Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Visual / Audio > Show and Shine
Old 09-20-2008, 07:38 AM   #1 (permalink)
MAZDA6charcoalgray's Avatar
Send a message via Yahoo to MAZDA6charcoalgray
When getting a new set of wheels what is one of the best ways to protect them? I dont want to use a harsh wheel cleaner, so I have read that is not needed to abuse the wheel. Mabe a wax or some kinda protectant coating, or cleaner before they are ever used. Just would like to do a little something before I put them on the 6. I think its aluminum wheels with machined lip.
MAZDA6charcoalgray is offline   Reply With Quote
Old 09-20-2008, 09:23 AM   #2 (permalink)
jd42's Avatar
QUOTE (MAZDA6charcoalgray @ Sep 20 2008, 06:38 AM)
When getting a new set of wheels what is one of the best ways to protect them? I dont want to use a harsh wheel cleaner, so I have read that is not needed to abuse the wheel. Mabe a wax or some kinda protectant coating, or cleaner before they are ever used. Just would like to do a little something before I put them on the 6. I think its aluminum wheels with machined lip.[/b]
I can highly recommend waxing the wheels. This makes cleaning the brake dust and road tar easier, and helps keep the nasty stuff from etching into the paint.
jd42 is online now   Reply With Quote
Old 09-20-2008, 10:40 PM   #3 (permalink)
any recomendations on a certin wheel wax or brand?
Old 09-20-2008, 10:46 PM   #4 (permalink)
QUOTE (MAZDA6charcoalgray @ Sep 20 2008, 08:40 PM)
any recomendations on a certin wheel wax or brand?[/b]
+1 on waxing. Just use a good car wax, the same thing you use on the painted part of the car. The wheels are painted after all.
RacerRik is offline   Reply With Quote
Old 09-21-2008, 08:31 AM   #5 (permalink)
ka-boom's Avatar
Also, look into ceramic brake pads if you dont already have them. They will cut down on the brake dust.
Simply Green seems to be a popular solvent for cleaning. Non-toxic, and works well.
The early worm gets eaten by the bird.
ka-boom is offline   Reply With Quote
Old 09-21-2008, 09:24 AM   #6 (permalink)
TNM6i's Avatar
There is a specific product for wheels called Wheel Wax. Some parts store carry it, but it can also be found online. Regular car wax works good, but if it's carnauba-based, the high heat from the brakes will shorten its life span. Carnauba has a low melting temperature and probably won't last over 3 weeks due to the high heat the wheels see. The Wheel Wax is specifically formulated for higher heat and should last longer. Also, any car "Sealant" should work well. They are polymer/acrylic-based and can take the higher temps.
<span style="font-family:Tahoma">2006 6i Grand Sport | Glacier Silver Metallic
Smoked LED Rear Reflectors | Smoked LED Sidemarkers | LED Lighting | CX-7 Antenna | Airbox Mod | 17" Enkei RP03s
Future Plans: Window Tint | Painted Calipers/Hubs | Racing Beat Axle-Back Exhaust
</span>
TNM6i is offline   Reply With Quote
Old 09-21-2008, 07:43 PM   #7 (permalink)
Drizz-OH's Avatar
Send a message via AIM to Drizz-OH
QUOTE (MAZDA6charcoalgray @ Sep 20 2008, 03:38 AM)
When getting a new set of wheels what is one of the best ways to protect them?[/b]
Don't scrape them on curbs...
Drizz-OH is offline   Reply With Quote
Old 09-22-2008, 07:45 AM   #8 (permalink)
oh man I know, if i do curb it im gonna shit my pants and curse myself. But ive been pretty good about not curbing it, only done it once. I take a look and see about a wheel wax, thanks everyone for the replys.
Old 09-27-2008, 10:46 AM   #9 (permalink)
+1 to wheel curb
teleopti is offline   Reply With Quote
Old 10-01-2008, 09:50 AM   #10 (permalink)
Scott P's Avatar
Poorboy's Wheel Sealant works very well to protect the wheels. A Google search will find a distributor that carries it. Use your regular car wash solution to wash the wheels after that.
2006 MS6 Grand Touring - Titanium Gray Metallic
2008 CX-9 Grand Touring - Stormy Blue Metallic
Scott P is offline   Reply With Quote
