Replace headlight bulb - 2004 Mazda 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 17 (permalink) Old 03-07-2010, 11:55 AM Thread Starter
Hello,
I am trying to replace the drivers side low beam headlight bulb on my 2.3 liter 2004 Mazda 6. The descriptions and pics I see in this forum do not seem to match what I am seeing under my hood. Any help would be much appreciated. Thanks....
I added some pics .... any thoughts ?
thanks
ID:	74278   Click image for larger version
ID:	74279   Click image for larger version
ID:	74280   Click image for larger version
mabmab is offline
post #2 of 17 (permalink) Old 03-07-2010, 12:14 PM Thread Starter
Hello,
I am trying to replace the drivers side low beam headlight bulb on my 2.3 liter 2004 Mazda 6. The descriptions and pics I see in this forum do not seem to match what I am seeing under my hood. Looks like the air filter would need to be taken out ? Any help would be much appreciated. Thanks....
mabmab is offline
post #3 of 17 (permalink) Old 03-07-2010, 04:23 PM
Send a message via AIM to jwomack Send a message via Yahoo to jwomack
maybe if you post a pic, or something someone here can help ya out....
jwomack is offline
post #4 of 17 (permalink) Old 03-07-2010, 10:58 PM
Spazdog's Avatar
Groans: 5
I don't remember having to take the airbox out. It's not fun, but I think I only had to remove my coolant tank on the passenger side (V6)
I used a pair of long curved needle nose pliers to feed it in and then clipped it down blind. It sucked but it can be done. (Careful, don't touch the capsule)
Spazdog is offline
post #5 of 17 (permalink) Old 03-07-2010, 11:45 PM
ryanrc03's Avatar
Groans: 7
Groaned at 6 Times in 5 Posts
drop the front bumper off like everyone else. It takes an extra 10 mins to get on and another 10 to put back on. That is the best way. Other wise you will need a mirror of some sort and some extra skin for your knuckles. Or a tiny hand
2005 6S V6 MTX Lapis Blue w/ black leather- Tint, 6000k HID's low and fog, "Matched" high beems, white LED "194" driving light, super white LED interior and license plate lights, debadged, car-led tail lights(amber turn) with brake light mod, stubby antenna
ryanrc03 is offline
post #6 of 17 (permalink) Old 03-08-2010, 12:17 AM
ok man it simple just unscrew the air pipe that connects to your air box from the air intake on the engine. pull up your air box you dont need to unscrew anything. now ope up the cover to your headlight, press upward on a little clip on the bottom of the cover. it will be your far left light. theres a clip holind it down so just push it upward as well and pull it back at the same time. then the light will pop out. good luck. if anything ill add more if you dont get it.
munky01 is offline
post #7 of 17 (permalink) Old 03-08-2010, 01:01 AM
Freak4Dell's Avatar
Quoted: 19 Post(s)
Yeah, the easiest way is to just drop the bumper and take out the headlight. It clears up so much space, and you don't risk cutting yourself up or anything like that.
Freak4Dell is offline
post #8 of 17 (permalink) Old 03-11-2010, 05:35 PM
I just did it lastweekend.
1)Place a screwdriver tip in one of the vertical holes on the light housing cover and gently tilt the handle back to remove the cover.
2) If your hands are small enough (mine are) remove the bulb and replace
3) snap the cover back in place
Icarus 402001 is offline
post #9 of 17 (permalink) Old 08-01-2010, 06:37 PM
I got lucky with my medium sized hands.. had to replace the drivers side low beam. The only thing that bothered me was that little clip that kept getting in my way when I tried to put the bulb back in place.
I figured to use a shoe lace to keep it 'up' and outta the way. Furthermore, before installing the new bulb i practiced with the broken one in order to know how to put it back in place. Picked up a new bulb and first try was succesfull.
Overall, it took my about 15 minutes. Thanks guys for the instructions!
nielsoosting is offline
post #10 of 17 (permalink) Old 10-19-2011, 01:37 AM
Send a message via AIM to Kubetsu
I tried... so far kind of good until I realized that passenger side would be a nightmare.
Removed bumper.. added an extra 20 min's of labor.. but I'm good with that.
Colorado Springs, Co - 2004 Mazda 6S 3.0L
Kubetsu is offline
