PCV Hose Replacement? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 09-04-2008, 11:11 AM Thread Starter
Can anyone tell me if this sounds right to you?
While idling, my car has been lurching forward, RPMs dip to stall then rev back up, AND the car stalls out. The dealer tells me the PVC hose is leaking and needs to be replaced. They tell me this is located under the intake manifold, which will need to be removed to replace the hose.
Parts = $70.00
Labor = 5 hours @ $103.00/hour for $515.00 total labor
Does this sound right or am I getting raked over the coals?
Oh, and the car is a 2005 Mazda 6i with about 63,000 miles.
calyank1184 is offline
post #2 of 7 (permalink) Old 09-04-2008, 11:20 AM
dfw6er's Avatar
Are you referring to the PCV (Positive Crankcase Ventilation) hose that goes from the PCV valve to the intake manifold?
PVC is polyvinylchloride...those white plastic pipes plumbers and landscapers use.
dfw6er is offline
post #3 of 7 (permalink) Old 09-04-2008, 11:24 AM Thread Starter
Yes, the PCV hose. I fat-fingered that one, my mistake.
post #4 of 7 (permalink) Old 09-04-2008, 11:40 AM
dfw6er's Avatar
That price seems kinda steep, as dealership service depts usually overcharge for their work. Unfortunately, I'm not familiar with the 4 cylinder engine, mine's a V6. Let me say that on my engine there is very little involved in changing that hose and it can be done in under 10 minutes. PM member twowheelin or moderator mrtea, as they'd probably be able to answer your question.
dfw6er is offline
post #5 of 7 (permalink) Old 09-04-2008, 03:37 PM
Banned
PCV Valve L325-13-890A Mazda retail - $11.33
PCV Valve Hose L341-13-895 Mazda retail - $45.98
From the parts breakdown, the valve is in a part called the oil seperator. That part is attached to block just below the intake manifold.
Sheldon.
MAZMART Sheldon is offline
post #6 of 7 (permalink) Old 09-07-2008, 02:04 PM
GraphiteM6's Avatar
Send a message via MSN to GraphiteM6
QUOTE (calyank1184 @ Sep 4 2008, 11:11 AM)
Parts = $70.00
Oh, and the car is a 2005 Mazda 6i with about 63,000 miles.[/b]
yes, they're trying to screw you. Although, I had this same problem a little over a month ago and my dealership quoted me $630!
Go to auto zone, or advanced auto parts, or any other local auto store and get some new hose. It'll cost you $10 and about half an hour to replace.
2003 Steel Grey 6i ATX -- Traded in after 5 wonderful years
2008 Garnett Ember G35 Sport
GraphiteM6 is offline
post #7 of 7 (permalink) Old 09-08-2008, 08:39 AM Thread Starter
Thanks for all the feedback. I dropped it off this morning at a different dealership. They quoted me two hours of labor to replace the hose, so they win my business for now. Dealerships are going to start realizing that they can't just arbitrarily quote people ridiculous prices like $600 for this kind of work when people have a world of information at their fingertips. Man, $600... Time to write a scathing review of that place!
