Coolant/antifreeze for the Mazda6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 14 (permalink) Old 03-14-2008, 10:53 PM Thread Starter
posttosh's Avatar
Quoted: 13 Post(s)
Here is the first part of the problem: -- there are two -different- formulas for antifreeze/coolant that are used in modern automobiles: - GM-spec Dexcool, or Zerex-spec G05.
Here's the second part of the problem:-- if you mix Dexcool and G05, you end up with a semi-solid gel that will destroy your cooling system.
So what is in the Mazda6 as delivered from the factory?
Mazda is not telling; Ford is not telling.
There are several threads on this board that speculate on what the factory fill is. None comes to a conclusion that inspires confidence.
If you need coolant, you can take your Mazda6 to the Mazda dealership, and they will refill it from the unmarked barrel of Mazda coolant.
But what if you want to top off your coolant yourself?
If it is Dexcool in there, adding G05 will turn your coolant to gel, and could cause engine damage.
If it is G05 in there, adding Dexcool will turn your coolant to gel, and could cause engine damage.
Whatever is in there, it is a good idea to flush and replace every couple of years. That is what we are going to do next week in our '04 which still has the original factory fill.
Our instructions to the (independent) repair shop:-- after flushing, fill with Zerex G05. The consensus seems to be that G05 has a slight edge over Dexcool.
So what are the rest of you doing?
posttosh is offline
post #2 of 14 (permalink) Old 03-15-2008, 12:33 AM
karlt10's Avatar
Quoted: 25 Post(s)
So what are the rest of you doing?[/b]
Besides looking at a dealer in Omaha who looked at me like 'What do you mean, 'Do I have Mazda coolant for sale?' Guy looked like I asked for the holy grail....
I will likely go the standard Prestone route. If the anti-freeze is changed on a regular basis, there is zero benefit in using long-life fluid. I'd rather save a few bucks by going to Costco, knowing I'll replace it in (at mose) 2 years anyway. Prestone, distilled water and RedLine Water Wetter has never let me down. The Prestone has equally superior protection for dissimilar metals, and Water Wetter only adds to that protection, in addition to helping the water remove heat.
Eibach springs / MazdaSpeed bars / Bilstein / Steeda Adj FR links / Racing Beat RR links / GTSpec Rear Susp & Trailing Braces / Steeda shock tower brace
EBC Ultimax rotors & pads / StopTech lines / Motul fluid
MSDS headers / Magnaflow cat / Racing Beat mufflers / Cork Sport urethane hangers / WeaponX coils / AER CAI / Fluidampr pulley
EGR mod / FilterMag / Street Unit engine mount /
B&M trans cooler / Amsoil fluid
Mazda iPod adapter
/ CX7 antenna
Continental Extreme DWS / Bridgestone Blizzak
karlt10 is offline
post #3 of 14 (permalink) Old 03-15-2008, 10:16 AM
Ericzoom's Avatar
I use Prestone LL 50/50 on my 04' M6s. I've done 2 drain-refills on the system, and don't see the need for a flush in my case. I figure i'll do it once a year to keep it fresh.
04' 6S ATX cooler,airbox mod
Ericzoom is offline
post #4 of 14 (permalink) Old 03-15-2008, 10:49 AM
TNM6i's Avatar
On my '06, Mazda specs FL22-compatible coolant/anti-freeze. I haven't researched enough to know which ones are FL22 compliant. Prestone or Peak, or one of the many other brands sells a "universal" pre-mixed coolant. They say you can add it to any color anti-freeze, any make/model. I haven't tried any of them yet, my coolant level is just slightly below the full mark, so no need to add. It would be better to just go back to the standard green stuff.
2006 6i Grand Sport | Glacier Silver Metallic
Smoked LED Rear Reflectors | Smoked LED Sidemarkers | LED Lighting | CX-7 Antenna | Airbox Mod | 17" Enkei RP03s
Future Plans: Window Tint | Painted Calipers/Hubs | Racing Beat Axle-Back Exhaust
TNM6i is offline
post #5 of 14 (permalink) Old 03-15-2008, 11:48 PM Thread Starter
posttosh's Avatar
Quoted: 13 Post(s)
On my '06, Mazda specs FL22-compatible coolant/anti-freeze. I haven't researched enough to know which ones are FL22 compliant.[/b]
This document- from the State of Florida suggests that FL22 is a term unique to Mazda: the only coolant or antifreeze Florida lists that mentions "FL22" is the Mazda brand. Hey, when Mazda claims that the best FL22 coolant is Mazda FL22 coolant, who can argue?
And see this official MazdaUSA document- (bottom of page 12).
posttosh is offline
post #6 of 14 (permalink) Old 03-16-2008, 12:21 AM
tranz's Avatar
Quoted: 6 Post(s)
Problem Solved?
EDIT: Sorry the pics turned out a little blury. lol. And their deffinently not upright.
tranz is offline
post #7 of 14 (permalink) Old 03-16-2008, 02:18 AM
DennisW's Avatar
Quoted: 11 Post(s)
I will likely go the standard Prestone route. If the anti-freeze is changed on a regular basis, there is zero benefit in using long-life fluid. I'd rather save a few bucks by going to Costco, knowing I'll replace it in (at mose) 2 years anyway. Prestone, distilled water and RedLine Water Wetter has never let me down. The Prestone has equally superior protection for dissimilar metals, and Water Wetter only adds to that protection, in addition to helping the water remove heat.[/b]
Probably the best solution as long as you completely flush out the old stuff, and most likely a lot cheaper and easier to obtain than the mysterious FL22.
DennisW is offline
post #8 of 14 (permalink) Old 03-16-2008, 08:36 AM Thread Starter
posttosh's Avatar
Quoted: 13 Post(s)
Captured on video! Details at 11:00!
Do you have pictures of a yeti or sasquatch in the wild , too?
posttosh is offline
post #9 of 14 (permalink) Old 03-17-2008, 01:56 AM
Quoted: 139 Post(s)
Groans: 5
Groaned at 8 Times in 6 Posts
Best top odff I found was peak global, like dexcool except it uses no 2EH that ford hates, and uses "sodium bentonate"? like a G05 and F22.
For flush and fill, I'd switch to G05.
04 6S atx hatch
93 RX-7, 75 Trident
KevinK2 is offline
post #10 of 14 (permalink) Old 04-15-2008, 03:06 PM
Send a message via AIM to leviat
Mazda released a TSB with information about the mysterious FL22 coolant. In short...
• FL22 coolant is compatible with current (Green) ethylene glycol coolant.
• If FL22 coolant is mixed with existing Orange coolant, coolant color will turn black. For customer satisfaction, DO NOT mix FL22 coolant and Orange coolant.
You can find the full TSB here: http://www.mazda6wiki.com/wiki/TSB_01-033-07
Edit:
Part number is 0000-77-508E-20
MazdaSpeed6 GT : Liquid Platinum
[color="#000099"]CP-E (CAI, BoV Kit, Engine Mount, DP, Dual TBE)
RAYS (Gram Lights T57-RC 18x7.5")
DeFi (Boost, Oil Pressure, EGT)
AutoEXE (CF Lip Kit, CF Grill, Low-Down Springs)
Misc (iPod/Aux, Stubby Antenna, DashHawk)
leviat is offline
