Hitachi-Warner K04-022-881 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 30 (permalink) Old 08-17-2006, 09:11 PM Thread Starter
Well I'm not sure whether anybody has ever verified the model of the Mazdaspeed 6 Turbocharger before, but I found I could see the identification name plate on the turbocharger by using a 1 million candle power flashlight( it was dark) and looking from the front of the engine, kind of under the straight snorkel piece of the CAI, back towards the big hose that goes straight down to the snorkel of the turbocharger, from the back of the I/C. You can see where the CAI hose attaches to the hub of the turbocharger ( where the impellers are, center of the snail, so to speak) and just underneath the hub is the identification name plate and is clearly visable to someone with good eyesight.........my son. He didn't have any idea what it was supposed to say, so I'd say that it's a pretty safe bet it's a K04-022-881 as that's what he read off it to me.
I was kind of hoping Mazda had used a little larger model............but oh well, we'll just have to make do with what we've got ...........HA HA HA ya just until we modify it, of course.
Anyway, I hope that is of some help.
2006 Mazdaspeed 6 GT Liquid Platinum/Black Leather/Moonroof/Tint/AEM CAI/Defi Meter BF Boost Gauge & Control Unit / HKS SSQ BOV / ELF Evolution 5w/30 Full Synthetic Ultra High Performance Oil/ RedLine 75w-90 Full Synthetic in the rear end and PTO (Tranfer Case)/ MT90 Full Synthetic in the transmission. (Defi Meter BF Oil Pressure/ Exhaust Temp./ Water Temp./ Lo-Tek Dash Gauge
Beltronics Vector FX2 #'s
1/4 Mile: ET 13:37 @ 102 MPH
1/8 Mile: ET 8.60 @ 81 MPH
1000 ft: ET 11:17
60 FT: ET 1:72
0-100 MPH ET: 12:50
0-60 MPH ET: 4:90
rocket 6 is offline
post #2 of 30 (permalink) Old 08-17-2006, 09:17 PM
Send a message via AIM to More cowbell
yeh it was posted while back. Its the same turbo used in audi TT 225hp model 1.8t. This turbo is way undersized for a 2.3L direct injected high compression motor.
Mazdaspeed6 with LS7 swap and rwd conversion.
More cowbell is offline
post #3 of 30 (permalink) Old 08-17-2006, 09:20 PM
WhightLightn's Avatar
I wouldn't say that.
It's sized perfect for the results Mazda wanted.
For us speed nutz...yeah a 16g size would've been a good starting point thank Q.
WhightLightn is offline
post #4 of 30 (permalink) Old 08-18-2006, 12:20 AM
MrTea's Avatar
Quoted: 38 Post(s)
for those that get Sport Compact Car, the newest issue covers the speed3 and says it uses the same turbo as the speed6 (which we know)
"for a stockturbo, it has a lot of trick features, including a compressor stage supported by a full-floating, journal-bearing, water-cooled center section. Power balance is supported by a 79 trim 50mm turbine stage with an Inconel shaft-wheel mated to a 16.5mm A/R Niresist iron turbine housing. Maximum turbine speed is over 165,000rpm with a peak eshaust gas temperature in excess of 990 degrees Celsius."
goes on to say on pg 73, on ways to make it better....
"Since the engine came from teh 274bhp Mazdaspeed6, we know the turbo can handle a bit more boost, though it's approaching it's intended design limit. This is a cautionary not to you tuners: you can't simply add a boost controller and turn up the wich for more power. If you do, you run the risk of running lean and as well spinning the turbo faster (over-speed) than is safe or efficient and potentially destroying your engine...."
it also says the DISI system is being used on Begenholtz 1400hp drag car. i don't know how much Golden Eagle knows about the tuning side of the car. but they build the engines for him, so it might be worth shooting them an email (i'd actually call, as they don't do electronic stuff much) and seeing what they use on the system if you want big HP and worry about fuel.
just some reading tonight
MrTea is offline
post #5 of 30 (permalink) Old 08-18-2006, 01:50 AM
They use a direct injection methanol system. Similar to a diesel (methanol) truck puller system. Our system is definitely not methanol compatible. But I'm not sure what they are using for a HP fuel pump, but I would like to get my hands on one.
turboaz2 is offline
post #6 of 30 (permalink) Old 08-18-2006, 06:10 AM
Wiggum's Avatar
Interesting read, thanks man...
2006 Mazdaspeed6 - Grand Touring w/ Moonroof - Black/Black-
2005 Mazda6s - Fully loaded w/ every option but ATX - Steel Gray/Black (SOLD) -
2006 Mazda6i - Sport package w/ Bose/Moonroof ATX - Dark Cherry/Black -
Wiggum is offline
post #7 of 30 (permalink) Old 08-18-2006, 12:35 PM
Quoted: 138 Post(s)
Groans: 5
Groaned at 8 Times in 6 Posts
yeh it was posted while back. Its the same turbo used in audi TT 225hp model 1.8t....[/b]
not convinced yet. if the compressor wheel is 2.4" dia, its's like a K04 hybrid, perhaps with K26 compressor. the audi TT does not have a 60mm (2.4") compressor wheel.
From Car and Driver:
"In Mazda’s new direct-injection version of the MZR 2.3-liter inline-four, fuel is squirted at 1885 psi directly at the spark plug for better atomization and more thorough burning. Mazda wanted the engine to flare, rather than explode, with power, especially from 2000 rpm to 5500 rpm, so the Hitachi Warner turbo, with 2.4 inches of compressor diameter, is on the small side for rapid spooling"
04 6S atx hatch
93 RX-7, 75 Trident
KevinK2 is online now
post #8 of 30 (permalink) Old 08-18-2006, 01:06 PM
man do you guys just like to argue or is it a estrogen imbalance?? i give up.
post #9 of 30 (permalink) Old 08-18-2006, 05:01 PM
not convinced yet.
Ya, because magazines never get anything wrong... Nope, never.
grgaspar is offline
post #10 of 30 (permalink) Old 08-18-2006, 06:53 PM
Turbonetics T106 FTW.... LOL I'm a troll
2005 Mazda 6i Steel Grey - Magnaflow Catback, Airbox Mod, more to come
[x] Cat Back Exhaust
[x] Cold Air Intake
[x] Non Sport Appearance Package
[x] TEIN S-Techs
[x] Nex-O M-20's 18x7.5 w/ Yokohama AVS ES100's
[ ] Vibrant Header
1991 Eagle Talon TSi AWD - 11.467 @ 121.460 MPH stroked + GT42R
[x]DONE!!!
HawaiianEagle is offline
