For those of you that don't know what an ATP VES is - it's a boost actuated exhaust dump. The valve opens at 10psi and dumps the exhaust. Anything less than that, the exhaust will flow through the stock exhaust (or whatever exhaust is in place)
We all know that the best performing exhaust for a turbo car is 'no exhaust' That being said, I'm wondering other peoples thoughts regarding how the ECU would deal with this decrease in backpressure. Obviously it will allow the engine to flow more easily and the turbo to spool quicker. I'm wondering if any of that can or will affect how the ECU reacts. And if so, will it react adversely. Your thoughts and productive comments are appreciated.
almost done |
Strangely I think you would want it to do the opposite. Have it dump the exhuast under 10psi to let the turbo spool faster, then close. Once the turbo is spooled (assuming you have an aftermarket free flowing exhuast) I don't see a cut out being a huge boost. But the decrease in inital spool time might be awesome, even in between shifts.
"NASCAR is the Bose of auto racing. Makes a lot of money but ain't worth crap" 2006 Black Mica Mazdaspeed 6 Sport 2003 Vibrant Blue Sentra SE-R Spec-V - R.I.P 1/11/07 Auto-X fun |
#4 (permalink) | |
Unless you have a large slow spooling turbo I don't think it's necessary-our tiny turbo can already hit 20+ psi by 2500 rpm. Without some very effective boost control, you'd just end up with a very large boost spike.
<div class='quotetop'>QUOTE Quote:
that screams boost creep... you would need some management for that.
06 Speed6 GT- whitewater pearl w/ white and black leather and nav mods: ACT street clucth, ATP downpipe, AWR pass motor and tranny mount, CP-E cai, CP-E rear motor mount, CP-E catback, CP-E hpfp, CP-E FMIC, denso ITV-24 plugs, EBC redstuff brake pads, EGR delete, F2 BSD, HKS Twin Power Ignition, Koni Yellows, OCC, prosport boost gauge in vent pod, Rotara slotted rotors, PTP windage tray, RPM test springs, SPC ball joints, Synapse BOV, TT diff mount, TWM short shifter, whiteline rear sway |
So boost creep is the main source of concern?
I was really wondering if the ECU is going to freak out and go lean or something - who knows... only time will tell.
almost done |
#7 (permalink) |
Yeah, I think that's why 4drhtrd's motor blew. QTP's cutout is switched electrically, so that one might be better for this ECU.
V-Band Catless DP//Corksport CBE//Liquid-Air IC//GReddy Type-S BOV//GReddy Profec E-01 BC (first)//SU, AWR, & TT motor & diff mounts//TWM STS, bushings, & Desert Eagle knob//Walbro 255lph high pressure in-tank fuel pump (first/only)(I want more!)//F2 BSD//PTP Windage Tray//Redline hood struts//Stoptech Slotted Rotors w/ PosiQuiet Semi-Metalic Pads all around//WOT Box (first)//Kenwood 1800W RMS system (infinate baffel) |
#8 (permalink) |
i had the qtp on my car for afew months but with the stock boost controler the car was spikeing at 21-22 in first gear, this scared me so i removed it and put it on my drag car.
qtp is cheeper and better than atp's cut out. the qtp on my drag car is wired to a wot swich and my nos window switch to control when it opens and when it shuts, also adding a reostat you can control how much it opens to control boost spikes and creep i love the qtp cut out but i cant stand qtp's customer service also if you buy one they are $50 cheeper at summit than qtp's web page.
![]() "When you can leave black marks from the exit of every turn to the braking points of the next turn, then you have enough horsepower." "Oversteer is when you hit the wall with the back of the car. Understeer is when you hit the wall with the front of the car. Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it." 06 Black Cherry Mica Speed6 |
#9 (permalink) | |
As far as QTP vs. VES - there have been numerous complaints about the QTP electric motor frying due to the heat involved. On a drag car I could see it working since it's not running for hours on end. The VES is completely mechanical so there aren't any issues w/heat.
almost done |
#10 (permalink) |
I am seriously debating the QTP cutout.
I honestly don't like the drone these catbacks are making. I ran one on my p5...it was lounder than a mack truck.... I currently have Street Unit TP and intersted in having it welded into it! -C
Current Mods: Wouldn't you like to know |
