2.3L Oil Change Question? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Mazda6 (Atenza) > Newbie Section
New User? Register
Old 04-08-2005, 01:57 PM   #1 (permalink)
hype4bid
Guest
Posts: n/a
Quoted: Post(s)
I own a 2003 Mazda 6/2.3 L for a little over a year now. I decided finally to change my own oil instead of going to the dealer and pay the high-inflated price. After 2 weeks of searching, I finally located a filter via Advanced Auto parts. I opened the package and notice a canister filter with 2 rings (small and large). Its foreign to me, since the only oil changes I done was to my 91 MR2. I was discouraged because I never saw a filter like it. I decided to take my Puralotor filter and car to an express lube place to get my 1st synthetic oil change. After parking the 6 in the pit, they popped up the hood and a few minutes later, the manager approach me stating they can’t change my oil because they don’t have the tools to do it. They specify that a 6-sided tool was needed to remove a part to get to the oil and filter and they never changed a 2.3/L 6. They advised that I should take it to the dealer. That was that; wonder if this is a myth? Anyone had experiences changing their 6s’ oil? Any insight would be appreciated?
Old 04-08-2005, 02:45 PM   #2 (permalink)
crossbow's Avatar
http://www.mazda6tech.com/Articles/How-To/...-Mazda-6i-.html
Make sure to use a perfectly fitting filter cap tool...using pliers or something that "almost fits" is extremely dangerous.
crossbow is offline   Reply With Quote
Old 04-08-2005, 03:00 PM   #3 (permalink)
Da 6's Avatar
Send a message via AIM to Da 6 Send a message via Yahoo to Da 6
filter wrench is 15 flute 74mm or 76mm with paper towel linning it)
2005 Satin White Pearl Subaru Legacy GT *13.5 @96 MPH In Stage 2.5*
Da 6 is offline   Reply With Quote
Old 04-08-2005, 03:01 PM   #4 (permalink)
Monsoon's Avatar
If you have never taken any auto shop in high school this will be foreign to you. You need to get yourself educated on the oil changing process for this 2.3L engine.
When I first brought my 6i home for the first time I was concerned also. Be very careful how you handle the plastic canister that holds the oil filter. After you have done your first oil change it will be like riding a bike. The plastic canister will be damaged if you don't have the correct tools to remove/install it.
Your first oil change may appear difficult but it is not impossible if you take the right approach.
You will need to remove the large splash guard to gain access to the canister. I use Rhino ramps to gain access from underneath the car.
I hope this is enough tips for you.
> > Show me the Data! < <
You can always grow-up but immaturity can last a lifetime.
Not Your Average Six Owner...
www.mozilla.org
Monsoon is offline   Reply With Quote
Old 04-08-2005, 03:08 PM   #5 (permalink)
Da 6's Avatar
the 2 o-rings are also a critical item to replace. all steps needed to taken. It's not a hard task...just a time consuming one compared to a traditional spin on.
