as described in title
and i believe im the first one to have this setup? anyways, here's the soundclip Youtube Clip |
u should do a drive-by ... and/or drive-around...
lets hear how it sounds like on the road!
say w0rd. |
i had an exhaust leak shortly after, probably due to new bolts being in place, and vibrations and what not, got them tightened again. that fixed it.
just switched out the PCV and it's hose for new ones. having some tapping noise from the engine, might be the tensioner pulley, need to lube it. or it could be some bad valve clatter. sooo, im going to be switching to schaeffer's supreme 7000 5w-30 oil, hope that helps with the clatter. AND, i need to do a ATF flush, car's been shifting bad, especially in 100+ weather right now, also switching to schaeffer's ATF. |
#7 (permalink) |
"schaeffer's supreme 7000 5w-30 oil"
Perfect choice of oil! You'll like it.
![]() 2006 Mazdaspeed6 Grand Touring Liquid Platinum Metallic http://www.mazdaclubkc.com AEM cold air intake; Magnaflow cat-back exhaust; CP-E motor mount; Eibach Pro-kit springs (waiting install) |
