Low beam headlight problem - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Mazda6 (Atenza) > Newbie Section
New User? Register
Old 11-20-2012, 02:14 PM   #1 (permalink)
Default Low beam headlight problem
I have a 2004 6I a bought used a couple years ago. I have a headlight problem that I'm trying to diagnose. The passenger side low beam doesn't work. I put in a new H1 bulb and it didn't work. I discovered the dust cover was missing and the black plastic surrounding the wire connector to the back of the bulb was cracked. I either got the car like that or the mechanic at Meineke muffler I asked to change the bulb awhile back during an oil change didn't put the dust cover back on correctly and it fell off and probably cracked the plastic on the wire connector squeezing it too tight with pliers as he tried to reconnect it. It's not easy to see in there and he probably was unfamiliar with the car. In any event he said he put the new bulb and in it didn't work, told me I had a short somewhere he was too busy to fix and pretty much made it clear he didn't want to work on it anymore. I guess I should have checked out his "work" before I left
In any event I'm trying to fix this problem myself because I don't have cash to spend on the dealer to find it for me. I tried another new bulb and replaced the wire connector with a 18-22 wire connector that looks the right size I got at O'Reilly AP. Still nothing. Can anybody help me diagnose where the short might be? What do I try next? Any help would be greatly appreciated!
markg8 is offline   Reply With Quote
Old 11-20-2012, 02:24 PM   #2 (permalink)
Shiro Shinobi
Byakuya's Avatar
Quoted: 715 Post(s)
Welcome to the forum!
Those plastic caps break if you breathe on them.
Have you checked all your fuses? All the grounds?
My thoughts are that if the dust cap was off, water got in and fried something. Check fuses.
2014 GT, NE Meets, The Great Mazda Climb, and NEW NEM6.com!
TiGraySpeed6: "Back to class youngster, and get off my lawn!"
Legacy4Life: "Nothing like a good day of raunchy car talk."
6Y Mazda "One million horsepowerzzz"
Sold: 2004 V6 GT
Byakuya is online now   Reply With Quote
markg8 (11-21-2012)
Old 11-20-2012, 03:56 PM   #3 (permalink)
Final Impact's Avatar
Quoted: 194 Post(s)
Take a look at this; Although it's from an 06 it may be helpful.
>79,000
markg8 (11-21-2012)
Old 11-20-2012, 05:33 PM   #4 (permalink)
Thanks for responding guys. I checked the fuses and they're good though one was in backwards which I switched. I'm not experienced at reading electrical schematics so just to be clear, the passenger side front low beam is the right or the left lo beam in that drawing Final Impact? As for the ground I am assuming it is the other wire attached to the back of the housing were the bulb goes in. It's to the outside side of the bulb right? How would I check that? I guess I also ought to check and see if there is power in the wire going into the back of the bulb too right? And the 06 ought to be the same as an 04 right? I'm assuming they didn't change much in the way of electricals in these cars as they're the same generation.
Old 11-21-2012, 03:28 AM   #5 (permalink)
Quoted: 194 Post(s)
in the auto world everything is referenced from the drivers view looking through the windshield.
So does yours have 4 fuses? 2 for L&R high and 2 for L&R Low beams?
Mine has HID so I don't have a clear image of what's broke. What you need is DMM or a 12V test lamp. Because you have one GOOD side you can compare readings.
With a DMM (Digital Multimeter) or a 12 volt test lamp you can connect one side to Battery POS and probe the housing ground lead on both sides. The light should light showing you have a path to ground. It will be good on one side and may be bad on the other side OR it may be fine. If you lost the ground we can fix that.
Next repeat the test using your leads and connect one side to the NEGative terminal of the battery. Now turn on the light and probe to find 12V for the left and right HIGH and LOW beams. What do you find??? Report back. . .
>79,000
markg8 (11-21-2012)
Old 11-21-2012, 03:48 AM   #6 (permalink)
Markg8, where in the world are you?
grim_reaper is offline   Reply With Quote
Old 11-21-2012, 12:26 PM   #7 (permalink)
I'm in Downers Grove Illinois, USA Grim Reaper.
Old 11-21-2012, 12:29 PM   #8 (permalink)
Yeah, checked 'em all and they're good.
I'll go get a tester and let you know what I find.
Old 11-21-2012, 01:37 PM   #9 (permalink)
Quoted: 194 Post(s)
IIRC it has 4 fuses but honestly I have to look.
A test lamp or cheap DMM can be found at just about any automotive store. If you don't have any electrical wire and butt connectors/crimping tool you might grab some.
I'm not sure what wire to recommend but suspect its 12 or 14 gauge so you might grab both and some connectors for that size.
>79,000
Old 11-21-2012, 02:45 PM   #10 (permalink)
Ok I used the probe I bought and have power to both hot wires on the L& R low beams. I did this by attaching the alligator clip to the body and sticking the probe in the hot wire connector on both sides and then again by connecting the a-clip to what I assume is the ground on the back of the bulb assembly too. Lights up all 4 times on both sides but still no low beam on passenger side.
