Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > General > Other Cars
Old 07-21-2009, 01:25 PM   #1 (permalink)
lapisbluinhou's Avatar
Nissan Dual Injector System for improved fuel efficiency in small-displacement engines
Nissan today announced it has developed a Dual Injector system designed to improve fuel efficiency in small-displacement gasoline engines. The new fuel delivery system, claimed to be the first of its kind, uses an injector for each port rather than one per cylinder – speeding up fuel vaporization, reducing the amount of unburned fuel and reducing hydrocarbon emissions. Nissan will put the system into production vehicles beginning twelve months from now.
While most current gasoline engines utilize one injector per cylinder (furnishing fuel to two intake ports), the new Nissan Dual Injector system doubles the number of injectors per cylinder. This reduces the diameter of the fuel droplets by about 60%, resulting in smoother, more stable combustion.
The system also adds continuous valve timing control on the exhaust side to conventional intake-side control, improving heat efficiency, reducing pumping losses and raising fuel efficiency by up to 4% (compared with Nissan gasoline-powered engines in the same class) in sync with the dual injectors.
 While similar in theory to “direct-injection” systems, which also inject fuel directly into cylinders, such direct injection systems are difficult to use on small-displacement engines because they require a high-pressure pump that complicates system design, making component layout less cost-efficient. In contrast, the Nissan Dual Injector system is lighter and structurally simpler because it furnishes fuel at normal pressures, reducing cost by about 60% compared to direct-injection engines of similar displacement.
The new Dual Injector system also uses half the amount of rare metals in the catalyzer while maintaining the efficiency of the catalytic conversion system. That number could potentially be reduced to 75% in combination with the ultralow-rare-metal catalysts that were introduced in 2008.
“We consider it important to further improve the fuel efficiency of gasoline engines as demand for gasoline and other internal-combustion systems continues to increase around the world,” said Shuichi Nishimura, Corporate Vice President, Nissan Powertrain Engineering Division. “By widely applying the Dual Injector system on small-displacement engines, we hope to help reduce CO2 emissions and conserve rare metals.”
Nissan has been addressing a wide range of actions under “Blue Citizenship,” which represents the company’s desire to protect the blue planet and to be a corporate citizen that can live symbiotically with people and society.
These efforts range from such global issues as the environmental protection to contribution to communities, promoting diversity and making personal mobility available to as many people as possible. Nissan continues promoting the “Nissan Green Program 2010,” based on the “Blue Citizenship” spirit by introducing effective technologies, products and services into the market.
2004 Mazda 6S-V6 Hatch:
<strike>K&N Air filter w/Airbox mod</strike> l Grounding Wire Kit l B&M 24,000 GVW Transmission Cooler l 20% Tint l Euro clear side signals l 5w-20 Fully synthetic Engine Oil w/K&N Oil filter l TB Coolant Bypass l Mesh Grill l Car PC l 7" Lilliput TFT touchscreen l Yokohoma Avids l 35w Apexcone HIDs l Angel Eyes l CPE Engine Mount l <strike>Pulse-star spark plugs</strike> l EGR Mod l Weapon X Coils l Fan Control Module l <strike>Pulse-star spark plugs</strike> l 160 Degrees Thermostat l NGK IX's l Racing Beat rear Sway Bar l CPE MAFci l Optimized Throttle Body l K&N Air Filter l AWR Transmission Mount 88 Duro l Redline D4 l Magnefine Transmission filter
lapisbluinhou is offline   Reply With Quote
Old 07-21-2009, 03:24 PM   #2 (permalink)
smokeU6s's Avatar
Send a message via AIM to smokeU6s
Good find!
I wonder what the performance/economy would be to a comprable GDI engine. Guess we'll know in 1 year
All Black Mazda6s 04 ATX 5door | Bose | Moonroof | CP-E MAFci Intake | Painted Yellow Calipers | Magnaflow catback | B&M tranny cooler | Magnafine Transmission Filter | Anzo Clear Side Markers | Weapon X Coil on Plugs
smokeU6s is offline   Reply With Quote
Old 07-29-2009, 09:14 AM   #3 (permalink)
Its applauded, but I would certainly like to know what cars this will be available in.
The first thing you should know is that we have people everywhere.
R1 Brakes
Confuc1ous is offline   Reply With Quote
