Shifting Gears Without The Use Of Clutch? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 09-05-2007, 05:22 PM Thread Starter
Fenixz Prime's Avatar
Question
I just noticed something when I was shifting. When I'm driving, I can actually shift gears back to neutral without pressing on the clutch. I still have to press the clutch to go to another gear but i just found it weird that I was able to do that. I only did it once or twice to confirm that I can do that but stopped cos I don't want to damage the transmission in the even that it's not really normal for that to happen. Has anyone got the same experience? I have '04 6S mtx.
Pictures of my 6 soon to be posted here. It was supposed to be done months ago.
Fenixz Prime is offline
post #2 of 10 (permalink) Old 09-05-2007, 05:32 PM
StylinM6s's Avatar
Send a message via AIM to StylinM6s
So you can shift to neutral w/o pressing in the clutch? If so, that most likely isn't good for the syncros. But that's interesting how that can go through
2005 Mazda 6s V6 MTX Glacier Silver, Black Leather, Loaded, 30% tint
SOLD!
Now: 98' Mustang Cobra SVT
4.6L V8 32v
1 out of 356
StylinM6s is offline
post #3 of 10 (permalink) Old 09-05-2007, 05:47 PM
Matt6S's Avatar
So you can shift to neutral w/o pressing in the clutch? If so, that most likely isn't good for the syncros. But that's interesting how that can go through[/b]
You can shift into neutral w/o using the clutch, but I never do because I don't want to get into the habit. THere are some that can shift gears w/o the clutch at all, but it has to be done exactly right or it will mess up your trans. I wouldn't recommend trying it if you don't know what you're doing.
'06 6S 5-Door mtx Onyx Black Gran Sport 5-speed 32% tint
Matt6S is offline
post #4 of 10 (permalink) Old 09-05-2007, 06:22 PM
It's funny you mention this. Earlier today I had the car shifting perfectly fine without the use of the clutch. The key to the whole thing is to shift in and out at the right RPM. You can just feel the car accepting it and it's smooth too if done right.
Mazda 6i Sport (Hatch, Onyx Black, 15% tint) 2007 - 5 Speed Manual Trans. MT-90 Oil
My Mods:
- Turbo Charged.
Polish_Eagle is offline
post #5 of 10 (permalink) Old 09-05-2007, 06:34 PM
norrisjg's Avatar
I had a chevy s-10 that I could completely shift the gears w/o using the clutch. I would completely rev it through a gear and as I took my foot of the gas, I could quickly shift it into the next gear. I DO NOT suggest doing this with a car you care about but I didn't ever experience a problem from doing it.
2006 Mazdaspeed6 -- Pearl GT with Mazdaspeed CAI
The dumbest people I know are those who know it all.
norrisjg is offline
post #6 of 10 (permalink) Old 09-05-2007, 07:04 PM
I had a chevy s-10 that I could completely shift the gears w/o using the clutch. I would completely rev it through a gear and as I took my foot of the gas, I could quickly shift it into the next gear. I DO NOT suggest doing this with a car you care about but I didn't ever experience a problem from doing it.[/b]
If you can get the RPM's right you should have a problem, but if you are forcing it into gear then you will cause some serious damage. Its KEY to get the perfect RPM. But I wouldn't recommend driving daily like that, maybe to try it here or there. Its not all that hard to push the clutch.
My Mods:
- Turbo Charged.
post #7 of 10 (permalink) Old 09-06-2007, 12:46 PM Thread Starter
Unhappy
I can only shift it back to neutral without clutch. still need it for moving to another gear. kinda like having automatic and u can shift to neutral without pressing the shift button(or whatever it's called) but can't move it to reverse or other gears. I was curious to see if this is something I should be telling the dealer since I am getting close to the end of my warranty.
post #8 of 10 (permalink) Old 09-06-2007, 01:00 PM
BlackCherry06's Avatar
Send a message via Yahoo to BlackCherry06
I shift into neutral without the clutch all the time. The higher gear you're in, the easier it is to do. If you don't feel any resistance from it, you're not hurting anything. Jerking it out of gear while there's pressure on the transmission from the engine's acceleration or compression braking forces is a bad idea, however.
I've driven several trucks that allowed clutchless shifting, but I've never driven a fwd car that took very kindly to it.
___ ___ ___ ___ ___ ___
BlackCherry06 is offline
post #9 of 10 (permalink) Old 09-06-2007, 01:00 PM
Being able to pull the stick out of gear (or "shifting into neutral") without the clutch is completely normal. I've driven multiple manuals and they all do it.
However, no matter how "perfect" you shift INTO gear without using the clutch, you are going to most likely do damage to your synchros and gears. If not immediately, then probably over time. IMO, don't even try on a car you care about.
2008 Sunlight Silver Metallic MS3
Sold: 2003 Silver Mazda 6i MTX - Modifications - Magnaflow Cat-back Exhaust - MazdaSPEED CAI - MazdaSPEED Protege Shift Knob - 50% Llumar Charcoal Tint - Lotek Gaugepod - Prosport Gauges
canislupis is offline
post #10 of 10 (permalink) Old 09-09-2007, 06:42 PM
i wont hurt it but why temp fate. maybe doing it once in awhile wont hurt but not a good pratice. its not designed to operate that way
Sleeper626 is offline
