So I know stock 17" tires are 215/50/17. I'd like to go just a tad wider to help protect curb rash, which the previous owner of my car took no care of. Also a wider tire cannot hurt my traction either.
I know there are slight changes that might occur to the speedometer reading or other slight differences when doing this. I'd like to see if having a slightly wider tire is a good idea. What do you all think and what size should I go for to suit my needs? Thanks!
2005 Mazda6 s Sport Hatchback Steel Grey Metallic 6-Speed Auto w/ Manual mode |
I've found on several cars that 225/45 has been a good performance / ride compromise. They'll be a slightly smaller overall diameter than your stockers, causing a fast speedo. You could probably get away with going up to a 235/45 which would put your speedo very nearly dead-on, and would definitely add some rim protection at the expense of a good sidewall fit. Bulging outward or inward causes a performance (and in extreme cases, a safety) compromise so for that reason, 235s wouldn't be my first choice for these wheels.
___ ___ ___ ___ ___ ___ |
Had 235/50/17 Michelins on my stocks (used only in winter) ... ride and handling still excellent. No rub. Seems to protect rims but then again haven't curb check the rims yet.
(`ー´)<sup><span style="color:#00ff00"><span style="font-family:Comic Sans MS">WTB<span style="color:#000000">: ALOT of THINGS!</span></span></span> <span style="font-family:Impact"> |
![]() Join Date: Apr 2005
Try 225/50s. The speedometer error is less than the 225/45s, and since most speedos read 1-2 MPH too fast (well, mine does
), it'll help to give a more accurate speed.I plan on bumping up to this size for my next tire purchase, and I haven't heard any issues with rubbing (using stock rims). |
I would NOT go with 235/45R17s..... they are meant for 7.5-9.0 inch rims. The OEMs are only 7" wide I believe....
225/45 or 225/50 are your best options if you want wider tires without changing your wheels. Keep in mind that with the wider tire, there will be more sidewall flex which doesn't really help your cornering ability. But, then again, if you are not racing or concerned with performance, it might not even matter.
L76-powered |
#6 (permalink) | |
I'm wondering how worth it is to get wider tires.
#7 (permalink) |
Here is what the two sizes look like compared to the stock size of 225/50/17:
[attachment=28053:225_45.JPG][attachment=28054:225_50.JPG] |
#8 (permalink) | |
225/45 is an option, but not a good option, on a 7" rim (the sidewall, shorter than OEM, ends up canted too far from the vertical). 225/50 is a good option on a 7" rim (the sidewall, longer than OEM, has flex room). |
#9 (permalink) | |
#10 (permalink) |
Hey thanks for the great thread. I have the same thoughts. Not quite willing to make the plunge to get new rims/tires, but the stockers sure stick out pretty far.
2006 Black Cherry M6S - SOLD!!! Bought a 2008 Candy Apple Red Mustang GT 5speed!! |
