CHECK ENGINE LIGHT - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 15 (permalink) Old 01-26-2008, 07:52 AM Thread Starter
mzumel's Avatar
2007 Mazdaspeed 6, only been 1month and 8 days
2012 miles
Got up off the bed, prepared for work, started the car, the usual warm up idle, then all of a sudden I noticed that the engine light stayed on.
Well with-in the warranty, no mods, just engine light is on. Checked fuel cap, it was on correctly nice and closed. Sounded exactly the same on idle. Last drive, drive around the city, didn't stall or anything.
Any suggestions?
mzumel is offline
post #2 of 15 (permalink) Old 01-26-2008, 08:18 AM
Jax6S's Avatar
Go get it checked at the dealership just to be safe.
2006 Black Mazdaspeed6
Jax6S is offline
post #3 of 15 (permalink) Old 01-26-2008, 08:27 AM
mk706's Avatar
i'll bet cash-money that it's the EVAP code. i.e., leak of gas vapors. the dealer will most likely tell you that you failed to full seat the gas cap. i assure you i full seat the gas cap with every fill up.
i've had this problem 4 times now. the first time the dealer gave me that lame explanation, the second time they replaced the purge valve. times three and four i got the same lame excuse. i think i'm going to upgrade to an aftermarket gas cap.
2006 MS6-GT Black Cherry Mica - Sold!
2007 Mazda CX-7 GT-AWD Crystal White Pearl
2005 M6s-5door Steel Gray - traded in
2004 M6s-4door Sepang Green - traded in
Semper Fidelis
mk706 is offline
post #4 of 15 (permalink) Old 01-26-2008, 09:18 AM Thread Starter
mzumel's Avatar
i've had this problem 4 times now. the first time the dealer gave me that lame explanation, the second time they replaced the purge valve. times three and four i got the same lame excuse. i think i'm going to upgrade to an aftermarket gas cap.[/b]
What does "Full seat" mean? Is there any other way, method that I can do to make the light go away? Filling up my gas tank to full not over clicking it...it was cold this morning too about 39 degrees...would that be the cause?
mzumel is offline
post #5 of 15 (permalink) Old 01-26-2008, 09:47 AM
Send a message via AIM to jb606
First, go get the code pulled! Most major auto parts places will pull the codes out for free. Once you have your code(s), if the store didn't tell you, someone in here can lookup what the code means.
My guess it's going to be some kind of evap code.
2012 VW MKVI GTI
2010 Infiniti G37x
2006 Mazdaspeed6 GT (Sold)
jb606 is offline
post #6 of 15 (permalink) Old 01-26-2008, 01:12 PM
firedawgs's Avatar
Let us know what the code was.
I just had my front O2 sensor replaced, because of a code. I think the sensor got fouled up when the turbo went bad.
firedawgs is offline
post #7 of 15 (permalink) Old 01-26-2008, 01:21 PM
06MS6GT's Avatar
Agree with mk706. When I had the Engine Light on, I took it to the Autozone (lot closer than the dealer) and for free they checked it and cleared it. It ended up being the gas cap not being tight enough...
2006 Titanium Gray Metalic Mazdaspped 6 GT -
06MS6GT is offline
post #8 of 15 (permalink) Old 01-26-2008, 02:18 PM Thread Starter
mzumel's Avatar
went to autozone, it says engine code is P0455...anyone know what that is?
mzumel is offline
post #9 of 15 (permalink) Old 01-26-2008, 03:38 PM
Just from a quick search on net.
P0455 OBD-II Trouble Code
Technical Description
Evaporative Emission Control System Leak Detected (no purge flow or large leak)
What does that mean?
This indicates a fuel vapor leak or lack of purge flow in the EVAP control system. It means a large leak has been detected. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Symptoms
You likely won't notice any drivability problems.
Causes
A code p0455 most likely means one or more of the following has happened:
* A loose or improperly affixed gas cap
* A non-conforming gas cap (i.e. not factory/original brand)
* Other leak or damaged piece in EVAP system
Possible Solutions
With a p0455, the most common repair is to:
* Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
* Otherwise, replace the gas cap, and/or
* Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary
Hope it is accurate.
rkohou is offline
post #10 of 15 (permalink) Old 01-28-2008, 12:26 AM Thread Starter
mzumel's Avatar
Symptoms
Causes
Possible Solutions
Hope it is accurate.[/b]
Well went to sears picked me up a canobd2 sensor and it read it p0455... I cleared it and made usre the gas cap was tight, about to see if it pops up tomorrow.
mzumel is offline
