Water Dripping Under Car (Not Using A/C) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 09-09-2008, 08:36 PM Thread Starter
Was driving around today and I noticed that water is dripping under my car, underneath the engine. I am not using A/C.
I'm 99% sure it's water because I touched it and got it on my hands and it's not oily. Feels just like water and looks clear.
The only change I made recently was that I switched the temperature knob to being right in the middle. Normally I drive with it on cold (but not A/C) but it's getting a little chillier now so I changed the temp.)
Should I be worried about this?
2007 Mazda6i (4cyl, ATX)
If you drink, don't drive!
login2389 is offline
post #2 of 7 (permalink) Old 09-09-2008, 11:03 PM
GerryB's Avatar
Quoted: 197 Post(s)
Were you running in the "heat" position (as opposed to hi/lo or vent)? If so, the compressor could still be running - it's a Ford thing, although there is much debate about this. That's how it works with my auto climate.
GerryB is offline
post #3 of 7 (permalink) Old 09-10-2008, 12:00 AM
dfw6er's Avatar
I suppose an exhaust leak could also cause water to drip.....water is a product of combustion
dfw6er is offline
post #4 of 7 (permalink) Old 09-10-2008, 12:09 AM Thread Starter
QUOTE (GerryB @ Sep 9 2008, 11:03 PM)
Were you running in the "heat" position (as opposed to hi/lo or vent)? If so, the compressor could still be running - it's a Ford thing, although there is much debate about this. That's how it works with my auto climate. [/b]
What do you mean by "heat" position? The temperature knob was vertical so it was right in the middle between warm and cold.
post #5 of 7 (permalink) Old 09-10-2008, 12:34 PM
LapisLazuli6's Avatar
Quoted: 10 Post(s)
Send a message via AIM to LapisLazuli6 Send a message via MSN to LapisLazuli6 Send a message via Yahoo to LapisLazuli6
It doesn't matter what the temperatue knob position is, if you're in defrost or floor/defrost, the air compressor is running.
The water drips near the right front wheel for the AC compressor in mine, and we have the same engine.
-Paul
- 13 Honda Accord EX-L Obsidian Blue - purchased 4/23/13
- 10 Acura TSX non-Tech Grigio Metallic - traded @ 32k miles.. lost interest
- 06 Redfire 6i Sport - traded @ 102,611 miles, trouble-free motoring and fun!
LapisLazuli6 is offline
post #6 of 7 (permalink) Old 09-10-2008, 01:32 PM
Quoted: 68 Post(s)
Groans: 13
Groaned at 6 Times in 6 Posts
maybe your car is just really nervous.
xtmesisx is offline
post #7 of 7 (permalink) Old 09-13-2008, 08:10 PM Thread Starter
QUOTE (LapisLazuli6 @ Sep 10 2008, 12:34 PM)
The water drips near the right front wheel for the AC compressor in mine, and we have the same engine.[/b]
Yeah that was it. Forgot I had switched it to defrost a couple of days prior due to driving in the rain. Thanks.
