" a blob of grease into and through the openings and wiping off the excess.
This guy is starting to make an awful noise when I press in the clutch. Not sure if he needs to be lubed or replaced.
The clutch slave cylinder push rod squeaks where it contacts the release arm. Just push a bit of the green grease into the contact area and it will be fine.
> Post-transplant start-up options
(whoosh @ Apr 8 2009, 05:50 AM)
install the turbo and connect all lines (oil and coolant)
unplug the coil packs / just the connectors
turn the car over for about 10-15 seconds
obviously it will not start and thats the point to get oil running through the turbo
sit a minute and do the 10-15 seconds again
connect the coil packs and start it up
don't worry about the coolant
after your car is running and you are sure there are no leaks
let it cool a bit and add coolant until it's at the required level
Originally Posted by ungrave View Post
I wanted to add that the crank/no start procedure from whoosh is a good idea but not the best way of going about it. Reason being is that with that procedure you are removing the spark but the engine is still injecting fuel into the combustion chamber.
A much better and easier way of doing this (and what I do on initial start up after each oil change) is to simply pull the fuel injector fuse.
Open the fuse box under the hood next to the air filter. Pull the fuel injector fuse, I believe it's labeled 'FUEL INJ'. Fuses are labeled under the fuse box cover. It should be the fuse near the corner of the fuse box by the MAF. Crank the engine till the oil light goes off, then put the fuse back in. Then crank it again and it'll start right up with instant oil pressure!
Mazdaspeed6 GT #3476 TiGray slicktop
Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete
M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, SU Billet RMM
TWM Stage II STS & JBR SSB, Prosport Mech Boost
RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff
Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued
405/394 AWD - cf1.01 e38 BNRs3
315/372 AWD - cf1.01 e38 k04
TiGraySpeed6 is online now   Reply With Quote
The Following 3 Users Say Thank You to TiGraySpeed6 For This Useful Post:
daztd (03-15-2013), Mandinca (04-26-2013), We Are Ninja (02-16-2013)
Old 09-15-2008, 03:30 AM   #2 (permalink)
dude...i vote for sticky.
jroc520 is offline   Reply With Quote
Old 09-15-2008, 06:48 AM   #3 (permalink)
fireboy's Avatar
How about coolant?
And windshield washer fluid?
2006 Mazdaspeed 6 GT Black Cherry Mica
Mods: CPE XCel CAI, HKS BOV, CX7 antenna, Intel dual core CarPC, Car2PC adapter, ObdPro adapter, clear sidemarkers, mazdaspeed oil cap, block8head vent pod with Prosport premium boost gauge, CCD rear view camera, led bulbs in most lights, Denso 1 step colder spark plugs
Tuned with -
by
Mazda 6/Speed 6 Manuals Online
fireboy is offline   Reply With Quote
Old 09-15-2008, 06:56 PM   #4 (permalink)
Quoted: 210 Post(s)
Updated to add coolant info
Old 09-30-2008, 06:55 PM   #5 (permalink)
Quoted: 210 Post(s)
updates to the PTO/Rear Diff section, amsoil notes
Old 09-30-2008, 08:51 PM   #6 (permalink)
sticky.. i see this coming in very handy for alot of people.
2007 Mazdaspeed 6
dane145 is offline   Reply With Quote
Old 10-01-2008, 08:57 PM   #7 (permalink)
gte024h's Avatar
I need to know the brake/clutch fluid capacity. Anyone got that?
retired
gte024h is offline   Reply With Quote
Old 10-02-2008, 06:57 PM   #8 (permalink)
Quoted: 210 Post(s)
I've not yet flushed the fluid on the MS6-
That said, I have performed complete system flush on many rides over the years, and have never used a full litre bottle to complete the job.
My standard routine, which will be done to the MS6 as well, what I've always called a Stage 1 brake upgrade, includes the following for all four corners at once:
- pads
- slotted rotors, OEM size (slotted for rain shedding, I'm in Florida)
- Stainless braided lines
- ATE SuperBlue (litre bottle, +/- $14.00 US)
I use a Motive Power Bleeder, making the fluid flush a simple, fast one person job. (1101 adapter for Mazda)
You could get by with less fluid, but I'm just cautious that way, and I like to flush a pretty good quantity of the new stuff through the system.
Old 10-02-2008, 07:31 PM   #9 (permalink)
Groans: 5
Groaned at 6 Times in 4 Posts
Quoted: 37 Post(s)
QUOTE (TiGraySpeed6 @ Oct 2 2008, 06:57 PM)
- ATE SuperBlue (litre bottle, +/- $14.00 US)[/b]
I also use ATE. Some shops also carry the ATE amber ... same stuff, but makes it easy to tell when you have flushed the lines completely. Very handy if you track your car and change brake fluid often.
For MTX oil, I also suggest NEO synthetic 75W90-HD (bakerprecision.com). A bit better that MT90 for shifting.
NEO trans oil review
04 6S atx hatch
93 RX-7, 75 Trident
KevinK2 is offline   Reply With Quote
Old 10-03-2008, 09:29 PM   #10 (permalink)
Quoted: 210 Post(s)
The comments on Neo are very positive, the RX7 folks really seem to have been fond of it.
Thanks for posting that link. I'd never heard of Neo
Now then, I'm going to make a request here, but I wanted to say KevinK2, I'm not grieving at you!!
Rather, this is a pre-emptive post.
There are many, many more brands out there beyond the two I've listed above.
Well, look, I don't want this thread to develope into a pissing match of any kind. In that regard I've added the following text to the original post in the hopes that it will stay more as a nice simple FAQ on fluids for the MS6-
Please, please do post things that should be added in the first post, but let's not start into a TORCO RULES thing, keep it to a GL-5 will cause excessive wear to gold metals so use GL-4 where spec'd type thing. Frankly, I've added everything I can think of, so anything else will come from your suggestions. -
ok? thanks.
Edited to include note on brand names-
Shown here for those getting the email thread updates:
A note regarding brand names-
There are many, many more available than the two reasonably popular and widely available examples I've listed above for the tranny and PTO/Rear Diff. Heck, I didn't even list examples for the engine oil or brake fluid because there are so many good choices. People have different brand loyalties, needs, desires, environments etc, and there are as many differing viewpoints as there are oil/lube brands to choose from.
I'm not even gonna bother trying to list all of them
Please feel free to start another topic to discuss your favorites, and feel free
to post here with a link to your thread.
The brands I did choose to list as examples are readily available and have been
deeply discussed over & over again.
Thanks-
TiGray-
