PCD stage 1 and 2 performance chips - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 09-15-2012, 04:35 PM Thread Starter
So ive already ordered these chips from pcd should be here in a few days but was wondering if anyone else has installed a chip, if so what were the results, if any?
mitchellallan26 is offline
post #2 of 7 (permalink) Old 09-15-2012, 04:46 PM
Quoted: 399 Post(s)
Groans: 16
Groaned at 4 Times in 4 Posts
What car do you drive? Most chips are snake oil...
tapatalking.. err wait.
xkreedx is offline
post #3 of 7 (permalink) Old 09-15-2012, 06:24 PM Thread Starter
04 6 s 5speed 3.0, just installed full cold air intake (HUGE difference thru 3rd), everything else is stock. Wondering if these chips will over ride the governor and if they will recalculate my air ratio so that my check engine light goes off (reading all four o2 sensors)
post #4 of 7 (permalink) Old 09-15-2012, 06:38 PM
Quoted: 399 Post(s)
Groans: 16
Um no. Get a refund buddy. You need a tuning solution not a worthless chip
xkreedx is offline
post #5 of 7 (permalink) Old 09-15-2012, 06:42 PM
100% CANUCK
Mr.Smoke's Avatar
Quoted: 1294 Post(s)
Groaned at 8 Times in 8 Posts
There isnt a chip out there for our cars that actually does something. The ECU is always learning so even if one was able to do anything it wouldnt be for long.
The codes are likely from your intake. An air straightener will fix that right up most likely.
Mr.Smoke is online now
The Following User Says Thank You to Mr.Smoke For This Useful Post:
mitchellallan26 (09-15-2012)
post #6 of 7 (permalink) Old 09-15-2012, 07:16 PM Thread Starter
It was throwing that code before i put the intake on but when i swapped them i found a split hose. Now hose is fixed didnt find any other leaks and still code. I also think its caused from to much air. Thanks
post #7 of 7 (permalink) Old 09-17-2012, 11:31 PM
MonoxideChild's Avatar
Quoted: 18 Post(s)
Groans: 66
iTrader: 2 reviews
there isnt a single 'Chip" out there for our car. anyone that is selling you one. is selling you something that will not work for your car no matter what BS there spoon feeding you.
MonoxideChild is offline
