There are a bunch of spark plug threads floating around so I thought why not take a few pics and post a how to for those that may not have changed plugs on the speed or on any car for that matter.
OK There is probably some ifo that could be added along the way but here is what I do know The stock relacement NGK plug part number is ILTR6A-8G one step colder part number is LTR7IX-11 I'm installing the one step colder NGK's in the pics I bought a set of stock heat range plugs and 1 step colder plugs from www.clubplug.net you can get either heat range plug for under 12.00 each compared to 19.00 and up offered at some other vendors HKS makes 2 heat ranges as well this is a cut and paste from the HKSUSA site: M-Series Super Fire Racing Plugs 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 1 $22.97 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 1 $22.97 as for the install it's very staight forward with common tools.... first remove the intercooler shroud by taking the 2 - 10mm bolts off and sliding the shroud back toward the firewall for removal ![]() next start removing the your TMIC (top mounted intercooler) by taking off the 3 - 12mm mounting bolts there are two in the front, one in the rear of the TMIC ![]() ![]() next remove the vacuum line to the BOV(blow off valve) and remove the lower hose clamp by the throttle body this hose clamp can be loosened with a phillips screwdriver or a 10mm socket ![]() and lastly to remove the TMIC, loosen the hose clamp on the rear of the intercooler also 10mm or phillips screwdriver ![]() pull up on the rear of the intercooler seperating the intercooler from the rear hose connection - then wiggle the intercooler back and forth to free it from the front lower hose connection by the throttle body once the intercooler is off and set aside, remove the 4 - 8mm bolts that hold down the coils then simply pull up on each coil carefully ![]() now you are ready to remove the spark plugs using a 5/8 spark plug socket(has rubber in the socket to hold the plug in place while removing and installing) ![]() ![]() once they are removed, reinstall everything in reverse order I gapped my plugs at .32 Please be careful when doing this I personally use feeler gauges when gapping plugs to ensure proper gap. I don't trust the cheesey spark plug tools from auto stores. I use a Jacob's Electronics plug gapper on standard type plugs but irridium tip plugs are very fragile so feeler gauges are the way to go IMO I also use electric grease on the spark plug boot/coil before re-installing plus ***very important*** use a small amount of anti-seize on the new spark plug threads to allow for easy removal in the future. ![]()
2006 Mazdaspeed 6 386awhp/376awtq beat that! intake Performed by whoosh |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) | |
Thanks so much for the post and great pics. I have a question about the valve cover 'valley'. Is there any way for water to drain out of that valley, or is it closed on all 4 sides? I've lost 2 coilpacks to what the dealership is calling 'water intrusion'. The tech noted that he found standing water during this procedure and I was wondering where in the world that would have been until I saw your pictures.
Thanks
___ ___ ___ ___ ___ ___ |
#5 (permalink) | |
as for the valley area, I didn't notice any type of drainage holes or passages I think if you have a lot of water in there, the only way to remove it is letting the engine heat burn it off evetually or to dry it with a rag I wonder how you are getting so much water in there unless you are continually steam cleaning the engine compartment or using bags of ice over the intercooler between rounds at the track????? Either way, try to keep water out of there if possible. If you pack the connector and boot with electril grease when dry, that would kinda help your situation but keep;ing water away from the coils is seemlingly key
Strangely enough, the first coilpack failure came shortly after driving in a very hard rain. I keep the engine bay clean via wiping down with microfiber cloths and mild cleaning agents, and I noticed the day after the heavy rain that there were tons of dirty water spots all up inside the hood ducting, indicating that rain water or water coming off other people's tires were going through the ducting. I don't know how much water made it to the valve cover, but the following day on my way home (80 mile drive) suddenly I had a coilpack failure on #2.
I had the same thing happen 2 weeks ago, the day after I washed the car (not the engine) at the coin-op car wash. I always dry underneath the hood, and I noticed that I once again had water in the ducting from the high pressure spray aimed at the nose during the wash, and the next day....fried coilpack again. This time #3. It wasn't completely clear to me what the technician noted, whether he actually found water, or found that water HAD BEEN there, but they added to my work order that washing the engine is a no-no. Imagine the problems I'd have if I washed the engine. Kind of a bad design, IMO. Since there's a direct path from the nose of the car to the intercooler, and down on top of the valve cover, drains would seemingly be essential. Thanks for the info!
#7 (permalink) | ||
2007 MSP GT Black Mica ~ CPE CAI ~ TWM Stage II short shifter w/bushings ~ Forge BPV ~ Focal 6.5 Component K2 Power & Focal Polyglass VR 6.5 2-Way-Focal ~ K2 Subwoofer ~ Alpine 1000W mono ~ Alpine 4x150W ~ JBL Clean Sweep ~ "1" Farad Capacitor ~ RPM Street Springs ~ Bilstein shocks ~ 25% Tint ~ OZ Superleggera III Wheels ~ |
#8 (permalink) | |
I'm running the BOV VTA and it isn't that loud especially since I installed the Greddy anti-stall valve
#10 (permalink) |
Groaned at 5 Times in 1 Post
I posted this in the other spark plug topic but no one has responded. Sorry for the double post but I thought this topic was more appropriate as this is where whoosh first mentioned his new plugs.
So this is from the NGK website. I'd really like to go a step colder also but I'm concerned about the reach difference of the two plugs. I'm too much of a noob to know if this matters but it seems like the colder plug might not extend into the cylinder as far as the oem. Will this have an effect? The gap is also pretty different. I guess it could be fixed but I've always heard that Ir plugs were fragile. stock heat range replacement NGK ILTR6A8G Stock Number: 3787 Iridium plug, 14mm, 26.5mm reach, 5/8" hex, tapered seat, resistor, extremely long life plug, special firing end construction, iridium center electrode with platinum tipped ground electrode, .032" gap 1 step colder NGK LTR7IX-11 Iridium IX plug, 14mm, 25mm reach, 5/8" hex, tapered seat, resistor, fine wire (0.6mm) iridium center electrode, tapered cut ground electrode, .044" gap
2008 BMW 335i 4dr 6MT w/ sport package, black/black |
| The Following User Says Thank You to Dadasracecar For This Useful Post: | STLSpd6 (08-19-2012) |
Advertisement | |
