idrives Build Thread - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 24Likes
post #21 of 75 (permalink) Old 05-31-2018, 10:18 PM
Dougspeed's Avatar
Quoted: 43 Post(s)
Very cool, I will eventually change out the wheels in the future with similar specs to what you're planning except maybe running a 245/40/19 to stay closer to the overall diameter of the factory wheel/tire combo. But for now, I'm gonna put some mileage on the stock tires. I'm looking forward to see which style of wheels you end up going with once you decide on the fitment. I'm also curious to see how the car handles with the larger sway in back.
Dougspeed is offline
post #22 of 75 (permalink) Old 05-31-2018, 11:35 PM Thread Starter
idrive's Avatar
Quoted: 122 Post(s)
Thanks and you're right about tire size that kind of slipped my mind. Going wider usually goes a little taller. Something I'll be needing to pay close attention to. May end up with a 40 rather than a 45 to make this fit. I can already tell it's going to be close. I'm thinking I may have to consider a -40 offset rather than -35.
2018 Signature
White Pearl - Chestnut
idrive is online now
post #23 of 75 (permalink) Old 06-01-2018, 05:01 PM Thread Starter
idrive's Avatar
Quoted: 122 Post(s)
Installed the Tanabe Tower Strut Brace today. I've installed a couple before but did something a little different this time. Found it from reading all of the literature while researching. It was part of the information on their website but interestingly not mentioned in the instructions that were supplied.
Installed the two brackets on the strut tower and then before attaching the brace we lifted the front end off the ground taking the weight off of the tires, attached, adjusted the strut bar, torqued everything down and then lowered the car back down. I hadn't ever heard of or lifted the front wheels off the ground before installing the brace/bar. It's also the first brace I've installed that is adjustable. Certainly made for an excellent fit.
Even on the short drive home the difference with lowering springs on the front and the tower brace installed was noticeable. Now I just need for the rear sway bar to hurry and get here to get it installed and replace the rear springs.
93blkongreenpro likes this.
2018 Signature
post #24 of 75 (permalink) Old 06-01-2018, 09:39 PM
Dougspeed's Avatar
Quoted: 43 Post(s)
That's a pretty strut bar, it looks very similar to the Mazda Soul Red Crystal paint.
idrive likes this.
post #25 of 75 (permalink) Old 06-03-2018, 09:45 PM
Quoted: 180 Post(s)
@idrive did you have any problems with the horizontal attachment bolts on the strut bar. I didn't follow the instructions with regard to tightening procedure? I tightened mine incorrectly and really bent them. Blew my mind the amount of bend I put in that M10 bolt. I had to cut it to get it out.
Your build is awesome by the way!
idrive likes this.
Modifications:
DrFeelGood is online now
post #26 of 75 (permalink) Old 06-03-2018, 10:00 PM Thread Starter
idrive's Avatar
Quoted: 122 Post(s)
Originally Posted by DrFeelGood View Post
↑↑ boggles the mind really... ↑↑
Anyhow...my parenting class says that when my 2-year-old displays behavior I do not approve of I should ignore it and re-direct.
Que redirect.
With the tower bar being adjustable the brackets were attached without the bar being attached so there wasn't any pressure on them. Then raised the wheels off the ground and attached the bar, adjusted it so it was nice and snug and then dropped the wheels back on the ground. No bending, everything nice and snug. Is that what you're asking me.
DrFeelGood likes this.
2018 Signature
post #27 of 75 (permalink) Old 06-04-2018, 07:30 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2677 Post(s)
Great thread so far. Keep up the good work.
Cleaned up the trash as well. @Mazda6Suspension ever heard the phrase "if you don't have anything good to say, don't say anything"? Either way: now you have. If you want to make unexperienced comments about things you've only read from other forums, please keep them in your own threads.
DrFeelGood and idrive like this.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #28 of 75 (permalink) Old 06-04-2018, 05:09 PM
Mazda6Suspension's Avatar
Quoted: 385 Post(s)
Groaned at 39 Times in 32 Posts
I agree
Last edited by Mazda6Suspension; 06-04-2018 at 05:26 PM. Reason: I can be a good guy too
Mazda6Suspension is offline
post #29 of 75 (permalink) Old 06-04-2018, 10:25 PM
bleevit's Avatar
Quoted: 4 Post(s)
Originally Posted by idrive View Post
Tanabe Coils and Strut tower bar are on the way. Expect to have them installed within about 10 days. They don't make a anti sway bar for the rear so looking for another option.
Curious where you purchased the Tanabes from? I'm assuming these are the NF210s?
2018 Grand Touring - Machine Grey Metallic
bleevit is offline
post #30 of 75 (permalink) Old 06-04-2018, 11:00 PM Thread Starter
idrive's Avatar
Quoted: 122 Post(s)
Yes, NF210's - purchased those from the "for sale" here on the forum under the suspension section. You'll notice he just closed his "for sale" ad a week ago. Good Guy BTW
The tower brace was purchased from:
www.sparktecmotorsports.com/tanabe-chassis.html - they shipped the next day after ordering.
I purchased the rear anti sway bar from:
ultraracing-usa.com/mazda-6-jg-2012-2016-rear-anti-roll-sway-19mm/
They sent me a message the day after ordering which I didn't see for a couple of days. Said the bar was in production. I have written back asking for an ETA and have not heard back. I really wish Tanabe made one. I would have ordered theirs.
Edit:
Guess I need to check the front porch more often. Just looked out and the OEM accessories box was sitting there. Going to be a hot one here tomorrow so will be getting up early to do the installs.
Splash Guards front and rear, footrest, brake and accel. covers.
2018 Signature
