Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain > MTX Transmission Discussion
Old 09-17-2009, 10:03 AM   #1 (permalink)
like the title says im in need of the torque specs for the pressure plate and flywheel, and if anyone has it the bolts that hold tranny to block, because the shop that just put this motor in didnt torque anything one bolt's super tight then next is finger loose and so on and so forth..any help would be kickass
justinhb is offline   Reply With Quote
Old 09-24-2009, 01:27 PM   #2 (permalink)
DaveRulz's Avatar
Send a message via AIM to DaveRulz
QUOTE (justinhb @ Sep 17 2009, 10:03 AM)
like the title says im in need of the torque specs for the pressure plate and flywheel, and if anyone has it the bolts that hold tranny to block, because the shop that just put this motor in didnt torque anything one bolt's super tight then next is finger loose and so on and so forth..any help would be kickass[/b]
I can check my factory service manual tonight if you still need this information.
Performance: CP-E Engine Mount - Autovation Racing Pedals - Single 2.5" exhaust - Magnaflow Mufler/Resonator - Graphite Konig Troubles with Toyo Proxes 4 (Summer) RX-8 16s with Hankook Z212 (race) stock 16s (winter) - Mazdaspeed Short Throw Shifter - Mazdaspeed6 shocks and springs - Racing Beat Rear Swaybar and endlinks - CPE MAFCi
Exterior: ATH lip Kit - Badgeless Grill - Stock lower fog lights - Euro tail lights tinted red - Side marker tinted overlays
Audio: Alpine CDA9887/Ipod, molded metra dashkit - Rockford Fosgate Power T3002: Dayton RSS315HO-4 (changes sometimes)- Rockford Fosgate Power T4004: Dayton RS180-4 in doors and Dayton RS-28A in kickpanels, actively crossed - Kicker Hyperflex 1/0 wiring.
In The Basement: Tinted headlight bezels - DIY LED Halos - rear bumper lip </span>[/i]
Currently the engine is out due to Pre-Cat failure on the front bank. Rebuilding with 2004 Sable shortblock, Ebay headers, Fidanza flywheel, stock clutch, AWR engine mounts, Aeroforce Interceptor, Glowshift Oil Pressure.
<span style="color:#FF0000">Rebuilt frankensablemazda motor is in, AND IT RUNS
DaveRulz is offline   Reply With Quote
Old 09-25-2009, 06:31 AM   #3 (permalink)
QUOTE (DaveRulz @ Sep 24 2009, 10:27 AM)
I can check my factory service manual tonight if you still need this information.[/b]
ya i fell and hurt my back so car is just now goin back together if youhave those specs that would rock
Old 09-28-2009, 08:42 PM   #4 (permalink)
CanyonRider's Avatar
Bellhousing to block: 28-36ftlbs
Pressure plate to Flywheel: 19-24ftlbs (gradually, evenly in crisscross pattern)
Flywheel to crank depends on transmission model:
G35M-R tranny: 80-85ftlbs
A65M-R tranny: 54-64ftlbs
The easiest way to tell them apart is the location of the VSS (vehicle speed sensor). The G36M-R VSS is on the driver's side of the differential, the A65M-R VSS is on the passenger's side.
FWIW: My 2003 V6 5-speed has the A65M-R.
2003 Mazda 6s MTX
CanyonRider is offline   Reply With Quote
